I see no switch to disable hybrid graphics (use only the discrete RTX card) in the BIOS. I have the advanced BIOS settings enabled as well. Am I missing something?
Precision 5000 series doesn't have the option to disable hybrid graphics and run with discrete GPU only. You need 7000 series for that.
