I bought two copper sheet 1.2mm and 0.8mm thickness and started to use 1.2mm thickness to fix the p870tm cpu heatsink by using copper sheet between IHS and the heatsink to fill the gape between them using kryounut thermal paste and i use a Liquid Metal when i delided 8700k cpu. So the results is great  now and the thermal throttling gone.
  • 4 weeks later...
Hi Maro,
I have finished developing and producing my second CPU fan controller for the P870TM. This makes it possible to control the second 5V fan simultaneously with the 12V main fan! Pictures are shown in the main thread (P870TM). Everything works as I designed it...
Big thanks to you for your support:-)
