oldpops Posted August 29, 2025 Posted August 29, 2025 Hello! I'm an old guy, and so is pretty much everything I own. Anyway I have an old Inspiron 6420 laptop and I need an Inspiron 6420 laptop I need to get a replacement charging cord. I order one on Amazon that was supposed to work but it has a flat little USB connector at the end of the charging cord. The one on the back of my laptop is round, and it's got some kind of pin connectors (I think two or three) that the charging cord plug end must have. I know it's an old laptop, but I'm disabled and my wife and I are seniors on a very fixed/tight income, so getting a new laptop is out of the question. I need my laptop going because there's important information on it and the battery is dead. Anyone here got any suggestions on where to get a new ac charging cord - that is the correct one? When you look online, none of the charging cords advertised give you a look INSIDE of the round charging cord connector (which I believe is 2 or 3 pins). Does anyone here have an old Inspiron laptop like mine, that could post a picture of the inside of the round plug (that goes into the back of the laptop). Thanks in advance to all who offer help and advice!!!
John Ratsey Posted August 31, 2025 Posted August 31, 2025 Do you mean an Inspiron 6420 or a Latitude 6420? The latter uses the same PSU as many other Dell models and the plug has a thin pin in the middle which is used for communication between the computer and the PSU.
oldpops Posted August 31, 2025 Author Posted August 31, 2025 Oh, I'm not sure if it's a Inspiron or a latitude? I gather they use different connectors?? Do you know where I can see both connectors and choose the correct one? (If I can find it?)
John Ratsey Posted August 31, 2025 Posted August 31, 2025 Does it look like this? https://www.amazon.co.uk/Dell-Genuine-Latitude-Adapter-450-ABFO/dp/B07GJQ3W7X
oldpops Posted August 31, 2025 Author Posted August 31, 2025 Thanks. We're in the USA so they won't ship that here. I've tried to attach a photo of the actual plug. The laptop says Dell Latitude but I don't know how big or small the connector hole size is. Does this help?
Aaron44126 Posted August 31, 2025 Posted August 31, 2025 That's a standard Dell barrel power connector that they used on many, many laptops from around 2003 until pretty recently when they switched to USB-C (the "flat" connector). So you can use any Dell power adapter with that barrel plug on the end, as long as it supplies enough wattage. 130W should be adequate for any Latitude or Inspiron. https://www.amazon.com/Dell-PA-4E-Adapter-Battery-Charger/dp/B00CKYGN3W?mfadid=adm (If you search for "PA-4E" on Amazon, you will find many options, but most of them are "off-brand".) These are very pervasive, and since don't need one specific to your model laptop, you should actually be able to find one locally without too much difficulty. I would think that a used computer / electronics recycling place would have these laying around and be able to sell one to you. If you have any friends or family who work in an office where they use Dell equipment, their IT department might be able to just hand one out. (I'll note that Dell actually had two different barrel connector sizes that they used with laptops before switching to USB-C. This fat one was used with almost all systems, but some of the slim XPS systems used a much smaller barrel plug.) 1 Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi
John Ratsey Posted August 31, 2025 Posted August 31, 2025 1 hour ago, Aaron44126 said: (I'll note that Dell actually had two different barrel connector sizes that they used with laptops before switching to USB-C. This fat one was used with almost all systems, but some of the slim XPS systems used a much smaller barrel plug.) Yes, the bigger connector is about 7.5mm diameter while the smaller one (about 4.5mm dia) was introduced when the computers got slimmer. Dell sold a short adaptor cable so that the old connector could be used with the smaller socket so that companies' stocks of spare PSUs didn't become obsolete.
oldpops Posted September 1, 2025 Author Posted September 1, 2025 Thanks. The last laptop charger I got was 90 watts - I didn't even know there was a 130 watt charger. Is that better? Does it charge faster?
Aaron44126 Posted September 1, 2025 Posted September 1, 2025 You can use a 90 watt then. 130 watts will also work but it won’t get you any benefit. Similarly, any 90 watt Dell charger with the appropriate connector on the end should be fine. It doesn't have to be specific to your model laptop. Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi
oldpops Posted September 4, 2025 Author Posted September 4, 2025 Thank you. Got a charger for my laptop. 2
kojack Posted October 2, 2025 Posted October 2, 2025 Since this is talking about chargers for dell systems, Is there anyone out there that makes a USB C on one end and Dell Barrel on the other? So we can use smaller charging blocks? I travel alot and have a travel charger I bought off Amazon some years ago, but its starting to show it's age and I cannot find a replacement. Workstation - Dell XPS 8940 - desktop creative powerhouse Mobile Workstation - Dell inspiron 5406 2 in 1 - mobile creative beast Wifey's Notebook - Dell inspiron 3169 - Little gem for our businesses
