ccvortex Posted September 13, 2025 Share Posted September 13, 2025 I know DELL didn't put a high refresh rate panel int he 5680 but was wondering if anyone knows if its possible to install a generic or other non DELL display to get a higher refresh rate. I would keep this laptop forever if I could only get a 90+ hz display in it... right now it's a 1920x1200 60 hz panel. So something like this: https://www.amazon.com/GBOLE-Replacement-Digitizer-1920x1200-Non-Touch/dp/B0D9NQCCST Link to comment Share on other sites More sharing options...
Aaron44126 Posted September 13, 2025 Share Posted September 13, 2025 I haven’t heard of anyone trying something like this yet on this model. Seems like it “should” work, if the replacement panel has the same connector, and you can actually perform the physical replacement. On that last point, I will say that Dell has made it a lot more annoying to replace the panel than it was in earlier systems. Before, you could snap the bezel off, take out some screws, and easily swap out the panel. Now, the panel is held in place by adhesive, not screws. Aligning a new one would be tricky. When Dell replaces a panel under warranty, they just replace the entire top part of the laptop — panel, enclosure, antennas, and all — rather than replacing the panel only like they used to. Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi Link to comment Share on other sites More sharing options...
ccvortex Posted September 13, 2025 Author Share Posted September 13, 2025 Yeah, I just had the panel on my 7760 replaced and that's how he did it. Just tore off the adhesive backed front panel and slapped on a new one. I'll ping Parts-People too ,see what he thinks. Link to comment Share on other sites More sharing options...
