rusvon Posted September 22, 2025 Posted September 22, 2025 hello everyone if I remove the standard 5V 0.5a (2.5watt) cpu fan from m18x r2 or m17x r4 and replace it with a 5V 1a(3.5w) or 12V fan, will it work without any problem? what is the maximum wattage the fan power input can handle? has anyone measured this?
janepa Posted September 23, 2025 Posted September 23, 2025 On 9/22/2025 at 3:42 PM, rusvon said: hello everyone if I remove the standard 5V 0.5a (2.5watt) cpu fan from m18x r2 or m17x r4 and replace it with a 5V 1a(3.5w) or 12V fan, will it work without any problem? what is the maximum wattage the fan power input can handle? has anyone measured this? Hi, i think there is 9 or 10 Amps FET transistor to powering all fans when i remember. I was studying the same when i need to add powering a water pump o this power line. Alienware M18x R1 i7-2720xm-32GB-Adlink RTX5000 Alienware M18x R2 i7-3920xm-32GB-RTX4090 (still in testing) with the latest bios version. A14 specially modified updated and unlocked by me 😎 Asus ROG Zephyrus G14 AMD Ryzen 9 7940HS-32GB-RTX4060
