Good evening everyone,
So I want to change the motherboard of my Alienware 18 (the CN-04703X motherboard) for a new one because I'm a bit afraid that the old one won't last too much. The thing is, I managed to change the BIOS display setting to SG mode (I modified the BIOS because I'm going to install a GTX1070 in the future). So when I get the motherboard and change it, will the SG setting stay as is? or will I loose my modification or cause further problems? (Or should I change to default display setting, swap the motherboard and then I can swap it to SG back again?)
Please help and thanks, I just want to make sure I don't cause display issues, its an expensive laptop.
You will need to flash the new motherboard with the modifed BIOS. All that information is stored on the BIOS chip on the board.
The modification you made in the BIOS on the old motherboard will, of course, be lost if you install a new motherboard. You’ll need to flash the unlocked BIOS again on the new board and then enter the BIOS to reconfigure the settings
On 11/1/2025 at 8:48 AM, Maro97 said:
@Maxware79 He is a god father of old Alienware laptops .
Understand what he says carefully and follow all his instructions so you can achieve the result you want without any problems
I appreciate that but @ssj92 is the real Godfather. He has done things that people thought would be impossible.
Hi,
Flashing bios is quite easy, there's a good tutorial here on the forum.
You'll definitely need modded BIOS if you want to install 1070 GTX in the future, as a fixed SG mode is mandatory for that one (no edp screen in AW18 unfortunately).
Original BIOS is default in PEG mode, which will result in 8 beep error and blank screen.
