poprostujakub Posted November 29, 2025 Posted November 29, 2025 I recently bought second-hand Zbook 17 G6 and it has strange problem - maximum power CPU can draw steadily is 30 watts, despite HWInfo stating it's 55/110 watts. Rarely I see spikes to 47 watts. Laptop has no dedicated GPU at the moment and power brick is 230 watts. CPU temperature at full load is around 75 °C. Full load frequency settles at 2.8 GHz which is very dissapointing. Clevo P870DM by Dsanke||i9-9900KF||HP Quadro RTX5000 Clevo M980NU||C2Q QX9300@3GHz||Dell Quadro M3000M Clevo P180HM||i7-2920XM||GTX680M
1610ftw Posted November 30, 2025 Posted November 30, 2025 Which CPU do you have and what are your settings in power options? You want max CPU power at 100% at least when connected to power. Even at 99% the turbo boost will be disabled and it may be that this is happening and/or you are stuck in power saving mode. At 2.9GHz you probably have the Xeon E-2286M?
poprostujakub Posted December 2, 2025 Author Posted December 2, 2025 i7-9850H. But I think that I resolved the case - it does this without battery. I have it partly disassembled because it waits for GPU so I didn't put battery in it. With battery clocks spikes to 4.6 GHz at about 100 W (and then thermal throttes by 20% according to HWInfo) then drops to 55 W at 3.6 GHz and 85 °C. But I'm dissapointed in cooling solution and fan curve, they would be good for multimedia use, not for workstation. Clevo P870DM by Dsanke||i9-9900KF||HP Quadro RTX5000 Clevo M980NU||C2Q QX9300@3GHz||Dell Quadro M3000M Clevo P180HM||i7-2920XM||GTX680M
1610ftw Posted December 2, 2025 Posted December 2, 2025 3 hours ago, poprostujakub said: i7-9850H. But I think that I resolved the case - it does this without battery. I have it partly disassembled because it waits for GPU so I didn't put battery in it. With battery clocks spikes to 4.6 GHz at about 100 W (and then thermal throttes by 20% according to HWInfo) then drops to 55 W at 3.6 GHz and 85 °C. But I'm dissapointed in cooling solution and fan curve, they would be good for multimedia use, not for workstation. That is indeed interesting and another design fail. Unfortunately my Zbook 17 G6 is also the one laptop that empties its battery in record time when not connected and I haven't had time to get to the bottom of it. The fan curve is really stupid. I suggest to get PWM7950 for it to keep temps as low as possible but even then the fan curve is severely limiting power due to its emphasis of silence over anything else. If you ran updates already then it probably does not matter any more but if you haven't you should block bios updates in device manager as previous bios versions would allow third party fan control and undervolting via Throttlestop or Intel XTU but HP took all of that away in later bios. What I would do to mitigate issues further is to use Intel XTU in order to limit maximum CPU power to something like 75 or 80W and you can also try to limit the hottest cores to lower max clock speeds - usually the 9850H will run very hot on a core or too which will cause it to throttle a lot faster than needed. If that is not possible you can still use Throttlestop to limit maximum power to the CPU and again I would go for 75 or 80W as that will give you a more even user experience than the spiking that you get when power is ramping up to 100W. I am also not sure if it is possible to go back to an earlier bios but I am lucky in that I am in a situation where I do not have to risk going back as my use case is such that I can live with the current fan curve. This is a magnificent chassis with very bad software and on top of that is is also completely locked down in the final bios version which is a worst case combination. Because of that it will also be my last HP laptop for now until I see that they have a design that has great hardware AND software.
poprostujakub Posted December 2, 2025 Author Posted December 2, 2025 Yes, I was impressed by the amount of expansion slots on the MB and rigidity of the chassis. I'm experimenting with custom fan driver built using Arduino Nano SuperMini stuffed into unused CD drive bay, but as good I am at electronics, I am bad at programming, so with current algorythm fans are very jerky when switching from fast changing MB signal to slow creeping input from thermistors I've glued near the VRM's (whichever is higher sets PWM duty for the fans), but I believe that after some more iterations it will be usable and maybe I will also use it my P870DM (stuffed with RTX5000 stolen from this HP, with incompatible temperature reporting 😆). Thanks for the advices, I'll check how much more watts I can squeeze. As for the uneven core heating, I tried bending cooling and added second springs to screws around CPU which mitigated this problem a little. I wonder if more powerful fans EG85100S1-C100-S9A from Fury 16 G10 i9+RTX5000 would fit, but they're way to pricey for now to play around. Clevo P870DM by Dsanke||i9-9900KF||HP Quadro RTX5000 Clevo M980NU||C2Q QX9300@3GHz||Dell Quadro M3000M Clevo P180HM||i7-2920XM||GTX680M
1610ftw Posted December 4, 2025 Posted December 4, 2025 Wow - I am impressed 🙂 I will have a look at my Zbook 17 G6 later to let you know what I can get in temperature and sustained watts over a 10 minute CB R23 run. Unfortunately no Intel XTU for me due to the stupid locked down bios. The 5000 is a very nice card - I only have the 4000.
1610ftw Posted December 4, 2025 Posted December 4, 2025 So I checked and 80W can be sustained with a 10 minute CB R23 loop. Due to the anemic fan speeds the CPU reaches up to 99C I made a quick check with lower limits and I arrived at around 95C with 75W and 90C with 70W power limit. I also checked 55W and that is more like 80C and the fans ramp down already with that power target. That is all with the laptop closed and including the GPU and with the back propped up by about 4cm for better airflow.
JadeRover Posted January 10 Posted January 10 Hey all, I have the zbook 17 g5, You can control fans with NotebookFanControl : GitHub - hirschmann/nbfc: NoteBook FanControl and use this profile for Zbook 17 g3 : Current Fan Speed Negative Value · Issue #501 · hirschmann/nbfc You can control GPU and CPU fan independently + create your own fan curve Bought it last year with bios v1.24. I went down to v1.08 going through : v1.24 -> v1.20 -> v1.18 -> v1.14 -> v1.12 -> v1.08 using the plugging in usb method and selecting the "update bios" in the bios setup. It didn't always downgrade, not sure why, but I got there in the end by jumping a few versions at a time. It was a massive pain but now I can undervolt and the 8850H I have has +400mhz OC option that gets enables meaning in theory it can run all core at 4.7ghz (never saw it happen, all core 4.45 ish possible @ 100 watts, -110mv, crashes) Precision M6700 : i7-3740QM | M3000M 4gb +250mhz OC vbios | 20gb DDR3 | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | P3000 6gb modded imac vbios | 16gb DDR4 | FHD ips Precision 7720 : i7-6820HQ | GTX1060 6gb, 88w OC vbios | 16gb DDR4 | (crappy) FHD ips Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 | FHD IPS -> attempting 4K120hz upgrade
1610ftw Posted January 11 Posted January 11 That sounds like quite the journey to get to a bios that still allows fan control and undervolting! Not sure I would risk bricking mine if indeed so many downgrades are needed but even if I wanted to I would not know where to get the files - where did you get yours?
JadeRover Posted January 11 Posted January 11 Looking at the CVEs, for the zbook 17 g6 you'll need to go back as far as v01.02 I got all of them from the official HP driver website, here is the page for your g6 (under "see revisions history") : https://support.hp.com/ca-en/drivers/swdetails/hp-zbook-17-g6-mobile-workstation/22892902/swItemId/ob-352280-1 You'll need to download the exe, run it and chose the option to install to usb. Then on the zbook, plug in the USB and boot to the bios and go to : Main -> update system bios -> make sure "lock BIOS version" is unchecked + "unrestricted bios rollback" is selected -> "Update system bios ... using local media" Normally that should do it, I think you'll need to jump slowly down to v01.02. There is no risk of corrupting the bios if you have power plugged in + charged battery Only downsight is that having to go as far back as v01.02 might make some BIOS features that got added later dissapear. 1 Precision M6700 : i7-3740QM | M3000M 4gb +250mhz OC vbios | 20gb DDR3 | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | P3000 6gb modded imac vbios | 16gb DDR4 | FHD ips Precision 7720 : i7-6820HQ | GTX1060 6gb, 88w OC vbios | 16gb DDR4 | (crappy) FHD ips Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 | FHD IPS -> attempting 4K120hz upgrade
1610ftw Posted January 14 Posted January 14 Thanks - that is a big surprise to find all of these for download on the bottom of the revision history page! I had a look at the release notes and it may be possible that I do not need to go back that far but we shall see. In any case it is great news to be able to have that option and I will download the files for possible later use.
frelu Posted January 18 Posted January 18 Hello @1610ftw, Did u manage to do the downgrade? I am interested in this topic too
JadeRover Posted January 18 Posted January 18 4 hours ago, frelu said: Hello @1610ftw, Did u manage to do the downgrade? I am interested in this topic too Hi, I can assist you if you need, the usb method is the only way I think. Precision M6700 : i7-3740QM | M3000M 4gb +250mhz OC vbios | 20gb DDR3 | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | P3000 6gb modded imac vbios | 16gb DDR4 | FHD ips Precision 7720 : i7-6820HQ | GTX1060 6gb, 88w OC vbios | 16gb DDR4 | (crappy) FHD ips Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 | FHD IPS -> attempting 4K120hz upgrade
frelu Posted January 18 Posted January 18 On 1/18/2026 at 5:39 PM, JadeRover said: Hi, I can assist you if you need, the usb method is the only way I think. I don't have the laptop yet. Still thinking about g6 with 9880h vs G7 10850. G7 is locked for undervolting for sure. If it's still doable with G6 I will swing to G6, but if not I will take G7.
aulafire74 Posted January 25 Posted January 25 On 1/11/2026 at 11:51 PM, JadeRover said: Looking at the CVEs, for the zbook 17 g6 you'll need to go back as far as v01.02 I got all of them from the official HP driver website, here is the page for your g6 (under "see revisions history") : https://support.hp.com/ca-en/drivers/swdetails/hp-zbook-17-g6-mobile-workstation/22892902/swItemId/ob-352280-1 You'll need to download the exe, run it and chose the option to install to usb. Then on the zbook, plug in the USB and boot to the bios and go to : Main -> update system bios -> make sure "lock BIOS version" is unchecked + "unrestricted bios rollback" is selected -> "Update system bios ... using local media" Normally that should do it, I think you'll need to jump slowly down to v01.02. There is no risk of corrupting the bios if you have power plugged in + charged battery Only downsight is that having to go as far back as v01.02 might make some BIOS features that got added later dissapear. Hello, I tried this and succesfully downgraded to V1.14 then it was blocked out by system policy, either directly from windows or USB stick, can you share how you manage to downgrade it further to V1.08? Thanks
JadeRover Posted January 25 Posted January 25 Huh, I did this a while ago and was trying random things all at ounce so not sure what allowed me to downgrade all the way down to the UV bios version. Did you make sure that in the bios, the auto-update bios setting is disabled ? You can also try restricting bios rollback to to v1.01. One last thing you can try is to modify the system date to 2019 see if that allows you to downgrade if it has a "check date" security. Precision M6700 : i7-3740QM | M3000M 4gb +250mhz OC vbios | 20gb DDR3 | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | P3000 6gb modded imac vbios | 16gb DDR4 | FHD ips Precision 7720 : i7-6820HQ | GTX1060 6gb, 88w OC vbios | 16gb DDR4 | (crappy) FHD ips Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 | FHD IPS -> attempting 4K120hz upgrade
JadeRover Posted January 25 Posted January 25 You can also attempt to boot on the usb stick if I'm not mistaken, without going through the "use media update" in bios Precision M6700 : i7-3740QM | M3000M 4gb +250mhz OC vbios | 20gb DDR3 | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | P3000 6gb modded imac vbios | 16gb DDR4 | FHD ips Precision 7720 : i7-6820HQ | GTX1060 6gb, 88w OC vbios | 16gb DDR4 | (crappy) FHD ips Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 | FHD IPS -> attempting 4K120hz upgrade
aulafire74 Posted January 26 Posted January 26 19 hours ago, JadeRover said: You can also attempt to boot on the usb stick if I'm not mistaken, without going through the "use media update" in bios I disable secure boot and everything related to bios (sure start, etc) Checked rollback version max to 1.02 Load firmware to USB, boot from it (the USB content is only HP folder, i don't think its bootable, or i missing some steps perhaps) Turn on the laptop using Win + B (black screen forever with fan 100%) Setting clock to 2019 (even i try to update the bios back to back to 1.16 and to 1.14 again to make sure "last bios update" goes to 2019) The weird thing, it seems "update bios from local media" only read from local disk drive (i update from 1.24 to 1.14 using hp firmware exe from windows), it stays even after i delete the .bin on swsetup (i wonder where the program store the .bin) I tried everything I guess All with no avail, bios update denied by system policy
