Sebastian Ramirez Posted January 5 Posted January 5 Hi, since I have an older Alienware 18 I wanted to sell, I just wanted to make sure that the heatsink works properly, as you can see the heatsink does't cover the entire chip I highlighted in the picture, it that okay? The chip should be still cooled off properly right? (I will put thermal pads on all the chips of the GPU) Thanks
Sebastian Ramirez Posted January 5 Author Posted January 5 Old configuration were two 860m, and the surface of their chips of those were covered fully by the NV75W, but it still should work with a 980m right?
Jerryzago Posted January 5 Posted January 5 I believe those 75watt heatsinks have 2 heatpipes and 100watt equivalents have 3 heatpipes. So maybe they will fit the GPU, but cooling will be a problem Alienware M18x R2 / i7 3720qm -> i7 3940XM / Dual 7970m -> 980m SLI -> HP Quadro RTX 3000 Alienware 17 R1 / 4710MQ -> 4930mx / 880M GTX -> PNY Quadro RTX 3000 HP 8570w / i7 3820qm / Quadro K2000M HP DV6500 / i7 T7200 -> i7 T9500 / 2GB RAM -> 4GB RAM / Atlas OS
