Annihilator Posted January 10 Posted January 10 hey peeps, got an M6800 for 100 bucks n now just want upgrade... some stuff already clear n ordered / installed, but need to know a couple of things(mainly about GPU options). Service Tag is: 9F9PZ52 (so u guys can take a look of original config) Original Configuration --> planed - ordered - already done/delivered: i7-4710MQ --> i7-4930MX(@4.1GHz allcore) 2x 4GB DDR3L 1600 --> 4x 4GB Kingston DDR3L 2133 CL11 AMD FirePro M6100 --> NV GTX 880M 8GB(just waiting for the NV heatsink, 880M i already had bcs was planned for a imac upgrade) doesnt work, maybe corrupted Bios, Quadro P5200 atm no card works, hope board not broken, will clean slot n check again 2x SATA 500GB HDD --> 2x 250GB Samsung 850 Evo SATA Raid0 + Kioxa BG5 1TB mPCIe No WIFI --> WIFI 6/AX sticky Palmrest --> New Palmrest DVD Drive --> UHD BD Drive Low Performance GPU Heatsink --> Optimizing Heatsink: lil Copper Heatsinks, second Fan Windows 10 Pro --> Windows 11 Pro 1 Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9060 XT 16GB @ 4GHz boost 2850MHz vram - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro 7720 - i7-7820HQ - 2x 16GB 2666 C15 - P5200 16GB - Samsung 960 Pro 512GB NVMe + WD SN730 1TB NVMe - Wifi 6E - Win 11 Pro M6800 - i7-4930MX - 4x4GB 2133 C11 - GTX 880M 8GB(not working atm😒) - Kioxa BG5 1TB mPCIe - 2x Samsung 850 Evo 250GB Raid0 - Wifi 6 - Win 11 Pro
Annihilator Posted January 13 Author Posted January 13 just measured some things... i can solder some passive heatsinks on the GPU n CPU cooler plate, height between 2-5mm, n in the secondary HDD bay will fit a 70*15mm blower fan, good on this is, no mods on the cassis itself needed, just couple hole on the bottom cover for the fan to get fresh intake n done, another really great thing is, bcs the bay is open straight to the direction of the cooler plates, they will get the whole fresh air, with some passive heatsinks on it, should be easy to cool down a 120W card + 57W CPU. will post any updates when done 🙂 Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9060 XT 16GB @ 4GHz boost 2850MHz vram - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro 7720 - i7-7820HQ - 2x 16GB 2666 C15 - P5200 16GB - Samsung 960 Pro 512GB NVMe + WD SN730 1TB NVMe - Wifi 6E - Win 11 Pro M6800 - i7-4930MX - 4x4GB 2133 C11 - GTX 880M 8GB(not working atm😒) - Kioxa BG5 1TB mPCIe - 2x Samsung 850 Evo 250GB Raid0 - Wifi 6 - Win 11 Pro
Annihilator Posted January 20 Author Posted January 20 just will order another CPU fan, fits perfect in the secondary HDD/SSD bay n can blow fresh air straight to the GPU heatsink, need to make a fan cable splitter bcs will put it straight to the CPU fan connector(should handle 0.6A in total). so few holes in the bottom cover, connect the cable, put the fan in n fresh air to the mem + GPU heatsink(will solder 2mm copper heatsinks on it for maximum performance) g). 1 Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9060 XT 16GB @ 4GHz boost 2850MHz vram - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro 7720 - i7-7820HQ - 2x 16GB 2666 C15 - P5200 16GB - Samsung 960 Pro 512GB NVMe + WD SN730 1TB NVMe - Wifi 6E - Win 11 Pro M6800 - i7-4930MX - 4x4GB 2133 C11 - GTX 880M 8GB(not working atm😒) - Kioxa BG5 1TB mPCIe - 2x Samsung 850 Evo 250GB Raid0 - Wifi 6 - Win 11 Pro
Annihilator Posted January 29 Author Posted January 29 ok, next step done: found n took a 4x4GB set of kingston 2133MHz mem, now just waiting for the parcel from aliexpress n the P5200 from poland from @colohgc. 😄 new palrest ordered too, the old one looks good but its sticky(really dont know why in the 2000s everyone putted those shitty coat on everything what get sticky after couple of yrs, even ferrari did on their knobs in 400k+ cars 😵💫), backlit keyboard to find with CH layout is nearly impossible, so maybe will take a look for a german one. n seen those samsung v-nand SATA SSDs have a really tiny circuit boards, will try to fit it in secondary bay without case while the "tuning" fan is in, when it fits will use raid0 with a second one... bcs whats better then speed? more speed!! 🤪 n still thinking about hailo-8 in the WWAN slot 🫠 1 Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9060 XT 16GB @ 4GHz boost 2850MHz vram - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro 7720 - i7-7820HQ - 2x 16GB 2666 C15 - P5200 16GB - Samsung 960 Pro 512GB NVMe + WD SN730 1TB NVMe - Wifi 6E - Win 11 Pro M6800 - i7-4930MX - 4x4GB 2133 C11 - GTX 880M 8GB(not working atm😒) - Kioxa BG5 1TB mPCIe - 2x Samsung 850 Evo 250GB Raid0 - Wifi 6 - Win 11 Pro
Annihilator Posted February 13 Author Posted February 13 finally arrived: palmrest n 2x4GB 2133(2x4GB still on da way) arrived too... maybe will put tomo all together 🙂 2 Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9060 XT 16GB @ 4GHz boost 2850MHz vram - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro 7720 - i7-7820HQ - 2x 16GB 2666 C15 - P5200 16GB - Samsung 960 Pro 512GB NVMe + WD SN730 1TB NVMe - Wifi 6E - Win 11 Pro M6800 - i7-4930MX - 4x4GB 2133 C11 - GTX 880M 8GB(not working atm😒) - Kioxa BG5 1TB mPCIe - 2x Samsung 850 Evo 250GB Raid0 - Wifi 6 - Win 11 Pro
Annihilator Posted February 17 Author Posted February 17 ok, putted card into my m6800 n doesnt work, but wasnt the fault of the card bcs in my 7720 works flawless... so i think same prob with the GTX 880M, card not broken or currupted bios, think something wrong with the MXM slot, possible broken(but really dont know how, bcs i never force stuff to come out or get in), maybe dirty connects... will clean it with alc next couple days n try again. Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9060 XT 16GB @ 4GHz boost 2850MHz vram - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro 7720 - i7-7820HQ - 2x 16GB 2666 C15 - P5200 16GB - Samsung 960 Pro 512GB NVMe + WD SN730 1TB NVMe - Wifi 6E - Win 11 Pro M6800 - i7-4930MX - 4x4GB 2133 C11 - GTX 880M 8GB(not working atm😒) - Kioxa BG5 1TB mPCIe - 2x Samsung 850 Evo 250GB Raid0 - Wifi 6 - Win 11 Pro
TreeTopsRanch Posted February 17 Posted February 17 Thanks for doing this Annihilator. You may be the last of the guys on this forum to do this. Like the poster on another subject said, most of us are just buying the best computer that we can afford and not modding. The rest are using their phones. You should visit the video forums for a shock. They are dying also except for Videohelp.com. The rest are almost dead. 1
SuperMG Posted February 18 Posted February 18 I put RTX 4080 MXM on M6800 and it works (check userbenchmark for proof). No weird 40W TDP bug (maybe only happens on Alienware?). Yes 4080 displays in the main screen, eDP with backlight mod v1. The custom heatsink works, need to use PTM7950 for better performance. Sadly I can't close the lid with the heatsink installed...
Annihilator Posted February 18 Author Posted February 18 13 hours ago, SuperMG said: I put RTX 4080 MXM on M6800 and it works (check userbenchmark for proof). No weird 40W TDP bug (maybe only happens on Alienware?). Yes 4080 displays in the main screen, eDP with backlight mod v1. The custom heatsink works, need to use PTM7950 for better performance. Sadly I can't close the lid with the heatsink installed... did u measured old n new heatsink? where is the prob, at the radiator/fins or the cooler plate itself to high? im machinist n most things easy doable for me when its made from metal 😄 Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9060 XT 16GB @ 4GHz boost 2850MHz vram - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro 7720 - i7-7820HQ - 2x 16GB 2666 C15 - P5200 16GB - Samsung 960 Pro 512GB NVMe + WD SN730 1TB NVMe - Wifi 6E - Win 11 Pro M6800 - i7-4930MX - 4x4GB 2133 C11 - GTX 880M 8GB(not working atm😒) - Kioxa BG5 1TB mPCIe - 2x Samsung 850 Evo 250GB Raid0 - Wifi 6 - Win 11 Pro
SuperMG Posted February 18 Posted February 18 2 minutes ago, Annihilator said: did u measured old n new heatsink? where is the prob, at the radiator/fins or the cooler plate itself to high? im machinist n most things easy doable for me when its made from metal 😄 The fins + heatpipe are like OEM, 1.8cm height, no problem on that. But it's strange??? The heatpipes curves are made by hand and not machine... 70€ gone for nothing
Annihilator Posted February 18 Author Posted February 18 1 minute ago, SuperMG said: The fins + heatpipe are like OEM, 1.8cm height, no problem on that. But it's strange??? The heatpipes curves are made by hand and not machine... 70€ gone for nothing ahh think i got it, so the lower heatpipe doin pressure to the soundboard n bcs of that it doesnt fit? Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9060 XT 16GB @ 4GHz boost 2850MHz vram - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro 7720 - i7-7820HQ - 2x 16GB 2666 C15 - P5200 16GB - Samsung 960 Pro 512GB NVMe + WD SN730 1TB NVMe - Wifi 6E - Win 11 Pro M6800 - i7-4930MX - 4x4GB 2133 C11 - GTX 880M 8GB(not working atm😒) - Kioxa BG5 1TB mPCIe - 2x Samsung 850 Evo 250GB Raid0 - Wifi 6 - Win 11 Pro
SuperMG Posted February 18 Posted February 18 (edited) 50 minutes ago, Annihilator said: ahh think i got it, so the lower heatpipe doin pressure to the soundboard n bcs of that it doesnt fit? Yeah and I give up, I always get scammed man, CPU does not work. The heatsink doesn't fit with palmrest but it works. The heatpipes look in bad shape, is that a beta version?? EDIT: SELLER WILL GIVE ME A FREE NEW HEATPIPE V2!!!! But I need to wait like 3 weeks ... Edited February 18 by SuperMG
Annihilator Posted February 18 Author Posted February 18 6 minutes ago, SuperMG said: Yeah and I give up, I always get scammed man, CPU not work, heatsink doesn't fit with palmrest. The heatpipes look in bad shape im tempted to order the heatsink n put the fat heatpipes from the original heatsink on it... 🤪 edit, do u wrote cicichen bcs of the issues? i think he may will solve it Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9060 XT 16GB @ 4GHz boost 2850MHz vram - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro 7720 - i7-7820HQ - 2x 16GB 2666 C15 - P5200 16GB - Samsung 960 Pro 512GB NVMe + WD SN730 1TB NVMe - Wifi 6E - Win 11 Pro M6800 - i7-4930MX - 4x4GB 2133 C11 - GTX 880M 8GB(not working atm😒) - Kioxa BG5 1TB mPCIe - 2x Samsung 850 Evo 250GB Raid0 - Wifi 6 - Win 11 Pro
SuperMG Posted February 18 Posted February 18 9 minutes ago, SuperMG said: 16 minutes ago, Annihilator said: ahh think i got it, so the lower heatpipe doin pressure to the soundboard n bcs of that it doesnt fit? Yeah and I give up, I always get scammed man, CPU not work, heatsink doesn't fit with palmrest. The heatpipes look in bad shape EDIT: SELLER WILL GIVE ME A FREE NEW HEATPIPE V2!!!! But I need to wait like 3 weeks ... Yes, he said FREE 1
Annihilator Posted February 18 Author Posted February 18 Just now, SuperMG said: Yes, he said FREE look, so no scam n 100% service, custom stuff sometimes not fit 100% like original parts, but most of those lil custom factories always try to fix it 🙂 Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9060 XT 16GB @ 4GHz boost 2850MHz vram - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro 7720 - i7-7820HQ - 2x 16GB 2666 C15 - P5200 16GB - Samsung 960 Pro 512GB NVMe + WD SN730 1TB NVMe - Wifi 6E - Win 11 Pro M6800 - i7-4930MX - 4x4GB 2133 C11 - GTX 880M 8GB(not working atm😒) - Kioxa BG5 1TB mPCIe - 2x Samsung 850 Evo 250GB Raid0 - Wifi 6 - Win 11 Pro
SuperMG Posted February 18 Posted February 18 21 minutes ago, Annihilator said: look, so no scam n 100% service, custom stuff sometimes not fit 100% like original parts, but most of those lil custom factories always try to fix it 🙂 I thought he was trying to get a quick buck from me... I hope it has express shipping:) 1
SuperMG Posted February 18 Posted February 18 PEG RTX 4080, 150W, Arctic MX-4 The heatsink performance: 83C max, throttles at second 25th out of 60 seconds. The main problem comes from the badly curved heatpipes, mostly the third heatpipe which probably cuts 50% of its performance easily. It's like a loss of 15-20W easily. Memory temps: 80C max Hotspot temps: 100C max No thermal throttles in heaven benchmark 4.0, lower FPS than the Clevo P570WM3 due to the CPU I guess, I use an i7 4700MQ and not the best i7 4940MX. No thermal throttles in userbenchmark GPU suite benchmarks, very good score. I think having better heatpipes without any big tends + PTM7950 could maybe handle 150W 1
Annihilator Posted February 18 Author Posted February 18 6 hours ago, SuperMG said: PEG RTX 4080, 150W, Arctic MX-4 The heatsink performance: 83C max, throttles at second 25th out of 60 seconds. The main problem comes from the badly curved heatpipes, mostly the third heatpipe which probably cuts 50% of its performance easily. It's like a loss of 15-20W easily. Memory temps: 80C max Hotspot temps: 100C max No thermal throttles in heaven benchmark 4.0, lower FPS than the Clevo P570WM3 due to the CPU I guess, I use an i7 4700MQ and not the best i7 4940MX. No thermal throttles in userbenchmark GPU suite benchmarks, very good score. I think having better heatpipes without any big tends + PTM7950 could maybe handle 150W MX-4 is really bad at direct-die i noticed(used too all the time before i got the MX-7), works better on CPUs with heatspreader, MX-7 is a whole new lvl, was really suprised by it. n i really dont get it, why 3x 6mm heatpipes instead of 2x flattened 8mm, thermal conductivity is the same possible slightly better with the 2x8mm bcs of bigger contact area on the base plate. Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9060 XT 16GB @ 4GHz boost 2850MHz vram - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro 7720 - i7-7820HQ - 2x 16GB 2666 C15 - P5200 16GB - Samsung 960 Pro 512GB NVMe + WD SN730 1TB NVMe - Wifi 6E - Win 11 Pro M6800 - i7-4930MX - 4x4GB 2133 C11 - GTX 880M 8GB(not working atm😒) - Kioxa BG5 1TB mPCIe - 2x Samsung 850 Evo 250GB Raid0 - Wifi 6 - Win 11 Pro
SuperMG Posted February 19 Posted February 19 7 minutes ago, Annihilator said: MX-4 is really bad at direct-die i noticed(used too all the time before i got the MX-7), works better on CPUs with heatspreader, MX-7 is a whole new lvl, was really suprised by it. n i really dont get it, why 3x 6mm heatpipes instead of 2x flattened 8mm, thermal conductivity is the same possible slightly better with the 2x8mm bcs of bigger contact area on the base plate. He said it has better resistance and slightly better performance but mine had very bad heatpipes, they were in a rough shape. I found locally an i7 4900MQ I'll get that (100Mhz slower than the 4910MQ)
Annihilator Posted February 19 Author Posted February 19 20 hours ago, SuperMG said: He said it has better resistance and slightly better performance but mine had very bad heatpipes, they were in a rough shape. I found locally an i7 4900MQ I'll get that (100Mhz slower than the 4910MQ) i really would like to do a shunt mod on the M6800, bcs this 61W limit is annoying, temps around 70-72°c.(n not lapped the heatsink yet bcs was out of 1k n 1.2k sandpaper) full load so think still 20-30W more possible for the cooler before CPU start throttling. need to check when open next time what for VRMs on the mainboard n how many amps they can deliver. Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9060 XT 16GB @ 4GHz boost 2850MHz vram - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro 7720 - i7-7820HQ - 2x 16GB 2666 C15 - P5200 16GB - Samsung 960 Pro 512GB NVMe + WD SN730 1TB NVMe - Wifi 6E - Win 11 Pro M6800 - i7-4930MX - 4x4GB 2133 C11 - GTX 880M 8GB(not working atm😒) - Kioxa BG5 1TB mPCIe - 2x Samsung 850 Evo 250GB Raid0 - Wifi 6 - Win 11 Pro
SuperMG Posted February 19 Posted February 19 3 hours ago, Annihilator said: i really would like to do a shunt mod on the M6800, bcs this 61W limit is annoying, temps around 70-72°c.(n not lapped the heatsink yet bcs was out of 1k n 1.2k sandpaper) full load so think still 20-30W more possible for the cooler before CPU start throttling. need to check when open next time what for VRMs on the mainboard n how many amps they can deliver. Impossible for me to do desoldering, I'll just get the 4940mx then
Annihilator Posted February 26 Author Posted February 26 now everything arrived, today the last 2 of the 2x 2x4GB kits arrived... time to bring the MXM slot back to life 😄 when will work out, will start the 7720 upgrade thread.... bcs the 2666MHz C15 mem arrived too, n watching a 2933 kit, maybe will take it n give a try, would be fab when it works. 1 Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9060 XT 16GB @ 4GHz boost 2850MHz vram - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro 7720 - i7-7820HQ - 2x 16GB 2666 C15 - P5200 16GB - Samsung 960 Pro 512GB NVMe + WD SN730 1TB NVMe - Wifi 6E - Win 11 Pro M6800 - i7-4930MX - 4x4GB 2133 C11 - GTX 880M 8GB(not working atm😒) - Kioxa BG5 1TB mPCIe - 2x Samsung 850 Evo 250GB Raid0 - Wifi 6 - Win 11 Pro
Annihilator Posted February 26 Author Posted February 26 ok, just noticed even USB ports doesnt work anymore, so think board is broken, just ordered new one... this means a bit of time for the 7720 and my old imac 12.2(27" mid 2011) want try a 3770 will work in it n putting the GTX 880M in it(3 heatpipe heatsink i have here since yrs)😇 Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9060 XT 16GB @ 4GHz boost 2850MHz vram - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro 7720 - i7-7820HQ - 2x 16GB 2666 C15 - P5200 16GB - Samsung 960 Pro 512GB NVMe + WD SN730 1TB NVMe - Wifi 6E - Win 11 Pro M6800 - i7-4930MX - 4x4GB 2133 C11 - GTX 880M 8GB(not working atm😒) - Kioxa BG5 1TB mPCIe - 2x Samsung 850 Evo 250GB Raid0 - Wifi 6 - Win 11 Pro
commanderf Posted March 2 Posted March 2 On 2/19/2026 at 12:51 PM, Annihilator said: i really would like to do a shunt mod on the M6800, bcs this 61W limit is annoying, temps around 70-72°c.(n not lapped the heatsink yet bcs was out of 1k n 1.2k sandpaper) full load so think still 20-30W more possible for the cooler before CPU start throttling. need to check when open next time what for VRMs on the mainboard n how many amps they can deliver. From the looks of it, these boards have 3 VRMs but spots for six.. referencing a boardview of the LVDS version of the mobo, the spots are in pairs of two, so two next to each other will feed into the same coil and cap because of how the board is wired, so it does seem possible to solder in more VRM's if your oc is pushing the stock ones real close to what they're rated for, but I'd check the pinouts of those pads manually before soldering HP Z8 G4 - 2x Xeon 6240, 32GB ddr4 ecc, evga 2070 super Precision m6800 - I7 4910MQ, 24gb ddr3, K3100M Backup pc- Thermaltake lvl 10 gt snow, asus m5a99fx r2.0, fx8350, gtx 670, thermaltake toughpower gold 1200w, evga 240mm aio, 8GB ddr3
Annihilator Posted March 2 Author Posted March 2 6 hours ago, commanderf said: From the looks of it, these boards have 3 VRMs but spots for six.. referencing a boardview of the LVDS version of the mobo, the spots are in pairs of two, so two next to each other will feed into the same coil and cap because of how the board is wired, so it does seem possible to solder in more VRM's if your oc is pushing the stock ones real close to what they're rated for, but I'd check the pinouts of those pads manually before soldering yeah i noticed that, would be interesting the VRM controller can handle 6 phases or they "only" get doubled then, even doubled is ok, bcs less thermical stress and sadly the 3770 wont work in the imac, its a shame from apple they not did not upgraded the EFI to support 3rd gen CPUs... n the 880M even wont work, so all back to normal(2600 + the old AMD card). Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9060 XT 16GB @ 4GHz boost 2850MHz vram - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro 7720 - i7-7820HQ - 2x 16GB 2666 C15 - P5200 16GB - Samsung 960 Pro 512GB NVMe + WD SN730 1TB NVMe - Wifi 6E - Win 11 Pro M6800 - i7-4930MX - 4x4GB 2133 C11 - GTX 880M 8GB(not working atm😒) - Kioxa BG5 1TB mPCIe - 2x Samsung 850 Evo 250GB Raid0 - Wifi 6 - Win 11 Pro
