kiemsigh Posted January 28 Posted January 28 I have a Clevo P775TM1 laptop with a 4K display and the following specifications: 1/ Display: 4K resolution, 60Hz 2/ CPU: Intel Core i9-9900K (full box, diamond packaging) 3/ GPU: RTX2080 8GB 150W 4/ RAM: Samsung 16GB x 4, 2666MHz 5/ Hard Drives: - Samsung 980 256GB - Samsung 970 Pro 512GB - Samsung SM843TN MZ7WD480HCGM 480GB SATA SSD - Samsung SSD PM897 MZ7L3960HBLT-00A07 960GB SATA 6Gb/s 6/ Cooling System: Water cooling Will this configuration be outdated by 2026? I can still play AAA games well at high graphics settings. Does anyone still use it? Please share your experience with me. Clevo P870DM3-G i9-9900K-32.0GB 2666MHz-GTX 1080 SLI-UHD60Hz Clevo P775TM1-G i9-9900KS-32.0GB 2666MHz-RTX 2080- UHD60Hz Clevo P775DM3-G i7-8700K-32.0GB 2666MHz-GTX 1080- FHD75Hz Dell Latitude 7430
Spacoom Posted January 28 Posted January 28 I am using Clevo P775TM1 but about to replace it. It works just fine for me I had to replace keyboard and CMOS battery over the years but its fine otherwise. I wish I could just buy new laptop like that but with modern processor, graphic card and slightly better screen resolution. Great model. 1
kiemsigh Posted January 28 Author Posted January 28 13 minutes ago, Maro97 said: CLEVO P870TM with official air cooling system The performance difference between the 2080 and the 3080 is really significant. The P870 is still great. 1 Clevo P870DM3-G i9-9900K-32.0GB 2666MHz-GTX 1080 SLI-UHD60Hz Clevo P775TM1-G i9-9900KS-32.0GB 2666MHz-RTX 2080- UHD60Hz Clevo P775DM3-G i7-8700K-32.0GB 2666MHz-GTX 1080- FHD75Hz Dell Latitude 7430
Maro97 Posted January 28 Posted January 28 YES … P870TM is the greatest DTR ever made and @Developer79working to use a desktop GPU in the laptop by an mxm adapter 1 1
kiemsigh Posted January 29 Author Posted January 29 9 hours ago, Maro97 said: YES … P870TM is the greatest DTR ever made and @Developer79working to use a desktop GPU in the laptop by an mxm adapter With water cooling on the Clevo P775. Performance test results: 100% CPU usage on the 9900K with a maximum temperature of 70°C. Very impressive. Clevo P870DM3-G i9-9900K-32.0GB 2666MHz-GTX 1080 SLI-UHD60Hz Clevo P775TM1-G i9-9900KS-32.0GB 2666MHz-RTX 2080- UHD60Hz Clevo P775DM3-G i7-8700K-32.0GB 2666MHz-GTX 1080- FHD75Hz Dell Latitude 7430
SamSTG44 Posted January 29 Posted January 29 To answer the question we need an extensive test or at lest collections of users tests data and compare it with newer latest DTR'ish laptops cpu/gpus the main obvious change it's the weight 1
kiemsigh Posted January 29 Author Posted January 29 7 hours ago, Maro97 said: What is the cpu frequency ? This is the result of the CPU performance test. Clevo P870DM3-G i9-9900K-32.0GB 2666MHz-GTX 1080 SLI-UHD60Hz Clevo P775TM1-G i9-9900KS-32.0GB 2666MHz-RTX 2080- UHD60Hz Clevo P775DM3-G i7-8700K-32.0GB 2666MHz-GTX 1080- FHD75Hz Dell Latitude 7430
Maro97 Posted January 30 Posted January 30 What is that broooo i thought you OC the cpu to 5.1 or 5.2 ghz on all cores with your water cooling system
