Sebastian Ramirez Posted March 6 Posted March 6 Hi, my Alienware fans dont work on their own so I had to setup HWINFO64 I just want to make sure the gtx1070 gets cooled properly, the gpu never gets hot right after turning on the laptop right? (because when setting up HWINFO64, I think it only starts the fans and cools the gpu when windows boots, not when pressing the power button of the laptop) Thx
TruenoG7 Posted March 7 Posted March 7 It is most likely that it is not making good contact with the GPU chip. This could be due to using thermal pads that are too large for the GPU, although it is a hot GPU it should not get so hot in the first few seconds of power-up. ---Dell Precision M6700---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS. ---Dell Precision M6800---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS. ---Alienware M17x R2--, I7-940MX, HD 8970M Crossfire, M6100/HD 8950M, GTX 765M, 1920x1200P OC 75 Hzt. ---Alienware 17-- i7-4940MX, RTX 3000(LVDS),P3000, GTX 980M, 880M,860M, M6100/HD 8950M, 1080P, 120 Hz, 3D. --Alienware 18-- i7-4930MX, 32GB RAM 1866 MHz, RTX 4000, RTX 3000, P3000, M6100/HD 8950M, 1920x1080P. LCDOC 75 Hzt. (In use). ---Alienware M18x R2- i7-3940XM, 32GB RAM 1866 MHz, GTX 980M SLI, 1920x1080p 6bits OC 75 Hzt. Youtube Channel : https://www.youtube.com/channel/UCi0b4otJZHtUJePgIejiI4Q.
zerokool Posted March 18 Posted March 18 On 3/9/2026 at 7:21 AM, Sebastian Ramirez said: Ok thx Do you have the dell support assistant app installed ? If so . Uninstall that it breaks fan control
