Hello, I want to repaste my Zephyrus Duo 16 (2023). I already bought Counductonaut Extreme, PTM7950 and TG Putty Pro. But while searching some info on reddit, I found out that Asus Zephyrus laptops have very small gaps between heatsink and cram, mosfets, vrm chips - lower 0.2 mm. For this reason high-end thermal putty like TG Putty Pro may not be suitable in my Zephyrus Duo because it has large particles. I also checked Snark Domain channel (thermal putty tester), he said TG Putty Pro can be pressed up to 0.48 mm in practice. Thermal Grizzly web site says the lower gap is 0.2 mm. I.m a little confused. Since I already purchaed TG Putty Pro I wanted to ask here users who already repasted, tested different putty in their laptops, maybe in my model. Is it OK to use TG Putty Pro in Zephyrus Duo 16 for good contact between heatsink and CPU, GPU chips? If not, what thermal putty you can recommend? Thanks!
maybe will help:
TG Putty Basic, TG Putty Advance and TG Putty Pro from Thermal Grizzly put to the test - from usable to absolute top class, even in your wallet | igor´sLAB
u can see at page 3, it starts at around 120µm(= 0.12mm) at the "Thermal Resistance Rth in cm²K/W" diagram
Phantom Gaming ITX B550 - 5950X @ 5.3GHz PBO - 2x16GB @ 3700 C14 - 9070 XT 16GB - 2TB + 1TB NVMe - 2TB + 2x1TB SATA SSD - Win 11 Pro
