amirhesamsadeghpour Posted 3 hours ago Posted 3 hours ago Alienware Area-51m R1 – i9-9900K All-Core Overclock to 5385 MHz with Stock Cooling! --- CPU-Z Validation: https://valid.x86.fr/ba5b0f The Achievement: I managed to overclock all 8 cores of the Intel Core i9-9900K (desktop CPU) inside my Alienware Area-51m R1 laptop to 5385 MHz – and it’s validated by CPU-Z. What makes this special is that it was done using the stock cooling system (no liquid metal, no physical cooler mods). System Specs: · Laptop: Alienware Area-51m R1 · CPU: Intel Core i9-9900K (8C/16T) · Motherboard: Z390 chipset (Alienware custom) · Cooling: Factory stock cooler (dual fans, vapor chamber) · RAM: 128GB (4×32GB) · Vcore: 1.368 V (as recorded in validation) · Multiplier: 54× · BCLK: 99.76 MHz How It Was Done: · Multiplier set to 54× · BCLK increased to 99.76 MHz · Vcore manually adjusted to ~1.34–1.37 V · Maximum power limits unlocked · Alienware Command Center set to “Performance” fan profile All settings were applied via BIOS and Intel XTU. No hardware modification was made to the cooling system. Why This Matters: · Most laptops with the i9-9900K struggle to maintain 5.0 GHz on all cores, let alone 5.385 GHz. · Achieving this on stock cooling proves how capable the Area-51m’s thermal solution really is. · The CPU-Z validation provides a verifiable proof of the all-core frequency. Stability & Temperatures: This was a validation run – the system was stable long enough to complete the CPU-Z validation and a short Cinebench R23 run. Under full load, core temperatures quickly hit 95+°C and thermal throttling kicked in. This configuration is not recommended for daily use or long gaming sessions; it’s purely a benchmark / personal record. Final Thoughts: The Alienware Area-51m R1 remains a legendary laptop that can still surprise with its overclocking headroom. Achieving a 5.385 GHz all-core overclock on factory cooling is a testament to its robust design. If you own one, carefully push its limits – but keep an eye on thermals! --- Validation link again: https://valid.x86.fr/ba5b0f --- Alienware Area-51m R1 – i9-9900K all-core overclock to 5385 MHz on stock cooling! ✅ Validated by CPU-Z. 🔗 https://valid.x86.fr/ba5b0f #Alienware #Area51m #Overclocking #i9_9900K #CPUZ
