For those frustrated with the 2400MHz RAM limit on the Alienware Area-51M R1, I've found a way to bypass the restriction and overclock the memory up to 2933MHz. This guide will walk you through the process step by step.
‏# 🔧 Requirements
‏Before you begin, you should be familiar with BIOS modding tools. You’ll need:
 Intel CSME Tools (for BIOS backup – version 12)
 UEFI Tool
 IFR Extractor
 RU.EFI (for modifying BIOS variables)
 A bootable USB drive
💡 How to Boot with UEFI Shell:
‏* Rename ShellX64.efi to bootx64.efi. ‏* Place it in the /EFI/BOOT/ directory on a FAT32-formatted USB drive. ‏* (use rufus )
‏# 🛠 Step-by-Step Guide
‏# 1️⃣ Extracting BIOS Data
1️⃣ Open the extracted BIOS file using UEFI Tool.
2️⃣ Press CTRL+F, go to the Text tab, and search for CFG LOCK.
3️⃣ Once found, scroll down, click the option, and extract the PE32 file (Extract As-Is).
‏# 2️⃣ Extracting BIOS Variables
1️⃣ Run IFR Extractor as an administrator.
2️⃣ Extract the PE32 file as a text document.
3️⃣ Note down the variables needed for modification.
‏# 3️⃣ Modifying BIOS with RU.EFI
1️⃣ Create a bootable USB drive with RU.EFI.
2️⃣ Enter BIOS and disable Secure Boot. Set the USB as the boot device.
3️⃣ Reboot the system and boot from USB.
4️⃣ After booting from the USB, you will automatically enter UEFI Shell. Here, you need to enter RU.EFI.
5️⃣ To access RU.EFI, type the following command and press Enter:
‏    FS0:
‏This will give you access to the USB drive.
6️⃣ Then, enter the following command to launch RU.EFI:
‏    RU.EFI
‏Once inside RU.EFI, the main menu will appear, and you can access the BIOS settings.
‏# Main Commands in RU.EFI:
‏* ESC: Exit the menu ‏* ALT + =: Search BIOS settings ‏* CTRL + Page Down: Navigate through pages of settings ‏* CTRL + W: Save changes ‏* ALT + Q: Exit RU.EFI and reboot the system
‏# 4️⃣ Overclocking RAM Speed in BIOS
1️⃣ Press CTRL + Page Down until you find variable 0A00.
2️⃣ Locate the 0A63/0A64 variables, which control RAM speed.
‏Modify the following values for 2933MHz:
‏    0XA64 → 0B
‏    0XA63 → 75
 Standard setting for 2667MHz:
‏    0XA64 → 0A
‏    0XA63 → 6B
 Memory Profile:
‏    MEMORY PROFILE 0XA65 → 01
 Additional Overclocking:
‏    0X93F → 0B
💾 Save the settings:
‏✔ Press CTRL+W to save changes.
‏✔ Exit with ALT+Q (or Ctrl + Alt + Del).
‏✔ Re-enter BIOS and verify the changes.
‏# ⚠ Important Notes
 This method works on all BIOS versions:
1.0.1, 1.2, 1.9.3, 1.23, 1.24, 1.25, 1.26, 1.28, 1.3.2
 Best BIOS version for stability: 1.3.2
🔹 Fully compatible with 200W GPU vBIOS
🔹 No sudden FPS drops or thermal throttling
 BIOS Update Warning
‏* Disable automatic BIOS updates in BIOS settings if you plan to use an older BIOS version. ‏* If the BIOS updates automatically, your settings may reset, requiring you to redo the process.
💡 Startup Delay Note:
‏After applying these changes, your system may take 1 to 2 minutes to display anything upon restart—this is normal.
💡 Incompatibility Recovery:
‏* If the selected frequency is not compatible with your RAM and your system doesn’t display anything, don’t panic! ‏* Simply disconnect the battery and reset the BIOS to restore the default settings.
‏⚠ Caution:
 Do NOT modify other settings in RU.EFI unless you know what you’re doing.
 I’m simply sharing my experience, and I hope this helps!
‏# 🎯 Final Thoughts
‏This method unlocks the full potential of RAM on the Alienware Area-51M R1, breaking Dell’s artificial 2400MHz limit. If you need help, feel free to ask! 💬
‎‏. This is entirely at your own risk, and I take no responsibility for any issues that may arise. It is highly recommended that you back up your BIOS settings before making any changes and follow the steps carefully
