Hello everyone and Good day. I am an old user of Notebookcheck forums and been lurking on this forums for a long time and decided to make a new account here.
I would like to ask some questions regarding the Alienware 51m R2 Heatsink. My specs is i7-10700(non K),RTX 2060,32GB ram, 4TB NVME SSD running at Windows 11.
My current heatsink 0XXG6C vapor chamber has failed and does not cool the CPU down, temps at 100c trottling the CPU on gaming, idle at 95-98c. I visually checked it and found some discoloration and by checking the airflow, it does not transfer heat, only the GPU side can transfer heat. I would like to know if the 067X3P heatsink designed for GTX is compatible to my laptop or do I need the exact 0XXG6C heatsink for RTX. Any advice will be helpful.
Laptops
Alienware 51m R2 Intel i7-10700,RTX 2070 Super, 32GB RAM, 4TB Storage (Current Laptop)
Alienware 14 , i5-4200 16GB RAM, GTX 750m, 1TB Storage (Old laptop)
Alienware 13 , i5-5200u, 16GB RAM, GTX960m, 512GB Storage (Old laptop)
News: I decided to buy the exact heatsink at the same time upgrade my GPU from RTX 2060 to an RTX 2070 Super. All is ok now.
Laptops
