I plugged a thunderbolt Hub station on my Clevo p775 and p870 with RTX3080 and I got compatibility problem to connect external monitor via thunderbolt. the monitor are detected but can not be used (seems to be a handshake failure). I use a danske bios and try with fp++ and Unique Id and use the option DDI to TBT in the bios, NO LUCK...
After some research it seems that the thunderbolt firmware can be updated however there is NO way to found download link or info on the internet.
could some FOX could give us the link on the latest firmware and the update procedure for our CLEVO p775 and p870 (there is the version 18 it seems...)
We will keep that post to provide those precious firmware download links updated
THANKS
