ssj92 Posted March 18, 2025 Author Posted March 18, 2025 1 hour ago, SuperMG3 said: But why it causes freeze? Because of being a GeForce card? It's the vBIOS. Something with vBIOS causes issues. Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
SuperMG Posted March 18, 2025 Posted March 18, 2025 3 hours ago, ssj92 said: It's the vBIOS. Something with vBIOS causes issues. Okay. Maybe a Dell vbios would work on the 980M. On the 3080 it won't I guess.
panda_zzz Posted March 18, 2025 Posted March 18, 2025 On 3/17/2025 at 9:37 AM, ssj92 said: All DX12 titles are stuck at 60fps for some reason on 3080. To get past this, overclock the display to 75-80hz. I think the problem here is not the display but the fact that intel optimus is used - there are limits to iGPU. If intel optimus was more powerful, you might have more frames. I've seen this on an intel 4600 vs iris 5200 comparison
SuperMG Posted March 18, 2025 Posted March 18, 2025 2 hours ago, panda_zzz said: I think the problem here is not the display but the fact that intel optimus is used - there are limits to iGPU. If intel optimus was more powerful, you might have more frames. I've seen this on an intel 4600 vs iris 5200 comparison But overclocking to 75Hz, could make you go from 60 to 75, that's what he meant. Intel HD 4000/4600 are performing the same in terms of Optimus.
panda_zzz Posted March 19, 2025 Posted March 19, 2025 3 hours ago, SuperMG3 said: Intel HD 4000/4600 are performing the same in terms of Optimus. work the same way, but the limit is different, so it is likely that they can draw different numbers of frames.
ssj92 Posted March 19, 2025 Author Posted March 19, 2025 23 hours ago, panda_zzz said: I think the problem here is not the display but the fact that intel optimus is used - there are limits to iGPU. If intel optimus was more powerful, you might have more frames. I've seen this on an intel 4600 vs iris 5200 comparison The weird issue with SG mode on older laptops such as M18xR1 (HD 3000 iGPU) is there's no DX12 support on titles even with a GPU such as RTX 5000, which supports DX12. Even more interesting is, Optimus only works with older drivers such as 419.XX. All newer drivers the nVidia GPU is not being utilized even with registry mod, Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
panda_zzz Posted March 19, 2025 Posted March 19, 2025 36 minutes ago, ssj92 said: Even more interesting is, Optimus only works with older drivers such as 419.XX. All newer drivers the nVidia GPU is not being utilized even with registry mod, what laptop do you have this on? because i have optimus working quite well on relatively fresh drivers on m17x r4 and m4800 (something around 550 version i think).
ssj92 Posted March 19, 2025 Author Posted March 19, 2025 1 hour ago, panda_zzz said: what laptop do you have this on? because i have optimus working quite well on relatively fresh drivers on m17x r4 and m4800 (something around 550 version i think). M18xR1. Speicfically sandy bridge intel hd 3000 iGPU. I think Precision M6600 has same issues. Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
panda_zzz Posted March 19, 2025 Posted March 19, 2025 57 minutes ago, ssj92 said: M18xR1. Speicfically sandy bridge intel hd 3000 iGPU. I think Precision M6600 has same issues. Maybe, although it may be a problem with the graphics card itself. or the combination of the laptop architecture and the graphics card driver. for example on my m15x with gtx970m and windows 10 nvidia drivers newer than 390 I think did not want to work.
SuperMG Posted March 19, 2025 Posted March 19, 2025 Also. I found that 16GB DDR3 SODIMM sticks exist. What would happen if we do 4x16 in the M18X R2? Will it boot? Or is the chipset inside is limited to 32 only?
panda_zzz Posted March 20, 2025 Posted March 20, 2025 12 hours ago, SuperMG3 said: What would happen if we do 4x16 in the M18X R2? the laptop won't boot up properly. 16 gigabyte ddr3 so-dimm modules do not work on 3-5 generation intel processors
SuperMG Posted March 20, 2025 Posted March 20, 2025 53 minutes ago, panda_zzz said: the laptop won't boot up properly. 16 gigabyte ddr3 so-dimm modules do not work on 3-5 generation intel processors Okay. So the limit is 32GB then? What about X58/X79 laptops? 16GB Sodimm accepted? Because my Precision T5500 has 16GB dimms times 6 (X5520 chipset something)
panda_zzz Posted March 20, 2025 Posted March 20, 2025 4 hours ago, SuperMG3 said: Okay. So the limit is 32GB then? The general case since the 1st generation of Intel mobile i-processors is 8 gigabytes per one slot for a memory module. the differences are in the maximum frequencies of this memory. if the slots are soldered 4, then yes maximum 32 gigabytes. but there are quite a lot of pitfalls from manufacturers, so I described only ideal conditions.
SuperMG Posted March 20, 2025 Posted March 20, 2025 48 minutes ago, panda_zzz said: The general case since the 1st generation of Intel mobile i-processors is 8 gigabytes per one slot for a memory module. the differences are in the maximum frequencies of this memory. if the slots are soldered 4, then yes maximum 32 gigabytes. but there are quite a lot of pitfalls from manufacturers, so I described only ideal conditions. My laptop recognizes 6 RAM slots but only 3 are present. It's DDR3, triple channel. I can somehow get 32-48GB to work on this X58 laptop (first gen i7 980X). 16+8+8 or 16+16+16. No one tried it tho since the dimms go for 60-120€
panda_zzz Posted March 20, 2025 Posted March 20, 2025 2 hours ago, SuperMG3 said: No one tried it tho since the dimms go for 60-120€ even taking into account that your laptop has a desktop chipset it doesn't change much - the same 8 gigabytes per channel, in case of three-channel mode - 24 gigabytes maximum. https://www.intel.com/content/www/us/en/products/sku/47932/intel-core-i7980x-processor-extreme-edition-12m-cache-3-33-ghz-6-40-gts-intel-qpi/specifications.html if you want you can experiment, but as for me it's a waste of money and bios will not be able to cope with 16 gigabyte modules, just like later bios for 3rd and 4th generation.
SuperMG Posted March 20, 2025 Posted March 20, 2025 11 minutes ago, panda_zzz said: even taking into account that your laptop has a desktop chipset it doesn't change much - the same 8 gigabytes per channel, in case of three-channel mode - 24 gigabytes maximum. https://www.intel.com/content/www/us/en/products/sku/47932/intel-core-i7980x-processor-extreme-edition-12m-cache-3-33-ghz-6-40-gts-intel-qpi/specifications.html if you want you can experiment, but as for me it's a waste of money and bios will not be able to cope with 16 gigabyte modules, just like later bios for 3rd and 4th generation. I said i7 980X because it's similar to the Xeon W3680. I have a Xeon.
SuperMG Posted March 20, 2025 Posted March 20, 2025 5 minutes ago, SuperMG3 said: I said i7 980X because it's similar to the Xeon W3680. I have a Xeon. https://forums.macrumors.com/threads/max-ram-in-2009-12-single-core-is-actually-56gb-w-w-xeon-and-64gb-w-x.1732968/ I guess 48GB is the max for me for the same CPU.
SuperMG Posted March 20, 2025 Posted March 20, 2025 I sent my RTX 3080 MXM to repair. I paid for the shipping. I'll probably wait 3-4 weeks until it's on my hand again bruh... I also found a very cheap 16GB SODIMM DDR3L stick for 28€ in China (how) and also 2x8GB DDR3L for 14€...
panda_zzz Posted March 20, 2025 Posted March 20, 2025 47 minutes ago, SuperMG3 said: I guess 48GB is the max for me for the same CPU. If you have 6 slots soldered into your laptop, it could be 48, but I think you said 3.
SuperMG Posted March 20, 2025 Posted March 20, 2025 40 minutes ago, panda_zzz said: If you have 6 slots soldered into your laptop, it could be 48, but I think you said 3. The system detects 6 slots on CPU-Z but it only has 3 physical. I also sent a link about the W3680/W3690 CPUs supporting up to 48/56GB. Sad that the Alienware M18X R2 doesn't even support 48GB...
panda_zzz Posted March 21, 2025 Posted March 21, 2025 4 hours ago, SuperMG3 said: The system detects 6 slots on CPU-Z but it only has 3 physical then there's no point in talking about 48 gigabytes 4 hours ago, SuperMG3 said: Sad that the Alienware M18X R2 doesn't even support 48GB... it's a CPU+chipset problem. and actually 32 gigabytes is still enough
ssj92 Posted March 21, 2025 Author Posted March 21, 2025 On 3/19/2025 at 3:45 PM, panda_zzz said: Maybe, although it may be a problem with the graphics card itself. or the combination of the laptop architecture and the graphics card driver. for example on my m15x with gtx970m and windows 10 nvidia drivers newer than 390 I think did not want to work. It's definitely a driver issue. Before 419.xx all gpus I tested work fine, but no dx12 mode. My m15x has 980M with latest driver. Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
SuperMG Posted March 21, 2025 Posted March 21, 2025 22 minutes ago, ssj92 said: It's definitely a driver issue. Before 419.xx all gpus I tested work fine, but no dx12 mode. My m15x has 980M with latest driver. What if you use an other GPU instead of the intel HD 4000? Like Kepler based one for slot 1 and 980m for the second slot?
ssj92 Posted March 21, 2025 Author Posted March 21, 2025 39 minutes ago, SuperMG3 said: What if you use an other GPU instead of the intel HD 4000? Like Kepler based one for slot 1 and 980m for the second slot? I'm referring to ONLY using Intel HD 3000 (Sandy Bridge) in SG mode HD 4000+ works fine Dual GPUs in PEG (mix/match) works fine Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
SuperMG Posted March 21, 2025 Posted March 21, 2025 10 minutes ago, ssj92 said: I'm referring to ONLY using Intel HD 3000 (Sandy Bridge) in SG mode HD 4000+ works fine Dual GPUs in PEG (mix/match) works fine Oh yeah my bad. On my previous M17X R4 I was sometimes limited by 60fps on dx12 using RTX 3000 MXM
