emcze Posted June 30, 2024 Posted June 30, 2024 1 hour ago, jonv8944s said: It works fine on windows 10. I need to try donwgrade to win 10.... Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti
jonv8944s Posted June 30, 2024 Posted June 30, 2024 Yeah its working fine on windows 10. Been playing games for last 2 hours no problem. anyone have suggestions on any settings that I should change in invidia control panel? It seems to be offloading some work to the intel internal gpu, which cant be very good.
emcze Posted June 30, 2024 Posted June 30, 2024 I found problem. It is in Device Meneger / Software devices I have: nvidia platform controllers and framework - I have exclamation and error code 31 It is because I used DDU Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti
emcze Posted June 30, 2024 Posted June 30, 2024 I tried windows 10: Firestrike : with GPU temp: and CPU at 4,5ghz not bed with temps 1 Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti
olenbt Posted July 1, 2024 Posted July 1, 2024 On 1/22/2022 at 10:34 PM, ssj92 said: Hey everyone... im kinda way late on this, but do you know where we can get the shorter vers of green PCB that converts mxm to m.2? one on the right side.
jonv8944s Posted July 1, 2024 Posted July 1, 2024 9 hours ago, olenbt said: im kinda way late on this, but do you know where we can get the shorter vers of green PCB that converts mxm to m.2? one on the right side. Yes, EBAY of all places. You will see that same green card on ebay! I entertained getting it myself but with all the storage I already have and am NOT using, I thought it was overkill. But go to ebay and look up "mxm to nvme" and it will come up
jonv8944s Posted July 1, 2024 Posted July 1, 2024 15 hours ago, emcze said: I tried windows 10: Firestrike : with GPU temp: and CPU at 4,5ghz not bed with temps So are you going to go back to Windows 11? Also, I am not stable at 4.5ghz, I think I am just at 4.2ghz, any suggestions on settings? Are you doing anything with your RAM speeds?
olenbt Posted July 1, 2024 Posted July 1, 2024 26 minutes ago, jonv8944s said: Yes, EBAY of all places. You will see that same green card on ebay! I entertained getting it myself but with all the storage I already have and am NOT using, I thought it was overkill. But go to ebay and look up "mxm to nvme" and it will come up I did look around on alibaba/express and ebay but couldn't find anything similar, the black one I did find but I needed extra space for something else lol. edit: found a shorter black pcie one, good enough lol https://www.ebay.com/itm/364423634457
emcze Posted July 1, 2024 Posted July 1, 2024 32 minutes ago, jonv8944s said: So are you going to go back to Windows 11? I don't know. Still problem is with "Shadow of the Tomb Rider". After I used DDU on Win11 Tomb Rider crashed. Now on clean Win10 still the same, and still code 31 on Device Meneger / Software devices/ Nvidia platform controllers and framework. Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti
aldarxt Posted July 1, 2024 Posted July 1, 2024 On 6/29/2024 at 6:55 PM, emcze said: I had the same. Your RTX3000 now is named 3D Video Controller. What you need to do: Download file nv_dispwi.inf - I uploaded it few post earlier. Click right button on It and click install on menu. After "Driver was installed succesfull" go to the Device Meneger and click on 3D Video Display. Click update driver and use update nanualy from driver installed in system. Click Graphic Card after that Nvidia after that Quadro RTX3000. Will be information that this driver can be not correct for this device but click update. Now your 3D Video display will be RTX3000. Also Disable Driver Signature Enforcement in advanced start-up Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4
jonv8944s Posted July 1, 2024 Posted July 1, 2024 Yeah I did all that and my kid played Fortnite for 2 hours straight with no crashing. So I feel confident I’m stable on win 10 with the previously defined steps to getting the RTX 3000 to work.
emcze Posted July 7, 2024 Posted July 7, 2024 On 6/29/2024 at 7:42 PM, jonv8944s said: Are these temps too high?! Ugh 😩 I checked my system with the same resolution as your. After the same time I have lover few degrees temp but higher FPS - 67 to 80 Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti
emcze Posted July 7, 2024 Posted July 7, 2024 I don't like Win10. i back to the Windows 11 with clean install. I know why 3DMark was crashed. Now working fine: Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti
emcze Posted July 11, 2024 Posted July 11, 2024 I use GPU TWEAK III and my GPU clock goes from 1890 to 1920 MHz, it gives me few FireStrike point 2 Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti
ssj92 Posted July 13, 2024 Author Posted July 13, 2024 Sorry I've been busy, let me make some suggestions here.. Windows 11 works fine BUT you must turn off gpu hardware scheduling or you will get BSODs (located in windows settings app). Instead of wasting time manually editing the INF, use nvcleaninstall to make the driver. It works perfectly and is easy to use. You can use the latest drivers no problem. 4 Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
emcze Posted July 15, 2024 Posted July 15, 2024 On 7/13/2024 at 10:45 PM, ssj92 said: Windows 11 works fine BUT you must turn off gpu hardware scheduling or you will get BSODs (located in windows settings app). It's changed nothing. Still the same behavior. When I started some game is like a wheel of fortune. Sometimes start and is playable, sometimes crashed, sometimes BSOD or OrangeSOD 🙂 But if Cyberpunk 2077 started... I play with Raytraceing on middle with 55fps. Looks great but... I started 35 times and played 2 times 😞 The same with Shadow of The Tomb Rider and other. Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti
emcze Posted July 16, 2024 Posted July 16, 2024 @ssj92 I solved my problem, I don't want double posts... here is full thread : Now I can run 3DMark Raytracing Benchmarks 🙂 1 Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti
Maks0098 Posted July 16, 2024 Posted July 16, 2024 6 minutes ago, emcze said: Now I can run 3DMark Raytracing Benchmarks 🙂 why does your processor frequency jump so much?? and do you have vertical sync enabled in the NVIDIA control panel or maybe limit the maximum frame rate to 60? Why is your result so not high and the fps is exactly 60 fps? Alienware M18x R2: i7-3920XM @4.7 GHz / 24GB DDR3-2133@CL11 / Tesla P6 upgraded from: GTX 1070 Oc`d, Quadro P4000 Oc`d, Tesla M6 Oc`d Alienware M18x R2: i7-3720QM / 16GB DDR3L-1600 / Firepro M6100 Clevo P751TM: i7-7700K / 16GB DDR4-2400 / GTX 1080 In past lives: Alienware 17 R1: i7-4710MQ / 16GB DDR3L-1600 / Quadro M3000M
emcze Posted July 16, 2024 Posted July 16, 2024 1 hour ago, Maks0098 said: why does your processor frequency jump so much?? need to check 1 hour ago, Maks0098 said: and do you have vertical sync enabled in the NVIDIA control panel or maybe limit the maximum frame rate to 60? I had vsync enabled 1 hour ago, Maks0098 said: Why is your result so not high I don't know because I run this benchmark few time and always was the same 15770 Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti
emcze Posted July 17, 2024 Posted July 17, 2024 I changed vsync to off but only 1 time had normal fps and CU flat line. EDIT I checked it in Fallout NewVegas and the same problem, V-sync always on ... 1 Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti
Maks0098 Posted July 17, 2024 Posted July 17, 2024 9 hours ago, emcze said: I had vsync enabled I think you need to disable Vsync or set "use 3D application settings" in NVIDIA control panel. and your result is the same, since you have 60 fps maximum due to the 60 Hz screen if vertical sync is always enabled. when you turn off vertical sync, fps will be able to reach the maximum. For gaming and general regular use, it is better to enable vertical sync everywhere, as it will give a smooth image and less load on the video card and processor if your laptop can produce more than 60 fps in a particular game. but the test will show the results below as you can see. Alienware M18x R2: i7-3920XM @4.7 GHz / 24GB DDR3-2133@CL11 / Tesla P6 upgraded from: GTX 1070 Oc`d, Quadro P4000 Oc`d, Tesla M6 Oc`d Alienware M18x R2: i7-3720QM / 16GB DDR3L-1600 / Firepro M6100 Clevo P751TM: i7-7700K / 16GB DDR4-2400 / GTX 1080 In past lives: Alienware 17 R1: i7-4710MQ / 16GB DDR3L-1600 / Quadro M3000M
emcze Posted July 17, 2024 Posted July 17, 2024 2 hours ago, Maks0098 said: I think you need to disable Vsync or set "use 3D application settings" in NVIDIA control panel. and your result is the same, since you have 60 fps maximum due to the 60 Hz screen if vertical sync is always enabled. when you turn off vertical sync, fps will be able to reach the maximum. I tried all settings. Always off, depend of app request, fast. This benchmark always cut to 59.9 FPS and play with CPU. I turned of GPU Tweek, disabled overclocking. Still the same with FPS and CPU. Only once I had more FPS and CPU line was flat. Don't know why. Expeditions Mud Runner and Metro Exodus if I disabled vsync give me more than 60 FPS. 1 Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti
emcze Posted August 7, 2024 Posted August 7, 2024 In weekend I will try P5000M 16GB and compare with RTX3000 Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti
emcze Posted August 16, 2024 Posted August 16, 2024 I'm in hostpital away from Alienware but I'm curious : Someone tried Black Myth: Wukong Benchmark Tool on Alienware M17x or M18x with RTX 3000?? https://store.steampowered.com/app/3132990/Black_Myth_Wukong_Benchmark_Tool/ 😁 Is It possible with our Intel i5 / i7 ? Alienware M18X R2 - i7-3940XM@4.5Ghz - Quadro RTX 3000 Alienware M17X R4 - i7-3740QM - Quadro P4000 Alienware M17X R4 - i7-3610QM - Quadro P4000 Alienware 13 R3 - i7-7700HQ - GTX 1050Ti
jonv8944s Posted September 3, 2024 Posted September 3, 2024 Because I cant leave well enough alone... lol... I did a fresh install of windows 11 (previously was on Win10), and I cant seem to get my system to agree that my RTX 3000 is fine. How do I fix this? Previously it had no drivers and was being called some "3D video" or something, so I did the old method on here of taking that .inf file and dropping it in the NVIDIA install directory while installing the newest drivers. I thought it was fine, until I see that explanation point next to the NVIDIA Quadro RTX 3000 adapter. If you are feeling generous, also share how I can fix some of the 'Other devices' section which show issues too?
