Working more on the M17x R2, I recently attempted a GPU upgrade from 660m > 770m. The 770 is much stronger and actually fits the heatsink. It cools itself well and native fan curve seem so to work. However, unless I disable HD audio in bios, the laptop screen ends up locked at one color immediately after windows boot. While disabling audio completely fixes this, I need the audio to work. Anyone have any ideas? I've considered a USB audio card, but I only want to try one If I know I can't get the internal one running, as well as I know that that will actually work.
Daily Drivers:
JANKTOP IV Mini-ITX Laptop - R5 2600X, 16gb DDR4 3000 Mhz, RX 5700 XT - (ONGOING)
Claymore V2 Cyberdeck, 6900HX, 680m iGPU, 16gb DDR5, 185 Wh Battery
14 R1 - 4710MQ @ 3.6 Ghz, hd 4600, 12gb DDR3L 1600 Mhz
Past Projects:
15 R3 - GTX 1060 6gb, i7 7700HQ, 16gb DDR4
17 R4 - RX 470 8gb i7 6700HQ, 16gb DDR4
M17x R4 - 3630QM, Quadro P4000, 16gb DDR3L 1600 Mhz
M17x R2 - i7 920XM @ 3.4 Ghz, GTX 770m 2gb, 16gb DDR3
UPDATE:
I figured out exactly what causes the issue, the 7-800 series cards use a wierd "hybrid vbios" That causes them to take up extra/different pcie lanes. Unfortunately, the sound card occupies one of those pcie lanes, so if both components are running at the same time they CAN NOT coexist. However, a cheap express card sound card I got on Ebay for $30 USD allows sound to be restored, while driving the 770m, which is also cooled properly in the R2 chassis without a shim.
Daily Drivers:
Past Projects:
On 6/14/2022 at 10:25 AM, StripeySnake said:
UPDATE:
I think there was a post on NBR that talked about drivers without IRQ issues. Idk where it went, somewhere on the archive. It may help solve these sound issues.
There was a fix on TechInferno for this issue with the M17x R3. There were a number of steps to do in the right order to get it working again
Can't seem to find the thread right now
