Yesterday my AW 14 started randomly freezing for several seconds, and repeating the same chunk of sound, as though it was hard crashing. However, it would recover within 10 or so seconds. This was really worrying me till I learned my friend's M17x R4 started having the same issue at the same time!
Long story short, Dell just released an update to SupportAssist on Jun 23 that is unstable, at least on older machines.
Here's how to fix it:
1: Open task scheduler
2: Locate SupportAssist task
3: Disable it
Next, open Services
1: Scroll down to the Dell Services
2: Right click on all the services beginning with "Dell" and click disable, one by one.
Restart your computer, and it should work fine again!
EDIT: I've now done this with four machines, 2 have been fixed, one still has less bad issues, and one reinstalled supportassist. I'm going to try and fix the last too, I'll get back to you if I find a way to fix that.
Known affected models:
M17x R4
M17x R5
15 R3
14 R1
Daily Drivers:
JANKTOP IV Mini-ITX Laptop - R5 2600X, 16gb DDR4 3000 Mhz, RX 5700 XT - (ONGOING)
Claymore V2 Cyberdeck, 6900HX, 680m iGPU, 16gb DDR5, 185 Wh Battery
14 R1 - 4710MQ @ 3.6 Ghz, hd 4600, 12gb DDR3L 1600 Mhz
Past Projects:
15 R3 - GTX 1060 6gb, i7 7700HQ, 16gb DDR4
17 R4 - RX 470 8gb i7 6700HQ, 16gb DDR4
M17x R4 - 3630QM, Quadro P4000, 16gb DDR3L 1600 Mhz
M17x R2 - i7 920XM @ 3.4 Ghz, GTX 770m 2gb, 16gb DDR3
thanks for sharing , actually i have been there with the m18xr1 and same thing happened with me 3 years back and since then i don't use these two apps anymore with the older machines
Alienware M18X R1, i7 2960XM @ 4.4Ghz, Nvidia GTX 880M SLI , 32GB RAM , samsung 840pro + samsung 860evo ( THE BEST I EVER HAVE)
Alienware Area-51M R1, i9 9900K @ 5.1Ghz, Nvidia RTX 2080, 64GB RAM, samsung 980 Pro( LOVELY MACHINE WITH BAD BIOS )
Alienware M18 R2, i9 14900HX @ 5.2Ghz, Nvidia RTX 4090, 64GB RAM, 4TB SSD  (MY current )
Alienware 18 , I7 4930MX @ 4.2Ghz , GTX 980M SLI, 32GB RAM ( MAY REST IN PEACE)   (SOLD)
  • 2 months later...
3: Disable it
Next, open Services
M17x R4
M17x R5
15 R3
14 R1
I was able to fix the problem by uninstalling Dell SupportAssist
I had that problem in alienware 18 R3, 17 r1 (2015)
---Dell Precision M6700---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS.
---Dell Precision M6800---, i7-4900MQ, Tesla M6, M6100/HD 8950M, 1920x1080p 6bits LVDS.
---Alienware M17x R2--, I7-940MX, HD 8970M Crossfire, M6100/HD 8950M, GTX 765M, 1920x1200P OC 75 Hzt.
---Alienware 17-- i7-4940MX, RTX 3000(LVDS),P3000, GTX 980M, 880M,860M, M6100/HD 8950M,  1080P, 120 Hz, 3D.
--Alienware 18-- i7-4930MX, 32GB RAM 1866 MHz, RTX 4000, RTX 3000, P3000, M6100/HD 8950M, 1920x1080P. LCDOC 75 Hzt. (In use).
---Alienware M18x R2- i7-3940XM, 32GB RAM 1866 MHz, GTX 980M SLI, 1920x1080p 6bits OC 75 Hzt.
Youtube Channel : https://www.youtube.com/channel/UCi0b4otJZHtUJePgIejiI4Q.
  • 1 year later...
