Meaker Posted July 23, 2022 Posted July 23, 2022 It's not been fully beatified as this is just for home use. I've used my old DDC pump and res for the stand and the radiator blocked the original stand arm. The sensors are mostly redundant these days as the aquaero program now reads direct the GPU core and CPU core temps via a USB header to tune the fan profiles. It's a coolermaster stand with holes cut in through the steel for two 140mm fans with a loose grill and some backing material to help make it look neat. 4 4 1 1 Louqe Ghost S1 case (Top hat and bottom extension) Powercolor RX 9070 XT Reaper 16GB 32" MSI 4k 160HZ IPS display AMD Ryzen 7 7700 cooled via Thermalright 240mm AIO 48GB (2x24) DDR5 6000 CL36 Asus B650E-I motherboard 2TB T500 nvme SSD + 2TB SN770 nvme Corsair SF750 platinum SFX PSU
jaybee83 Posted July 24, 2022 Posted July 24, 2022 15 hours ago, Meaker said: It's not been fully beatified as this is just for home use. I've used my old DDC pump and res for the stand and the radiator blocked the original stand arm. The sensors are mostly redundant these days as the aquaero program now reads direct the GPU core and CPU core temps via a USB header to tune the fan profiles. It's a coolermaster stand with holes cut in through the steel for two 140mm fans with a loose grill and some backing material to help make it look neat. post some air vs water cooled temps and wattages. also, hows the 3070 running at 180W? what kind of an uptick vs stock wattage? 1 1 Mine: Hyperion "Titan God of Heat, Heavenly Light, Power" (2022-26) AMD Ryzen 9 9950X3D (delidded) / Asus ROG Crosshair X670E Extreme (Qualcomm QCNCM865 Wifi 7 Upgrade) / MSI Geforce RTX 5090 Suprim SOC / G.Skill Trident Z5 RGB DDR5-8000 2x24 GB / 4x Western Digital Black SN850P/X 8TB in 2x16TB RAID 0 / Arctic Liquid Freezer III Pro 420 (Push/Pull 6x Noctua NF-A14 IndustrialPPC-3000 exhaust) / Seasonic TX-1600 W Titanium / Phanteks NV9 MKII Black incl. Premium D-RGB Light Strips Kit (6x Arctic P14 Pro A-RGB black intake / 2x Arctic P14 Pro A-RGB black exhaust / 1x Arctic P14 Pro A-RGB black RAM cooling) / Samsung Odyssey Neo G8 32" 4K 240 Hz / Ducky One 3 Daybreak Fullsize Cherry MX Brown / Corsair M65 Ultra RGB / PDP Afterglow Wave Black / Beyerdynamic DT 770 Pro X Limited Edition My Lady's: Clevo NH55JNNQ "Alfred" (2022-26) Sharp LQ156M1JW03 FHD matte 15.6" IGZO 8 bit @248 Hz / Intel Core i5 12600 / Nvidia Geforce RTX 3070 Ti / Mushkin Redline DDR4-3200 2x32 GB / Samsung 970 Pro 1 TB / Samsung 870 QVO 8 TB / Intel AX201 WIFI 6+BT 5.2 / Win 11 Pro Phoenix Lite OS / 230 W PSU powered by Prema Mod!
Meaker Posted July 24, 2022 Author Posted July 24, 2022 2 hours ago, jaybee83 said: post some air vs water cooled temps and wattages. also, hows the 3070 running at 180W? what kind of an uptick vs stock wattage? Since my model obviously does not support the boosting function It was something around 120-130W. I've shunt modded it to get that power output increased and the clocks stay around 2Ghz now in heavier titles so it's a 400-500Mhz uplift. I've refined my shunt modding technique, I now immerse the end in liquid metal in a ball at the end of the syringe and then I pull it back. This leaves a skin of liquid metal that's extremely stable. 1 1 Louqe Ghost S1 case (Top hat and bottom extension) Powercolor RX 9070 XT Reaper 16GB 32" MSI 4k 160HZ IPS display AMD Ryzen 7 7700 cooled via Thermalright 240mm AIO 48GB (2x24) DDR5 6000 CL36 Asus B650E-I motherboard 2TB T500 nvme SSD + 2TB SN770 nvme Corsair SF750 platinum SFX PSU
jaybee83 Posted July 24, 2022 Posted July 24, 2022 5 hours ago, Meaker said: Since my model obviously does not support the boosting function It was something around 120-130W. I've shunt modded it to get that power output increased and the clocks stay around 2Ghz now in heavier titles so it's a 400-500Mhz uplift. I've refined my shunt modding technique, I now immerse the end in liquid metal in a ball at the end of the syringe and then I pull it back. This leaves a skin of liquid metal that's extremely stable. thats kool, so no risk of the underlying SMDs falling off the board due to the LM? 😅 1 Mine: Hyperion "Titan God of Heat, Heavenly Light, Power" (2022-26) AMD Ryzen 9 9950X3D (delidded) / Asus ROG Crosshair X670E Extreme (Qualcomm QCNCM865 Wifi 7 Upgrade) / MSI Geforce RTX 5090 Suprim SOC / G.Skill Trident Z5 RGB DDR5-8000 2x24 GB / 4x Western Digital Black SN850P/X 8TB in 2x16TB RAID 0 / Arctic Liquid Freezer III Pro 420 (Push/Pull 6x Noctua NF-A14 IndustrialPPC-3000 exhaust) / Seasonic TX-1600 W Titanium / Phanteks NV9 MKII Black incl. Premium D-RGB Light Strips Kit (6x Arctic P14 Pro A-RGB black intake / 2x Arctic P14 Pro A-RGB black exhaust / 1x Arctic P14 Pro A-RGB black RAM cooling) / Samsung Odyssey Neo G8 32" 4K 240 Hz / Ducky One 3 Daybreak Fullsize Cherry MX Brown / Corsair M65 Ultra RGB / PDP Afterglow Wave Black / Beyerdynamic DT 770 Pro X Limited Edition My Lady's: Clevo NH55JNNQ "Alfred" (2022-26) Sharp LQ156M1JW03 FHD matte 15.6" IGZO 8 bit @248 Hz / Intel Core i5 12600 / Nvidia Geforce RTX 3070 Ti / Mushkin Redline DDR4-3200 2x32 GB / Samsung 970 Pro 1 TB / Samsung 870 QVO 8 TB / Intel AX201 WIFI 6+BT 5.2 / Win 11 Pro Phoenix Lite OS / 230 W PSU powered by Prema Mod!
Meaker Posted July 24, 2022 Author Posted July 24, 2022 19 minutes ago, jaybee83 said: thats kool, so no risk of the underlying SMDs falling off the board due to the LM? 😅 Yeah no river of liquid metal, just a very thin film, widened out a little to get the resistance I want. I was lucky and judged it right first time. 2 Louqe Ghost S1 case (Top hat and bottom extension) Powercolor RX 9070 XT Reaper 16GB 32" MSI 4k 160HZ IPS display AMD Ryzen 7 7700 cooled via Thermalright 240mm AIO 48GB (2x24) DDR5 6000 CL36 Asus B650E-I motherboard 2TB T500 nvme SSD + 2TB SN770 nvme Corsair SF750 platinum SFX PSU
