Do you love Cmos resets first thing in the morning? Do you hate having to track down welded wire coin batteries and have to wait for them to arrive in the post? Well look no further!
Jokes aside 🙂 I dislike having to find these welded wire coin batteries online and having to wait weeks for it to arrive so for ease of use I made this mod.
No longer need to use these batteries:
Now you can use normal store bought coin batteries. 🙂
I had to break off one corner of the socket so it would fit and bend down the corner of the contact so the battery is perfectly held in. 🙂
Alienware M17 R1: i7-8750H | RTX 2070 Max-q | 144hz
Alienware M18x R2: i7-3740QM | RX 480 4GB
Alienware M17x R4: i7-3720QM | GTX 1060 6GB | 120Hz
Alienware Aurora R5: i7-6700K | GTX 1080 SLI | 64GB RAM
Alienware X51 R2: i7-4790 | ASUS GTX 1070 Turbo
do you sell these? i really dislike having to disconnect those fragile wires incase of a mishap with the switchable graphics and whatnot
Alienware M18X R2 | Nebula Red | i7 3740QM [OC'd to 4Ghz] | 32GB RAM | NVIDIA Quadro P4000 | 75hz OC'd Display |
MXM to NVMe Adapter with Samsung 970 Evo Plus 2TB
Alienware 17 R4 | i7 6700HQ | 16GB RAM | GTX 1070 | 100hz OC'd LG 1080p Display
Alienware M18X R1 | Space Black | i7 2960XM | 16GB RAM | GTX 780M
This is a pretty good idea! Did you just get some of the battery cradles from ebay?
So the m18x R2 gets ANOTHER Upgrade!!!
Really nice for any laptop
This battery holder is a savlage from a random dead laptop board I had around. 😄
It is a slimmer design than the usual holders you see on laptops, so it fit much easier.
I found a holder on ebay here that may fit but you will have to check the dimensions from the listing. Size looks ok?
https://www.ebay.com.au/itm/125049195078?hash=item1d1d834a46:g:9FUAAOSw7B9htq0B
I don't sell them sorry. 🙂
If you know how to solder or know someone that does, this holder has a ON/OFF switch! Not sure on size though as it may not fit well. 🙂
https://www.ebay.com.au/itm/313835425911?hash=item49120c9077:g:qIsAAOSwxr1fTgV0
yeah that might be a little too big, also it has 2 lots of + and - on them so not sure how that works in the grand scheme of things
i ordered the 1st holder you listed, i do plan on getting a soldering kit as ive also ordered the quirky butterstick keyboard. so its something ill get around to eventually xD thanks again for showing this tho, the thought never crossed my mind to do this
No worries. Let us know how it goes & post some pictures when it's complete. 🙂
will do 🙂
I like this mod.  Are you concerned at all about the exposed metal contacting something on the board/casing?
I don't own an M18x R2 anymore, but I think the M15x and M17x R4 have the same setup?
Lenovo Legion Pro 7i | 13900 HX | RTX 4090 | 32GB RAM | 2TB 990 Pro | 4TB WD SN850X | 240Hz
Thanks. 🙂 The chassis is made from some sort of cast metal that is conductive for grounding of the board, however the black paint on the bottom side is quite thick & Non-conductive so it would need to be scratched right down to the base to be conductive so it's very safe. 🙂
The M17x R4 has a socket on the board thankfully. But the M15x does use the spot welded wire ones also, like the M18x R2. 🙂
