aayyppxx Posted August 17, 2022 Posted August 17, 2022 Hello I had purchased my Clevo P775TM-1 with the RTX 2070 from Obsidian in early 2019. It seems they have since gone out of business. I wanted to do some basic maintenance on this laptop such as replace the thermal pads and thermal paste. I do clean the normal dust buildup in the vents every 4-6 months. I know you're supposed to avoid using liquid metal compounds to avoid it spilling out and creating a short. Would the Noctua NH-1 be a good candidate ? What thickness are the thermal pads supposed to be ? I haven't replaced them yet, so I'm worried they might have been compressed and measuring the thickness would yield the wrong size. There is some dust build-up in the speaker grille which doesnt go away when I tried to clean using normal methods such as air can, small vacuum, brushing or wet cloth wipes. Any help appreciated. Any other things I should keep an eye out for when I open it up ? The laptop runs fine, if a bit hotter and noisier. Cheers aayyppxx
joluke Posted August 28, 2022 Posted August 28, 2022 Got a P775DM3-G modified to use a dsanke bios and a 8700k with a RTX 2070. Anyway use a normal thermal paste like Thermal Grizzly Kryonaut and you should be good to go. It's easy to do the maintenance to it Clevo P775DM3-G modded with 8700k - 48GB DDR4 - AUO LCD at 144hz - 4xSSDs
DuongTHVn Posted November 20, 2022 Posted November 20, 2022 @joluke can you share link to the document of dsanke bios for P775DM3-G. thanks
runix18 Posted November 20, 2022 Posted November 20, 2022 36 minutes ago, DuongTHVn said: @joluke can you share link to the document of dsanke bios for P775DM3-G. thanks here you are: http://www.smxdiy.com/thread-3647-1-1.html 1 Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 9800X3D | 64GB Corsair Vengeance RGB DDR5 6000MHz CL30 Dual Channel Kit | MSI RTX 4070TI Suprim X | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 11 Enterprise x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64
ViktorV Posted November 20, 2022 Posted November 20, 2022 2 hours ago, DuongTHVn said: @joluke can you share link to the document of dsanke bios for P775DM3-G. thanks What version of Dsanke bios for p775dm2/3 do you need? Сlevo p870tm1-g 17.3 Fhd 300Hz i9-10980hk ES rtx3060. / Clevo x170smg 17.3 300Hz i9-10850k rtx2070super 32g ddr4 3200Mhz Gskill. / Clevo x170kmg 17.3 2k 165Hz i5-11600k rtx3080 32g ddr4 3200Mhz Hyper-X.
