Ishayin Posted September 7, 2022 Posted September 7, 2022 Has anyone found a good way of providing more manual control over the fans in Clevo laptops? E.g. has anyone managed to set up an NBFC profile for any of them before? https://github.com/hirschmann/nbfc https://github.com/hirschmann/nbfc/wiki/How-to-create-a-NBFC-config I would like to be able to set my fans off / as low as possible for just a short few minute bursts at a time while doing sensitive audio recording. The best way I can find currently is using the Custom fan speed profile in Control Center, though I find it to be a bit buggy (sometimes I cannot get the settings menu for it to close down again) and the highest fan start temperature it allows is 70 °C.
User Posted September 7, 2022 Posted September 7, 2022 Is this compatible with your machine? - https://github.com/djsubtronic/ClevoFanControl I have not actually used it, but Starred a while back with some interest. 1 PowerSpec 1720 (PB70EF-G) | i7-8750H | 32GB 3000MHz DDR4 | RTX 2070 8GB 115W | 144Hz G-SYNC Spoiler -163 mV core & cache | 15-18-18-36 1T @ 1.35V | 1905MHz @ .975mV & 1950MHz GDDR6 Disabled: TVB, VMX Stress, RDB, HDC Tuned with: ThrottleStop, MSi Afterburner | TIM: SYY 157 Insyde H2OUVE BIOS Unlock | CB R20 - 3172 | CB R23 - 8164/1105 | CPU Prof. Max - 4702
luisxd Posted September 7, 2022 Posted September 7, 2022 I use RLECViewer for custom fan curves. 1 1 CLEVO PT870TM1-G || i7 8700K || 32 GB 2400MHz || Nvidia GTX 1080 x 2 || 1440p @120HzHP ZBOOK 17 G3 || Xeon E3-1535M v5 || 16 GB 2400MHz || Nvidia Quadro GTX M5000M || 1080p @60HzDELL PRECISION M6400 || C2Q QX9300 || Nvidia Quadro FX3700M || 1200p @60Hz || RETIREDLG 27UK850-W || 2160p @60Hz || AMD FreesyncOC.net profile (luisxd)Heatware profile (luisxd)
Ishayin Posted September 8, 2022 Author Posted September 8, 2022 On 9/7/2022 at 5:03 PM, User said: Is this compatible with your machine? - https://github.com/djsubtronic/ClevoFanControl I have not actually used it, but Starred a while back with some interest. This is a great find thank you – I've just been trying it out now and it works! (on my P751ZM) The manual curve settings are saved in userfancurve.cfg which is just a text file with a list of the fan settings in order. This makes it simple to edit directly as an alternative to the GUI (e.g. I just draw in the settings for the CPU, and then copy and paste them to replicate them for the GPU directly in the file). It also means you can easily transfer settings elsewhere, or save different manual configurations and just swap out which one is used by renaming the file extension (though it would be handy if you could call these up in a quicker fashion). Also, despite what it says in the Readme, it does seem to hand over control again on exit rather than setting fans to 100% as stated there. It doesn't revert back to the last used setting in ControlCenter, but I think it's instead going back to "Automatic" in that, or some similar underlying system default. You need to toggle the settings back and forth again in ControlCenter to be sure it is back how you would like things there. I might even consider using ClevoFanControl as the default controller. There are a few little glitches but all minor: Editing either manual fan curve will give that curve control over the relevant fan no matter which profile is selected. The "Clevo Default" profile doesn't display the fan duty, and will simply display however they were last set by the previous profile. The context menu option for "About" does nothing. A few other points to note: NTPort library appeared to install fine for me without any error. I didn't try running the program without doing this first. The curves are not really curves in effect, but simply steps without any interpolation in between them (so would be more accurately displayed as a bar chart). The setting at any given temperature will be applied the same for the 5 degree interval from that temperature, up until the point where the next setting kicks in (e.g. the 40°C setting is applied from 40–44°C, 45°C setting from 45–49°C and so on). It first opens to just the system tray icon, and need to open the GUI window from there. Hitting the "X" to close at top right of window will leave it running in the background in the system tray, while hitting the "Exit" button will actually close it down and let go of control, same as exiting from the system tray context menu. I couldn't figure out what the "GPU Batt. Monitor" setting is supposed to do. Any ideas? I found there is also a similar program available from Obsidian which looks slightly fancier, but costs €40 €30: https://code.obsidian-pc.com/clevo-software/fan-control/ I also came across this, but apparently it can only control one fan: https://marqis.github.io/BtoFanControl/ On 9/7/2022 at 5:19 PM, luisxd said: I use RLECViewer for custom fan curves. Thanks for that too! There does seem to be some suspicion around this: https://github.com/zuyan9/RLECViewer/issues/4 I would have said it was mostly likely just false positives, though the comment about something trying to change UAC policy settings is a little worrying. It also advises to uninstall Clevo Control Center first which I'd rather keep. Anyway, there apparently was an old thread for it on NBR at : http://forum.notebookreview.com/threads/rlecviewer-custom-clevo-fan-control.818858/ So I don't know if anyone can locate that in the backup at nbrchive.net. And apparently this is the original source for it: https://tieba.baidu.com/p/4872453181 3
Tenoroon Posted September 15, 2022 Posted September 15, 2022 I can't get the NTPort driver to install properly, has anyone else had the same issue? Clevo P870TM-G: Core i7 8700k @ 4.8ghz | Clevo RTX 2070 Super | 32gb HyperX DDR4 @ 3200mhz | 17" 1440p 120hz B173QTN01.0 Screen | 256gb Samsung 850 EVO | 500gb WD Blue SSD | Prema BIOS Alienware 17 R1: Core i7 4710mq @ 3.619ghz 741 CBR15 (834 CBR15 @ 4.213ghz) | Dell GTX 860m | 16gb HyperX DDR3L @ 2133mhz | 17" 3D 120hz LTN173HT02-T01 Screen | 256gb mSATA SSD Asus Zephyrus G14: Ryzen 7 4800hs @ 4.2ghz | GTX 1650 | 16gb DDR4 @ 3200mhz | 14" 120hz LM140LF1F01 Screen | 512gb NVME SSD
runix18 Posted September 16, 2022 Posted September 16, 2022 16 hours ago, Tenoroon said: I can't get the NTPort driver to install properly, has anyone else had the same issue? It did not instal properly for me also, but even so, the app was running as intended. Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 9800X3D | 64GB Corsair Vengeance RGB DDR5 6000MHz CL30 Dual Channel Kit | MSI RTX 4070TI Suprim X | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 11 Enterprise x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64
Tenoroon Posted September 16, 2022 Posted September 16, 2022 10 hours ago, runix18 said: It did not instal properly for me also, but even so, the app was running as intended. I should have edited my post, I found the problem out. I had to uninstall CCC and some other weird drivers and it works now. I'm going to reinstall CCC to see if that will work. Clevo P870TM-G: Core i7 8700k @ 4.8ghz | Clevo RTX 2070 Super | 32gb HyperX DDR4 @ 3200mhz | 17" 1440p 120hz B173QTN01.0 Screen | 256gb Samsung 850 EVO | 500gb WD Blue SSD | Prema BIOS Alienware 17 R1: Core i7 4710mq @ 3.619ghz 741 CBR15 (834 CBR15 @ 4.213ghz) | Dell GTX 860m | 16gb HyperX DDR3L @ 2133mhz | 17" 3D 120hz LTN173HT02-T01 Screen | 256gb mSATA SSD Asus Zephyrus G14: Ryzen 7 4800hs @ 4.2ghz | GTX 1650 | 16gb DDR4 @ 3200mhz | 14" 120hz LM140LF1F01 Screen | 512gb NVME SSD
Ishayin Posted September 17, 2022 Author Posted September 17, 2022 On 9/15/2022 at 1:33 PM, Tenoroon said: I can't get the NTPort driver to install properly, has anyone else had the same issue? On 9/16/2022 at 5:50 AM, runix18 said: It did not instal properly for me also, but even so, the app was running as intended. Note from the Github page in case it is of relevance: Important Notes ... NTPort library might give you an error message during the installation, but this can be ignored as the driver will still be installed
Tenoroon Posted February 25, 2023 Posted February 25, 2023 I've noticed that Clevo Fan Control doesn't spin my 2nd GPU fan on my P870. Is there a hidden setting or another program that will allow me to control all 3 fans? Clevo P870TM-G: Core i7 8700k @ 4.8ghz | Clevo RTX 2070 Super | 32gb HyperX DDR4 @ 3200mhz | 17" 1440p 120hz B173QTN01.0 Screen | 256gb Samsung 850 EVO | 500gb WD Blue SSD | Prema BIOS Alienware 17 R1: Core i7 4710mq @ 3.619ghz 741 CBR15 (834 CBR15 @ 4.213ghz) | Dell GTX 860m | 16gb HyperX DDR3L @ 2133mhz | 17" 3D 120hz LTN173HT02-T01 Screen | 256gb mSATA SSD Asus Zephyrus G14: Ryzen 7 4800hs @ 4.2ghz | GTX 1650 | 16gb DDR4 @ 3200mhz | 14" 120hz LM140LF1F01 Screen | 512gb NVME SSD
Ishayin Posted March 24, 2023 Author Posted March 24, 2023 On 2/25/2023 at 9:59 PM, Tenoroon said: I've noticed that Clevo Fan Control doesn't spin my 2nd GPU fan on my P870. Is there a hidden setting or another program that will allow me to control all 3 fans? I guess not unfortunately if that means you have three fans in total: Important Notes 2 fans supported at the moment There is also an open issue about this here: https://github.com/djsubtronic/ClevoFanControl/issues/2 You could try chasing up on that. Though the project hasn't had any updates for a while so maybe it needs someone else to pick it up in the future (fingers crossed!)
1610ftw Posted March 5, 2024 Posted March 5, 2024 After several crashes suffered by using the worthless Clevo Control Center I had to again search for something different to control fans. So I have in the last weeks tested RLEC Viewer and Clevo Fan Control and I have settled on Clevo Fan Control: At first RLEC viewer seemed to have some advantages as it also supports three fans but I only need support for two and for me it has an annoying glitch where at least in my Clevo X170KM-G the fans go briefly down to zero when they ramp down from one temperature bracket speed to another. They would for example ramp down from the 60° to the 55° bracket and there was always an annoying clicking sound in between when the fans turned off and then on again. So for a two fan chassis I would definitely recommend Clevo Fan Control and use RLECViewer only if needed for Clevos with three fans as the third fan is not recognized by Clevo Fan Control in its current state. So far Clevo Fan Control also seems to work reliably and I always turn it on manually on powering up, same as Throttlestop. I have the program and my CPU and GPU temps (via Throttlestop) in the corner of my task bar to be able to check temps if needed (CPU power only as I am not much of a heavy GPU user): From left to right is: temp Nvidia GPU power uptake CPU temp CPU Fan Control symbol I also like the option to quickly ramp up fans to max or 50% if needed or to give control back to the Clevo Default, all via right click on the fan control signal.
DLoa Posted October 23, 2024 Posted October 23, 2024 Eurocom Sky X7c (Clevo P775TM1-G): CPU: Delidded i9-9900K @ 3.6GHz (direct die cooling with vacuum chamber mounted onto the unified cooling system, all with liquid metal), RAM: 64GB (4 x16Gb Kingston Technology HyperX Impact 2666MHz DDR4 CL15), Main Storage: m.2 Samsung SSD 990 PRO 2Tb with Windows 11 Pro 64bit (24H2) and Atlas-OS 0.41, Secondary Storage: 2 x stripped (Raid0) Seagate FireCuda 2TB Solid State Hybrid Drives Performance SSHD (ST2000LX001 - 1RG174) GPU: NVidia RTX 2080 8Gb GDDR6 (liquid metal).
rockmanx97 Posted April 1, 2025 Posted April 1, 2025 On 9/17/2022 at 1:29 PM, Ishayin said: Note from the Github page in case it is of relevance: Important Notes ... NTPort library might give you an error message during the installation, but this can be ignored as the driver will still be installed Anyone fix this, I can't install the NTPort library, I have uninstalled Clevo Control Center, the program can't detect my fans or temperature
rockmanx97 Posted April 1, 2025 Posted April 1, 2025 On 9/16/2022 at 9:27 AM, Tenoroon said: I should have edited my post, I found the problem out. I had to uninstall CCC and some other weird drivers and it works now. I'm going to reinstall CCC to see if that will work. What are those weird drivers you had to uninstall
Tenoroon Posted April 2, 2025 Posted April 2, 2025 22 hours ago, rockmanx97 said: What are those weird drivers you had to uninstall It's been a very long time, but I think it was some other Clevo drivers that were on my machine alongside some random drivers since the OS was originally installed and used on another computer. I personally use RLECviewer as it gets the job done, but the UI can be a bit janky and it can sometimes force the fans to 100% for a few seconds. It allows me to control all 3 fans though. Clevo P870TM-G: Core i7 8700k @ 4.8ghz | Clevo RTX 2070 Super | 32gb HyperX DDR4 @ 3200mhz | 17" 1440p 120hz B173QTN01.0 Screen | 256gb Samsung 850 EVO | 500gb WD Blue SSD | Prema BIOS Alienware 17 R1: Core i7 4710mq @ 3.619ghz 741 CBR15 (834 CBR15 @ 4.213ghz) | Dell GTX 860m | 16gb HyperX DDR3L @ 2133mhz | 17" 3D 120hz LTN173HT02-T01 Screen | 256gb mSATA SSD Asus Zephyrus G14: Ryzen 7 4800hs @ 4.2ghz | GTX 1650 | 16gb DDR4 @ 3200mhz | 14" 120hz LM140LF1F01 Screen | 512gb NVME SSD
rockmanx97 Posted April 2, 2025 Posted April 2, 2025 1 hour ago, Tenoroon said: It's been a very long time, but I think it was some other Clevo drivers that were on my machine alongside some random drivers since the OS was originally installed and used on another computer. I personally use RLECviewer as it gets the job done, but the UI can be a bit janky and it can sometimes force the fans to 100% for a few seconds. It allows me to control all 3 fans though. The NTPort Library Driver service failed to start due to the following error: NTPort Library Driver is not a valid Win32 application. Tried it I'm getting this error the Clevo Control Center is the only one that works for me
