I've always connected my precision laptop to U3014 monitor with mini-dp to DisplayPort cable.
The 7770 doesn't have a mini-displayport connection, but has both an HDMI port and USB-C ports.
I'm curious -- is the HDMI connection usable / advisable. A long, long, long time ago I thought I remember reading about the hdmi running off the intel gpu not the nvidia, or something like that, but that was long ago...
Also it looks like the U3014 is limited in resolution to 1080p with a direct hdmi connection -- would an hdmi to dvi-d cable work in this situation to drive the U3014 from the nvidia gpu at 2560 x 1600?
Or is USB-C to DP cable the (only) way to go?
Since the HDMI port is there on the 7770, I'm just curious if it's usable in my case and if it is worth anything to free up an additional USB-C port, and if an HDMI->DVI adapter cable would work better/worse/the same as the USB-C->DP adapter cable.
USB-C -> DP is the ideal setup, I'd say.  (USB-C can carry a DisplayPort signal.)
HDMI should be able to work off of either the iGPU or dGPU in this system.  In previous systems, the HDMI port was physically located right on the dGPU, but in this one it is actually on the motherboard.  That said, I haven't tried it yet to confirm...
Err, I'm confused... I've been using a U3014 for years with various Precision M6x00 machines via HDMI at 2560x1600 with no issues (using the nVidia card only; I turned off the Intel GPU).  I briefly tried it with my 7770 while waiting for a new monitor to show up and it worked fine too.  I tried using it via DP-to-mini-DP with my older Precision machines and hated it (the video looked awful compared to HDMI, no idea why).
I'm now using an U3023E USB-C hub monitor and the off-axis picture quality stinks, I like the U3014 better -- better off-axis viewing, better soundbar options, better matte screen finish.  I like all the connectivity of the U3023 tho, so I'm keeping them both...
Interesting. I thought that I had read that the hdmi input on the 3014 would only allow 1080 resolution, but maybe this was based on a previous generation like the 3011. I'll give it a try.
Thank you!
It works via HDMI.
A U3014 30" will display its native 2560x1600 resolution through the HDMI - HDMI cable.
An older U3011 30" monitor with native resolution of 2560x1600 will only allow setting resolution to 1920x1200 via the same HDMI - HDMI cable on the 7770 Display Properties.
