Maxware79 Posted January 25, 2022 Posted January 25, 2022 I've owned this R2 since 2012 and it has been through a number of changes and upgrades since then. Unfortunately the latest change was a downgrade from a GTX 1070 to the 970M. I have bought and sold more Alienware laptops than I can count but I don't think I'll ever let this one go. Currently running from a Samsung 970 Evo using an MXM to NVMe adapter in the secondary MXM slot. Resprayed in Delft Blue which shines in the light and goes a deep blue in low light. 4 4 1 Alienware Aurora R15 - i9-13900KF - RTX 4090 - 32GB DDR5 Alienware X51 - i7-3770 - GTX 1060 - 16GB 1600Mhz DDR3 Alienware M17x R3 - i7-2760QM - GTX 580M - 16GB 1600Mhz DDR3 Alienware Area 51 ALX - i7-975 Extreme - GTX 980 - 16GB 1600Mhz DDR3 Alienware Aurora R2 - i7-3770K - GTX 670FTW - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 1060 - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 670FTW - 16GB 1600Mhz DDR3
razor0601 Posted January 25, 2022 Posted January 25, 2022 Very nice R2. Why you downgraded to 970m? Schenker DTR 15(P751TM1) @Dsanke Bios, I7-8700, 32GB 2666MHz RAM, GTX 1060, 15,6“ 4K B156ZAN02.2 Display
AXA Posted January 26, 2022 Posted January 26, 2022 was gonna ask about the downgrade also, love the color. if i didnt have the nebula red color on mine id consider a custom color too. Perhaps you could put a p4000/5000 in there? Alienware M18X R2 | Nebula Red | i7 3740QM [OC'd to 4Ghz] | 32GB RAM | NVIDIA Quadro P4000 | 75hz OC'd Display | MXM to NVMe Adapter with Samsung 970 Evo Plus 2TB Alienware 17 R4 | i7 6700HQ | 16GB RAM | GTX 1070 | 100hz OC'd LG 1080p Display Alienware M18X R1 | Space Black | i7 2960XM | 16GB RAM | GTX 780M
Maxware79 Posted January 26, 2022 Author Posted January 26, 2022 I just wasn't using the 1070 and I needed some extra cash so it had to go. I had the 970M laying around so it just made sense. I really don't get to play games these days with work and family. 1 Alienware Aurora R15 - i9-13900KF - RTX 4090 - 32GB DDR5 Alienware X51 - i7-3770 - GTX 1060 - 16GB 1600Mhz DDR3 Alienware M17x R3 - i7-2760QM - GTX 580M - 16GB 1600Mhz DDR3 Alienware Area 51 ALX - i7-975 Extreme - GTX 980 - 16GB 1600Mhz DDR3 Alienware Aurora R2 - i7-3770K - GTX 670FTW - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 1060 - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 670FTW - 16GB 1600Mhz DDR3
Katja Posted January 26, 2022 Posted January 26, 2022 I'm now kind of curious how modular and costly the M18x is, given I'd like to have an inexpensive tinkering machine that can do some more intensive work (since my main machine is almost exclusively gaming-oriented). Kirisame: Custom build Ryzen 7 5800X 32GB HyperX DDR4-3733 CL18 ASRock Phantom D OC RX 6800XT 1TB Samsung OEM gen4 2TB Inland Platinum 2TB Seagate Barracuda HDD Huawei Matebook D14 i5-10210U 8GB DDR4 500GB NVME
Maxware79 Posted January 27, 2022 Author Posted January 27, 2022 It is an extremely modular laptop with just about every part being replaceable/upgradeable. @ssj92 has pushed it further than most of us with his Quadro RTX 3000 upgrade. There isn't a better 'tinkering machine' around, in my perfectly unbiased opinion..... They can be as cheap or as expensive as you want them to be. Back in 2013 I spend $2500 just upgrading the GPU's to dual 780M's and the CPU to a 3920XM. Seems crazy now. Buying a base model can still seem expensive because these systems now have the 'collectible' badge to them but you may be able to find one for around the $400 mark if it needs a little work. I usually sell my refurbished projects for around $1000-1100AUD ($700-800USD) which is a lot for a laptop with a 3rd gen processor and one or two 600 series mobile GPUs. You just have to remember that you're stuck with a 3rd gen mobile CPU so it's not going to keep up with todays processors although an overclocked i7-3920XM or 3940XM are still very capable units. Alienware Aurora R15 - i9-13900KF - RTX 4090 - 32GB DDR5 Alienware X51 - i7-3770 - GTX 1060 - 16GB 1600Mhz DDR3 Alienware M17x R3 - i7-2760QM - GTX 580M - 16GB 1600Mhz DDR3 Alienware Area 51 ALX - i7-975 Extreme - GTX 980 - 16GB 1600Mhz DDR3 Alienware Aurora R2 - i7-3770K - GTX 670FTW - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 1060 - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 670FTW - 16GB 1600Mhz DDR3
runix18 Posted January 27, 2022 Posted January 27, 2022 Where did you bought the FX 2280 velociraptor? Need one for P870DM-G. Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 9800X3D | 64GB Corsair Vengeance RGB DDR5 6000MHz CL30 Dual Channel Kit | MSI RTX 4070TI Suprim X | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 11 Enterprise x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64
Maxware79 Posted January 27, 2022 Author Posted January 27, 2022 We got ours from a guy on NBR but he doesn't have them anymore. You can find them on Alibaba but I believe they are the full NVMe speed cards. There is an issue with our Alienware's though, the adapter drains power constantly, even with the power turned off. If you have an internal battery then it will drain that too. The M18x has a removeable battery which makes it a little easier. Alienware Aurora R15 - i9-13900KF - RTX 4090 - 32GB DDR5 Alienware X51 - i7-3770 - GTX 1060 - 16GB 1600Mhz DDR3 Alienware M17x R3 - i7-2760QM - GTX 580M - 16GB 1600Mhz DDR3 Alienware Area 51 ALX - i7-975 Extreme - GTX 980 - 16GB 1600Mhz DDR3 Alienware Aurora R2 - i7-3770K - GTX 670FTW - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 1060 - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 670FTW - 16GB 1600Mhz DDR3
FrozenLord Posted January 29, 2022 Posted January 29, 2022 On 1/27/2022 at 4:41 AM, Katja said: I'm now kind of curious how modular and costly the M18x is, given I'd like to have an inexpensive tinkering machine that can do some more intensive work (since my main machine is almost exclusively gaming-oriented). You might want to look into the Eurocom Tornado F5 (rebranded MSI 16L1) for that matter as well. The F5 offers a 6th gen 1151 LGA socket and can run a 9th gen Core i7 just fine, with some BIOS mods. It has also got a single MXM slot, on top of 1x SATA (2.5") and 2x NVME (m.2 2280) 🙂
AXA Posted January 30, 2022 Posted January 30, 2022 is the nvme adapter limited in which SSDs can be used? or will any work? (i noticed the a11 bios said support for samsung m.2 and nvme support so assumed it could be limited to just that brand) Alienware M18X R2 | Nebula Red | i7 3740QM [OC'd to 4Ghz] | 32GB RAM | NVIDIA Quadro P4000 | 75hz OC'd Display | MXM to NVMe Adapter with Samsung 970 Evo Plus 2TB Alienware 17 R4 | i7 6700HQ | 16GB RAM | GTX 1070 | 100hz OC'd LG 1080p Display Alienware M18X R1 | Space Black | i7 2960XM | 16GB RAM | GTX 780M
Maxware79 Posted January 30, 2022 Author Posted January 30, 2022 16 hours ago, Azther said: is the nvme adapter limited in which SSDs can be used? or will any work? (i noticed the a11 bios said support for samsung m.2 and nvme support so assumed it could be limited to just that brand) Not sure sorry. I'll have to check if the other guys have tried anything other than Samsung. I'll let you know if I find out. Alienware Aurora R15 - i9-13900KF - RTX 4090 - 32GB DDR5 Alienware X51 - i7-3770 - GTX 1060 - 16GB 1600Mhz DDR3 Alienware M17x R3 - i7-2760QM - GTX 580M - 16GB 1600Mhz DDR3 Alienware Area 51 ALX - i7-975 Extreme - GTX 980 - 16GB 1600Mhz DDR3 Alienware Aurora R2 - i7-3770K - GTX 670FTW - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 1060 - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 670FTW - 16GB 1600Mhz DDR3
AXA Posted January 30, 2022 Posted January 30, 2022 tyvm, greatly appreciated Alienware M18X R2 | Nebula Red | i7 3740QM [OC'd to 4Ghz] | 32GB RAM | NVIDIA Quadro P4000 | 75hz OC'd Display | MXM to NVMe Adapter with Samsung 970 Evo Plus 2TB Alienware 17 R4 | i7 6700HQ | 16GB RAM | GTX 1070 | 100hz OC'd LG 1080p Display Alienware M18X R1 | Space Black | i7 2960XM | 16GB RAM | GTX 780M
ssj92 Posted January 31, 2022 Posted January 31, 2022 I use SK Hynix 1TB in AW 18 and 980 PRO in M18xR2 so it should not matter. The Raptor card is built well in that any SSD should work even 8TB in theory Alienware Area-51 18 : Intel Core Ultra 9 275HX @ ??? | nVidia GeForce RTX 5090 | BE200 | 1TB Gen5 9100 PRO Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
Katja Posted February 1, 2022 Posted February 1, 2022 On 1/29/2022 at 5:57 AM, FrozenLord said: You might want to look into the Eurocom Tornado F5 (rebranded MSI 16L1) for that matter as well. The F5 offers a 6th gen 1151 LGA socket and can run a 9th gen Core i7 just fine, with some BIOS mods. It has also got a single MXM slot, on top of 1x SATA (2.5") and 2x NVME (m.2 2280) 🙂 I am now HEAVILY tempted on that; I'll have to look after I move in a few weeks, based on if I have any spare money, given right now there's some other things I have to worry about. On the off chance, if you know anything bout it, how is this in terms of fan noise/temps, given it has a desktop CPU? My current main machine is using an 11800h and a 3080 165w, but the idea would be to make that more of a second-use/project machine for Linux and other things. Kirisame: Custom build Ryzen 7 5800X 32GB HyperX DDR4-3733 CL18 ASRock Phantom D OC RX 6800XT 1TB Samsung OEM gen4 2TB Inland Platinum 2TB Seagate Barracuda HDD Huawei Matebook D14 i5-10210U 8GB DDR4 500GB NVME
senses3 Posted February 22, 2022 Posted February 22, 2022 Wow never seen MXM to NVMe adapter in the wild. Good stuff.
FrozenLord Posted March 3, 2022 Posted March 3, 2022 On 2/1/2022 at 10:06 AM, Katja said: On the off chance, if you know anything bout it, how is this in terms of fan noise/temps, given it has a desktop CPU? I am using this laptop as my main device and have messed with it quite a bit. The noise depends on CPU / GPU combo used as well as on the heatsink. I bought my device used and am unsure whether my heatsink is in pristine condition... My experience: The laptop is able to handle a 1080GTX at 150W continuously in 22°C rooms. A 6700K and a 7700K (have hands-on experience with bith in this device) might run hot, as they always do. However, some users in Notebookreview's owner thread were able to run a 8700K and overclock it, although I am not sure how they managed to do so. My F5 is now sporting a 9700F, which is limited by power and thermals on my device. With 1.2V (unstable below that) I am able to run it at 45x45x45x45x45x44x43x42, with IMON Offset of -25W (to go above Intel's mandated 65W power limit). With this setup (daily driver), the CPU will reach high 80s to low 90s on average when playing CPU+GPU intense games. This is just shy of throttling which is why I have set it up like that. Depending on your needs, you can keep the 65W default power limit and get away with lower temps. Fan noise is fully dependent on the fans used. There were some discussions on that in the previous forum as well. The stock fans (N322) tended to die like flies, needing a replacement within 1y. The updated N395 you could get from some websites lasts much longer and is a bit faster, at slightly increased noise. There seems to be a newer version N408 which is supposed provide a reliable / lasting (similar to N395) fan at a lower noise level (vs. N395) but I have not tried those. You can also take a completely different fan and mod it to fit this device. My GPU is currently being cooled by a fan used in Asus laptops (would need to check the label to know which fan it is). Unless you push for the limit (= what I am doing to this device), the noise level is actually quite low. Last but not least, the device is based upon a MSI barebone so you can use Svet's VBIOS Tuner to modify the fan table in the EC (included in that tool, you still can not modify VBIOS for Pascal GPUs).
FredSRichardson Posted April 5, 2022 Posted April 5, 2022 Really outstanding! Amazing work keeping that laptop going strong for 10 years - it looks great it sounds like it performs well too. Really can't ask for more than that!
StripeySnake Posted April 5, 2022 Posted April 5, 2022 I'm not sure you would need more CPU cooling, but after some shenanigan's I did with an m17x R2, I can't help but notice that third GPU heatsink slot could be filled with a heatsink and linked to the CPU cooler fairly easily, and with HWINFO you could bind that second GPU fan to the CPU temps. I'm sure that kind of cooling would be more than a little overkill, but you could probably handle clocks close to 5 ghz with that kind of cooling on a 3940. Daily Drivers: JANKTOP IV Mini-ITX Laptop - R5 2600X, 16gb DDR4 3000 Mhz, RX 5700 XT - (ONGOING) Claymore V2 Cyberdeck, 6900HX, 680m iGPU, 16gb DDR5, 185 Wh Battery 14 R1 - 4710MQ @ 3.6 Ghz, hd 4600, 12gb DDR3L 1600 Mhz Past Projects: 15 R3 - GTX 1060 6gb, i7 7700HQ, 16gb DDR4 17 R4 - RX 470 8gb i7 6700HQ, 16gb DDR4 M17x R4 - 3630QM, Quadro P4000, 16gb DDR3L 1600 Mhz M17x R2 - i7 920XM @ 3.4 Ghz, GTX 770m 2gb, 16gb DDR3
Maxware79 Posted April 5, 2022 Author Posted April 5, 2022 19 hours ago, FredSRichardson said: Really outstanding! Amazing work keeping that laptop going strong for 10 years - it looks great it sounds like it performs well too. Really can't ask for more than that! Thanks. 8 hours ago, StripeySnake said: I'm not sure you would need more CPU cooling, but after some shenanigan's I did with an m17x R2, I can't help but notice that third GPU heatsink slot could be filled with a heatsink and linked to the CPU cooler fairly easily, and with HWINFO you could bind that second GPU fan to the CPU temps. I'm sure that kind of cooling would be more than a little overkill, but you could probably handle clocks close to 5 ghz with that kind of cooling on a 3940. I've thought about this many times over the years. I've even looked into buying some heatsink pipes and bending them myself. Now that I have the NVMe adapter in the second slot doesn't really work though. Alienware Aurora R15 - i9-13900KF - RTX 4090 - 32GB DDR5 Alienware X51 - i7-3770 - GTX 1060 - 16GB 1600Mhz DDR3 Alienware M17x R3 - i7-2760QM - GTX 580M - 16GB 1600Mhz DDR3 Alienware Area 51 ALX - i7-975 Extreme - GTX 980 - 16GB 1600Mhz DDR3 Alienware Aurora R2 - i7-3770K - GTX 670FTW - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 1060 - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 670FTW - 16GB 1600Mhz DDR3
StripeySnake Posted April 6, 2022 Posted April 6, 2022 You're right. I was thinking you could go directly, but I just noticed the hinge mount in the way. It might still be possible, but would likely require replacing the first heatpipe with a longer one and that's very complex and difficult to do. Daily Drivers: JANKTOP IV Mini-ITX Laptop - R5 2600X, 16gb DDR4 3000 Mhz, RX 5700 XT - (ONGOING) Claymore V2 Cyberdeck, 6900HX, 680m iGPU, 16gb DDR5, 185 Wh Battery 14 R1 - 4710MQ @ 3.6 Ghz, hd 4600, 12gb DDR3L 1600 Mhz Past Projects: 15 R3 - GTX 1060 6gb, i7 7700HQ, 16gb DDR4 17 R4 - RX 470 8gb i7 6700HQ, 16gb DDR4 M17x R4 - 3630QM, Quadro P4000, 16gb DDR3L 1600 Mhz M17x R2 - i7 920XM @ 3.4 Ghz, GTX 770m 2gb, 16gb DDR3
