Converting from 4 cell to 97wh battery for a 7530 ?
Hi,
My 7530 battery has just died. According to my service tag it currently has a GHXKY installed however I'd like to upgrade it to a 97wh 6 cell battery.
The battery I have seen is a genuine 97wh and is a CJ18V.
Given that mine is 7.6v and the 6 cells are 11.4v, are the power management boards different ?
I'm also aware that Dell used two different battery power connectors as well....
Is the 97Wh OK to install into my 7530. Worst case requiring a different power connector?
Thanks....
Should be fine, unless you have a 2.5” SATA drive installed, then the larger battery will not fit.
  • Windows 10 Enterprise LTSC 2021
