Does anyone still has this app around?
I have a Clevo P750DM2 that I need to control the front led and I do not want to install Clevo CC, and rzrwolf/LED-manager-for-Clevo does not have the option to control that LED.
Thank you.
Yes
  • Сlevo p870tm1-g 17.3 Fhd 300Hz i9-10980hk ES rtx3060. / Clevo x170smg 17.3 300Hz i9-10850k rtx2070super 32g ddr4 3200Mhz Gskill. / Clevo x170kmg 17.3 2k 165Hz i5-11600k rtx3080 32g ddr4 3200Mhz Hyper-X.
1 hour ago, ViktorV said:
You are a legend. Thank you.
