Theguywhobea Posted December 1, 2022 Posted December 1, 2022 So I recently purchased a Y545 real cheap because it was supposed to be broken. Well turns out it is. I have spent hours and hours doing everything I can think of, but still can't really figure it out. At first it was running an old BIOS version, so after thinking I was having driver problems forever I realized it was probably some BIOS corruption or something and that was causing the near constant BSOD loops. Well I finally managed to stay in windows long enough to flash the most up to date BIOS, and it rebooted and said everything was good. BIOS menu looks fine now and reports the correct version. However it still won't boot into any OS. Linux kernel panics, and Windows BSOD's. I can however get it to boot into windows for a little bit if I pull the CMOS battery out. That always assures the next boot will work. If I have the laptop unplugged it will run for quite a while before bluescreening, if I plug it in it will bluescreen pretty quick. Is this still some kind of BIOS corruption? Is this even a fixable issue?
saturnotaku Posted December 1, 2022 Posted December 1, 2022 Random blue screens are usually a sign of failing/failed RAM. Desktop: Ryzen 5 7600X3D | 32 GB RAM | Radeon RX 9070 GRE | 8 TB SSD | Windows 11 Lenovo Legion 5i: Core Ultra 7 255HX | 32 GB RAM | GeForce RTX 5070 | 1 TB SSD | Windows 11 Gigabyte Aorus 16X: Core i7-14650HX | 32 GB RAM | GeForce RTX 4070 | 1 TB SSD | Windows 11 Lenovo IdeaPad 5 Pro: Ryzen 5 5600U | 16 GB RAM | Radeon Graphics | 512 GB SSD | Windows 11 MacBook Neo: Apple A18 Pro | 8 GB RAM | 512 GB SSD | macOS
Theguywhobea Posted December 1, 2022 Author Posted December 1, 2022 23 minutes ago, saturnotaku said: Random blue screens are usually a sign of failing/failed RAM. While I do agree, the BSODs aren't really random at this point, I can basically count on it to bluescreen now. And I have tried several sets of RAM in various configs, and verified that they all work in other laptops. I tried a different charger, I tried a different battery, I tried different SSD's. I have tried basically every BIOS option I can think of.
saturnotaku Posted December 1, 2022 Posted December 1, 2022 What is the specific blue screen error? Install the program WhoCrashed to analyze the memory dump. Desktop: Ryzen 5 7600X3D | 32 GB RAM | Radeon RX 9070 GRE | 8 TB SSD | Windows 11 Lenovo Legion 5i: Core Ultra 7 255HX | 32 GB RAM | GeForce RTX 5070 | 1 TB SSD | Windows 11 Gigabyte Aorus 16X: Core i7-14650HX | 32 GB RAM | GeForce RTX 4070 | 1 TB SSD | Windows 11 Lenovo IdeaPad 5 Pro: Ryzen 5 5600U | 16 GB RAM | Radeon Graphics | 512 GB SSD | Windows 11 MacBook Neo: Apple A18 Pro | 8 GB RAM | 512 GB SSD | macOS
Theguywhobea Posted December 1, 2022 Author Posted December 1, 2022 5 minutes ago, saturnotaku said: What is the specific blue screen error? Install the program WhoCrashed to analyze the memory dump. I can't get windows to stay up long enough to run a program install. It's typically SYSTEM_THREAD_EXCEPTION_NOT_HANDLED and sometimes it will say it was due to ACPI.SYS Other times it's some KMODE exception error.
