blacklord049 Posted December 18, 2022 Posted December 18, 2022 Hi,  I own a Clevo W650KJ1 (motherboard WK65KJ1_KK1) bought at SHS Computer (Belgium). My LCD panel is cracked on the top right corner. It still works but my worry is that it doesn't last.  Do you know where I could by a new LCD panel for my laptop? Do you know if other panels in the entire W650 series are compatible? I'm living in Belgium so to avoid custom fees or high shipping fees, I prefer not to buy the spare part outside Europe.  Edit: this one is mentioned in the service manual, could you confirm it's compatible? https://clevo-computer.com/en/spare-parts/clevo/clevo-n-series/nbxx/nb5xx/nb50tk1/display/2617/6-50-lb232-g18-lcd-15.6-fhd/edp/led-au-b156htn03.8-clevo-nb50tk1  This one costs 180€ but is not available : https://clevo-computer.com/en/spare-parts/clevo/clevo-w-serie/w6xx/w65x/w650kk1/6007/6-50-lb232-v02-display-lcd-15.6-fhd/edp/led-innolux-n156hge-eab-clevo-w650kk1  Kind regards
runix18 Posted December 19, 2022 Posted December 19, 2022 14 hours ago, blacklord049 said: Hi,  I own a Clevo W650KJ1 (motherboard WK65KJ1_KK1) bought at SHS Computer (Belgium). My LCD panel is cracked on the top right corner. It still works but my worry is that it doesn't last.  Do you know where I could by a new LCD panel for my laptop? Do you know if other panels in the entire W650 series are compatible? I'm living in Belgium so to avoid custom fees or high shipping fees, I prefer not to buy the spare part outside Europe.  Edit: this one is mentioned in the service manual, could you confirm it's compatible? https://clevo-computer.com/en/spare-parts/clevo/clevo-n-series/nbxx/nb5xx/nb50tk1/display/2617/6-50-lb232-g18-lcd-15.6-fhd/edp/led-au-b156htn03.8-clevo-nb50tk1  This one costs 180€ but is not available : https://clevo-computer.com/en/spare-parts/clevo/clevo-w-serie/w6xx/w65x/w650kk1/6007/6-50-lb232-v02-display-lcd-15.6-fhd/edp/led-innolux-n156hge-eab-clevo-w650kk1  Kind regards Anything that is in the laptops own service manual is sure to be compatible. You can also go the ebay route for cheaper parts with warranty: like this  Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 9800X3D | 64GB Corsair Vengeance RGB DDR5 6000MHz CL30 Dual Channel Kit | MSI RTX 4070TI Suprim X  | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 11 Enterprise x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64 Â
blacklord049 Posted December 23, 2022 Author Posted December 23, 2022 Bought this one : https://www.befr.ebay.be/itm/131912748027?mkevt=1&mkpid=0&emsid=e11050.m43.l1123&mkcid=26&ch=osgood&euid=1f582d52adba4c7196939fd7e3bf7432&bu=43622726804&osub=-1~1&crd=20221223033645&segname=11050 Â We'll see
blacklord049 Posted December 26, 2022 Author Posted December 26, 2022 Hello, I'm back to tell you I've successfully changed the panel, the model above is working well.
runix18 Posted December 26, 2022 Posted December 26, 2022 2 hours ago, blacklord049 said: Hello, I'm back to tell you I've successfully changed the panel, the model above is working well. 😉Good job. Desktop - MSI X670E Tomahawk Wifi (cheap Ebay mobo that I fixed) | AMD 9800X3D | 64GB Corsair Vengeance RGB DDR5 6000MHz CL30 Dual Channel Kit | MSI RTX 4070TI Suprim X  | Alienware 27 AW2724DM 2K 165 Hz Gsync | Samsung 990 Pro Nvme - Boot | Other various storage | Windows 11 Enterprise x64 SOLD - Clevo P870DM-G | i9-9700K 4.5 Ghz on all cores (-50 mv undervolted) | 32GB Hyper X Black 2666MHz | Clevo RTX 2080 3.1b undervolted for better temp 1905Mhz @881 mv | AUO B173HAN03.1 144hz Gsync | Samsung 980 NVME | Dsanke TM BIOS - Chujoi13 adapted based on needs | Network Card: Intel AX210-AX | Windows 10 Pro x64 Â
