TheQuentincc Posted January 14, 2023 Posted January 14, 2023 HI, I finally decided to upgrade my daily laptop with a wonderful 4k display, in this case the BOE NE156QUM-N6C which is one of the best currently available 15.6" UHD IPS display (IPS, 60Hz, 10bit, HDR400, 600nits, full DCI-P3 coverage, ) https://www.panelook.com/NE156QUM-N6C_BOE_15.6_LCM_overview_48042.html SIDE NOTE ABOUT OLED : I read 2 or 3 times that OLED panel needs to be supported by the laptop bios/firmware otherwise you might lack brightness control My Precision 7550 (which is similar as a 7560) came from the factory with the 1080p DCI-P3 500nits display and the regular camera (not IR). I firstly ordered one of the few eDP "UHD" cable available for the 7550/7560 which is "0CM4DM" part number, however I didn't realised this cable was only made for the IR camera configuration (on which you can't plug the regular camera, futhermore it require display frame and cover replacement to even be able to fit an IR camera, IT'S NOT WORTH the money imho), also this cable have a 40 eDP connector with 0.4mm pitch while my screen have a 0.5mm pitch.... So I ordered a second cable "02KWM2" part number which have the connector for the regular camera, like the previous cable it also have a 0.4mm pitch... (NOTE : it's a bit weird I can't found a 0.5mm pitch cable for the 7550/7560 because the 4k display version sent to reviewers were using a panel/connector with 0.5mm pitch) I finally ended up buying one of those adapter which works flawlessly : https://fr.aliexpress.com/item/1005002211991684.html (basically you plug the 0.5mm pitch part into the screen, golden pad facing the top, then you bend the cable over to make the 0.4mm pitch connector at nearly the same position as the display connector) I really enjoy this upgrade, the hardest part was to swap the cable, indeed you need to nearly disassemble the whole laptop which is a PITA (even more when you have liquid metal on your CPU). I'm now looking into upgrading my RTX 3000 to a better card (to handle more pixel in word :p) I can't recommand you enough switching to a QHD/UHD display for your work computer if you have a good view, it require so little more power if you aren't using 3D render at full resolution and it makes text so much clearer, also contrast ratio and brightness are nice improvement, totally worth the 180€ total for the upgrade. 1 1 Desktop / I7 14700KF @5.6/4.5GHz 1.20v / MSI Z690 Edge Wifi / 32GB DDR4 B-die @4000c16 / RTX 3080 Ti MSI Trio deshroud with 2x120mm / Triple 27" 4k120 + 2*4k60 XPS 9500 / I7 10750H @3.2GHz all-core / 32GB DDR4 2400MHz / GTX 1650Ti 4GB @50W / 15.6" UHD / NVME / 86Wh Dell Latitude C810 / Dell Precision M50 / Dell Precision M60 / Dell Precision M90 / Dell Precision M6400... and trying to get the other older flagship for cheap My "most modded" laptop was running an I7 3920XM @4.2GHz all-core (nvram edit) in a Dell Precision M6700 with 32GB 2133MHz DDR3L, a Quadro P4000 (before the OC vbios) and a 4k eDP display (using M6700 3D cable).
balfrog Posted April 19 Posted April 19 Just bought a used 7550 with the same 1080p 500-nit FHD DCI-P3 display. I find that I don't notice the difference between 4k and 1080p much at this screen size (maybe my eyes are just bad 😅) The color and brightness are likewise pretty nice, but what's really bothering me (coming from a XPS 15 7590 OLED) is the backlight bleed. It would be cool to upgrade to a high-refresh-rate panel too, but I'm not sure how to verify compatibility. I tried to do a similar upgrade on my 7590, I checked and all of the specs seemed to line up in Panelook, but when I plugged it in it fried the backlight circuit on my motherboard. So I bought a new motherboard and an OLED display LOL. Does anyone have any success stories re: upgrading to (perhaps) a QHD 165hz panel or similar?
TheQuentincc Posted June 26 Author Posted June 26 I believe the issue you had was using a regular display in an "oled motherboard" or something like that, you need at the very least the regular "eDP cable" that's not made for OLED display Desktop / I7 14700KF @5.6/4.5GHz 1.20v / MSI Z690 Edge Wifi / 32GB DDR4 B-die @4000c16 / RTX 3080 Ti MSI Trio deshroud with 2x120mm / Triple 27" 4k120 + 2*4k60 XPS 9500 / I7 10750H @3.2GHz all-core / 32GB DDR4 2400MHz / GTX 1650Ti 4GB @50W / 15.6" UHD / NVME / 86Wh Dell Latitude C810 / Dell Precision M50 / Dell Precision M60 / Dell Precision M90 / Dell Precision M6400... and trying to get the other older flagship for cheap My "most modded" laptop was running an I7 3920XM @4.2GHz all-core (nvram edit) in a Dell Precision M6700 with 32GB 2133MHz DDR3L, a Quadro P4000 (before the OC vbios) and a 4k eDP display (using M6700 3D cable).
Dimitri Posted Thursday at 03:12 PM Posted Thursday at 03:12 PM Hi, I bought a used Dell Precision 7550 laptop with a 1080p display, but my eyes hurt a lot because of PWM. I came across your post and I'm considering whether to install the BOE NE156QUM-N6C display, like the one you have. Could you tell me, please, did you check it for PWM for example using a phone camera in slow-mo and are there any flicker bands? Do your eyes hurt? What are your impressions of the new screen after using it for a while? You used a new cable with part number "02KWM2." But I found another one: "094D5W DC02C00P70" https://www.ebay.com/itm/256207921069. Have you come across this one? Would it work, and can it be used without an adapter?
