Steerpike Posted January 31, 2023 Posted January 31, 2023 I don't start too many threads as there are usually plenty of good ones around already, but today I started a new one, and I was required to provide a 'Tag' below the 'Title'. But there was no list of keywords to choose from, no hints or suggestions, so I had no idea what the purpose was. I ended up putting in something not very helpful. So ... what is the intent of the 'tag', and what are some useful examples?
Aaron44126 Posted January 31, 2023 Posted January 31, 2023 See - Basically to help add keywords that search engines can latch onto. 1 1 Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi
Reciever Posted January 31, 2023 Posted January 31, 2023 It helps our search engine and also to be brought up on external search engines like google. AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX | 32GB DDR4 3200Mhz | 2TB NVME | EVGA 1300w | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | RTX 3090Ti | 9300i-16P | 68TB HDD's | BeQuiet DP 13 1000w HomeLab | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
Steerpike Posted February 1, 2023 Author Posted February 1, 2023 8 hours ago, Reciever said: It helps our search engine and also to be brought up on external search engines like google. I'm strongly in favor of 'keywords' to aid in searching. But this forum is well structured to begin with, and I'm already aware of the value of 'good thread titles', so this seems a bit redundant, as a 'required' field. In my case, I created a thread titled "Windows 11 'Start Menu' changes"; appropriate tags would be, I presume, 'Windows 11' and 'Start Menu' - but those are already in the title which I presume is just as likely to be picked up by Google search indexing. So I was a bit puzzled by what tags I could add to 'further enhance' the post. However, I fully support the concept, so I'll try to create helpful tags from now on, even if they duplicate the thread title! Edit To Add: I see that they also aid in cross-forum searching if you click on the tag, so that's potentially useful:
Sandy Bridge Posted February 1, 2023 Posted February 1, 2023 Indeed, from a user (not search engine) standpoint, the main benefit is it lets you easily find other threads with the same tag. Maybe I want to find other "windows 7" threads, or "music" threads, for example. For this forum in particular, it can be used to tag the model of laptop in question. On forums that don't require tags, you're at the mercy of the search engine, which will often pull in other threads that only mention "windows 7" in the body for example. Or they might decide "7" is fewer characters than their minimum search term length of 3 (a restriction I've run into on some forums). They'll probably become more useful over time as we acquire more threads. On the old NotebookReview forum, where in its heydey there would be many threads per laptop, having the laptop tagged would have been great - find the entire world's cumulative knowledge about your laptop with one tag. Desktop: Core i5 2500k "Sandy Bridge" | RX 480 | 32 GB DDR3 | 1 TB 850 Evo + 512 GB NVME + HDDs | Seasonic 650W | Noctua Fans | 8.1 Pro Laptop: MSI Alpha 15 | Ryzen 5800H | Radeon 6600M | 64 GB DDR4 | 4 TB TLC SSD | 10 Home Laptop history: MSI GL63 (2018) | HP EliteBook 8740w (acq. 2014) | Dell Inspiron 1520 (2007)
