Etern4l Posted May 3, 2023 Posted May 3, 2023 Hello, Would it be possible to close gaps in the ignored users function (in the suggested order of importance): * Reactions from the ignored users shouldn't be visible * Noise from ignored users is still unnecessarily shown in the activity feed * Filter out from Last post thumbnails (a couple of users showing on the majority of threads on the site especially in off-topic) * Ideally we would also be able to filter out threads started by the ignored users Thanks guys. @Hiew "We're rushing towards a cliff, but the closer we get, the more scenic the views are." -- Max Tegmark AI: Major Emerging Existential Threat To Humanity
Reciever Posted May 3, 2023 Posted May 3, 2023 Certain posts removed AM5-DD | 9850X3D2 @ 5.7Ghz | Wet Devil 7900 XTX / Pulse 9070 XT (LSFG) | 32GB DDR5 8000Mhz | 2TB NVME | EVGA 1300w | NVME to 10Gbps | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | P1000 | 9300i-16P | 68TB HDD's | 5TB SSD's | BeQuiet DP 13 1000w ProxMox | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
Etern4l Posted May 3, 2023 Author Posted May 3, 2023 Thanks. Updated the list The system was more watertight on NBR. Possibly the only technical advantage of the old site. Not a biggie, but worth addressing if possible. Alternatively, perhaps firmer enforcement of a reasonable standard of posting might be worth considering, so that even fairly patient users are not forced to use the feature for sanity's sake. Without this, the noise is still there for any new and uninitiated visitors to see, could be off-putting. "We're rushing towards a cliff, but the closer we get, the more scenic the views are." -- Max Tegmark AI: Major Emerging Existential Threat To Humanity
Reciever Posted May 3, 2023 Posted May 3, 2023 28 minutes ago, Etern4l said: Thanks. Updated the list The system was more watertight on NBR. Possibly the only technical advantage of the old site. Not a biggie, but worth addressing if possible. Alternatively, perhaps firmer enforcement of a reasonable standard of posting might be worth considering, so that even fairly patient users are not forced to use the feature for sanity's sake. Without this, the noise is still there for any new and uninitiated visitors to see, could be off-putting. Yep, I will be addressing this with Hiew IRL next time I see him, things appear to slowing a bit with both our work lives so we I intend to hopefully address a number of holes overall on the forum. AM5-DD | 9850X3D2 @ 5.7Ghz | Wet Devil 7900 XTX / Pulse 9070 XT (LSFG) | 32GB DDR5 8000Mhz | 2TB NVME | EVGA 1300w | NVME to 10Gbps | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | P1000 | 9300i-16P | 68TB HDD's | 5TB SSD's | BeQuiet DP 13 1000w ProxMox | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
