Sandy Bridge Posted February 1, 2022 Posted February 1, 2022 In another thread, @Ishatixmentioned, Quote I tweak my Windows UI quite a lot to be more like the pre-Win7 / Cinnamon style anyway, with a double row of separated windows in the taskbar (i.e. not bundled together and hidden away under separate program icons), and I find that the longer/further you stay off the accepted mainstream "norm" with software, the more likely things will break, be removed, or no longer supported in the future. 😩 This got me thinking, that would be a good discussion topic! How do you tweak your taskbar, and what programs do you use to do so? I'm not sure I have any taskbar-tweaking programs on my Win8.1/Win10 computers, although having a double row of windows sounds intriguing, and I really should try having the taskbar on the side again! I'm constantly running out of space to read which programs I have open. I still have Taskix on my legacy system on its XP install, which lets you reorder windows on the taskbar (now present in later versions of Windows by default), as well as other features such as middle-click on the taskbar closing programs (I still kind of miss that one, now it opens a new window by default). But I guess the reordering was what I really installed it for, and now that it's present by default (except in groups of the same program's windows), I haven't felt compelled to re-install it. Any other cool programs we should all know about? Desktop: Core i5 2500k "Sandy Bridge" | RX 480 | 32 GB DDR3 | 1 TB 850 Evo + 512 GB NVME + HDDs | Seasonic 650W | Noctua Fans | 8.1 Pro Laptop: MSI Alpha 15 | Ryzen 5800H | Radeon 6600M | 64 GB DDR4 | 4 TB TLC SSD | 10 Home Laptop history: MSI GL63 (2018) | HP EliteBook 8740w (acq. 2014) | Dell Inspiron 1520 (2007)
Ishayin Posted February 1, 2022 Posted February 1, 2022 Ah, nice idea, and thanks for the mention! Well, if you'd mentioned Taskix to me 20 years ago I certainly would have been interested! 😄 But yeah, I consider the ability to re-order windows pretty essential. I can't remember now if that was standard by the time of Vista, or if there was a hack for it. No third party programs are required to set up the taskbar how I have it, it's all just standard options within Windows itself. Here are my taskbar settings in Windows 8.1 (right-click on taskbar and select "Properties"): Spoiler I believe that Windows 10 is more or less the same in this regard. No idea about Windows 11, but would be very interested if anyone here can confirm. I think the main options of importance here are ticking the box for "Use small taskbar buttons" and setting "Taskbar buttons:" to "Never combine". Then simply de-select "Lock the taskbar" from the right-click context menu, drag it up to the height for how many rows you want, and then lock it again. My use of two rows here dates back to my younger years when I worked a stint in tech support for a large banking organisation. (We used Windows "Omni"(?) or something like that... a sort of enterprise Windows variant in between XP and Vista I think...) We each had two computers and many dozens of different programs open on each of them for doing different things. So having two rows of windows in the taskbar was the only possible way to handle it all. And I still find it the most practical layout to this day since I often have many different things open at once, and like to be able to see, and switch between, all windows cleanly and quickly. I also still have an old school "Quick Launch" section configured between taskbar and the Start button at bottom left. Though in truth, I never use it any more (see final paragraph for why), so maybe I should get rid of it... For my Start Menu I still use an old version of Classic Shell, with the "Classic with two columns" start menu style, with entries adjusted to my own preferences. There are also some additional Windows 8.1 settings here. Though note that development now continues on it in the form of Open Shell, currently supporting Windows 7, 8, 8.1, 10. It is not clear yet whether it will support Windows 11 in the future. See this discussion: https://github.com/Open-Shell/Open-Shell-Menu But really, the most significant addition to my Windows interface is AutoHotKey (there are a number of possible alternatives for Linux), which allows you to create keyboard shortcuts for doing practically anything, and is very simple to use. So anything I do regularly I will have a keyboard shortcut for. E.g.: All the standard programs I use regularly I have set to open with Windows key shortcuts, such as Win-W for Winamp, Win-V for Vivaldi, Win-+ for Notepad++, Win-Z for Zim etc. Or a modified Windows key for ones I use less often like Win-Alt-R for autoruns.exe. Shortcuts for any commonly used text entries such as email sign-offs, the email address I use to sign-up for things, phone number, URL text injection etc. Numpad keys (when NumLock off) setup as media playback controls/volume etc. for Winamp. Shortcuts for allowing my remote control to launch certain programs. Custom screen brightness controls Sleep / lock / screen switch-off shortcuts(the latter is useful for laptops which don't have a function key for this). Paste without formatting Instantly creating the sub-directory structure that I always use in all my folders of photos. There are all extremely basic tasks. AHK can do a whole lot more powerful things than that if you are more technically inclined.
Aaron44126 Posted February 1, 2022 Posted February 1, 2022 I remember Taskix. Life saver back in the XP/Vista days when you couldn't rearrange the taskbar. I had a specific order that I liked, and I remember being upset when something would cause Explorer to crash and that would jumble up the order of items on the taskbar. I'd have to close and reopen everything to get the order back how I wanted. (Until I discovered Taskix.) I don't use any taskbar tweak programs right now, but I do have replacement for other parts of the Windows shell. I use Start11 (Start menu replacement) and Directory Opus (File Explorer replacement). If I could find a good taskbar replacement then I would check it out. I think that the taskbar could certainly be made more power user friendly. 12 minutes ago, Ishatix said: No idea about Windows 11, but would be very interested if anyone here can confirm. Windows 11 has lost most taskbar customization functionality. You can't "ungroup" windows anymore, show text next to the taskbar icons, or show it on any side of the screen other than the bottom. I'm a bit miffed that there is no way to show seconds on the clock (either on the taskbar or in the flyout that appears when you click on the clock). You can get functionality back by forcing it to use the Windows 10 taskbar, which is still present, but that's a bit hacky/broken. Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi
John Ratsey Posted February 1, 2022 Posted February 1, 2022 I briefly tried Windows 11 but quickly reverted to Windows 10 when I discovered that I couldn't put the taskbar up the left side of the screen so I get maximum vertical real estate. It's set to small icons and is wide enough that I get time and date shown. I've never liked auto-hide so it's fixed. My most frequently-used programs are pinned to the taskbar.
AXA Posted February 2, 2022 Posted February 2, 2022 My windows setup is pretty vanilla with the exception of StartIsBack and the Grey Eve theme to make everything dark mode. startisback: https://startisback.com/ Grey eve theme (working on LTSC 2021 so i would assume the standard 21H2 works also): https://github.com/nitschis/GreyEveTheme Heres how it looks: 1 Alienware M18X R2 | Nebula Red | i7 3740QM [OC'd to 4Ghz] | 32GB RAM | NVIDIA Quadro P4000 | 75hz OC'd Display | MXM to NVMe Adapter with Samsung 970 Evo Plus 2TB Alienware 17 R4 | i7 6700HQ | 16GB RAM | GTX 1070 | 100hz OC'd LG 1080p Display Alienware M18X R1 | Space Black | i7 2960XM | 16GB RAM | GTX 780M
defcon42 Posted February 2, 2022 Posted February 2, 2022 @AztherWhat is the advantage of Grey eve theme over Windows systemwide dark mode? Clevo P670HP6-G @OBSIDIAN-PC (2017), 17,3"//GTX1060//i7-7700HQ//512GB M2.SSD, external 32" UHD Display (defying BGA haters since day 1)😋
Aaron44126 Posted February 2, 2022 Posted February 2, 2022 3 hours ago, defcon42 said: @AztherWhat is the advantage of Grey eve theme over Windows systemwide dark mode? System-wide dark mode isn't exactly system-wide. For example, see "Task Manager" in the screen shot above; dark mode doesn't change its appearance at all. 1 Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi
AXA Posted February 2, 2022 Posted February 2, 2022 @defcon42 as @Aaron44126 has said, the built in one doesnt change everything over, stuff like transfer windows and task manager stay white. since grey eve is a modded high contrast theme, it converts everything and doesnt need any system file modifications to work 2 Alienware M18X R2 | Nebula Red | i7 3740QM [OC'd to 4Ghz] | 32GB RAM | NVIDIA Quadro P4000 | 75hz OC'd Display | MXM to NVMe Adapter with Samsung 970 Evo Plus 2TB Alienware 17 R4 | i7 6700HQ | 16GB RAM | GTX 1070 | 100hz OC'd LG 1080p Display Alienware M18X R1 | Space Black | i7 2960XM | 16GB RAM | GTX 780M
defcon42 Posted February 2, 2022 Posted February 2, 2022 @Aaron44126 @Azther True that. I just tested the Grey Eve theme and it looks great. Thanks! Clevo P670HP6-G @OBSIDIAN-PC (2017), 17,3"//GTX1060//i7-7700HQ//512GB M2.SSD, external 32" UHD Display (defying BGA haters since day 1)😋
AXA Posted February 2, 2022 Posted February 2, 2022 @defcon42 you're welcome 🙂 Alienware M18X R2 | Nebula Red | i7 3740QM [OC'd to 4Ghz] | 32GB RAM | NVIDIA Quadro P4000 | 75hz OC'd Display | MXM to NVMe Adapter with Samsung 970 Evo Plus 2TB Alienware 17 R4 | i7 6700HQ | 16GB RAM | GTX 1070 | 100hz OC'd LG 1080p Display Alienware M18X R1 | Space Black | i7 2960XM | 16GB RAM | GTX 780M
aldarxt Posted February 3, 2022 Posted February 3, 2022 I made a tweak a number of years ago and cant find the txt settings any where, maybe on an old HDD but dont know which one and would like to know more about it if it does anything or not. Its in power options, advanced settings. Graphic Processor, GPU Power State, Plugged In. I just cant find anything on the web, Dont remember where I got it, But do remember it was regedit setting, I exported the setting and tried to install on another laptop but it didn't show up. Vague possibility maybe got it on NBR, but don't know if it made it into the Archives, Big IF Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4
Aaron44126 Posted February 3, 2022 Posted February 3, 2022 50 minutes ago, aldarxt said: I made a tweak a number of years ago and cant find the txt settings any where, maybe on an old HDD but dont know which one and would like to know more about it if it does anything or not. Its in power options, advanced settings. Graphic Processor, GPU Power State, Plugged In. I just cant find anything on the web, Dont remember where I got it, But do remember it was regedit setting, I exported the setting and tried to install on another laptop but it didn't show up. Vague possibility maybe got it on NBR, but don't know if it made it into the Archives, Big IF These settings live in: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings Maybe check there on the system that has it and see if you can figure out which subkey it is. Export from one machine and import onto another. Note that just because the setting exists doesn't mean it actually does anything. You can actually create any arbitrary advanced power options that you want in the registry. The GPU driver would have to look at the setting and take action on it for it to be of any use. 1 Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi
aldarxt Posted February 3, 2022 Posted February 3, 2022 29 minutes ago, Aaron44126 said: These settings live in: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings Maybe check there on the system that has it and see if you can figure out which subkey it is. Export from one machine and import onto another. Note that just because the setting exists doesn't mean it actually does anything. You can actually create any arbitrary advanced power options that you want in the registry. The GPU driver would have to look at the setting and take action on it for it to be of any use. Thanks for this info, I had been hoping this setting would add some performance but I see its just aesthetics for the unwary. Yes HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings is what I exported to install on my m6700 but won't need to now, it didn't work anyhow Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4
Aaron44126 Posted February 3, 2022 Posted February 3, 2022 7 minutes ago, aldarxt said: Thanks for this info, I had been hoping this setting would add some performance but I see its just aesthetics for the unwary. Yes HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Power\PowerSettings is what I exported to install on my m6700 but won't need to now, it didn't work anyhow For Precision M6700, install Dell Feature Enhancement Pack to get some additional advanced power settings (they live in the same spot) that actually work. Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi
aldarxt Posted February 3, 2022 Posted February 3, 2022 2 minutes ago, Aaron44126 said: For Precision M6700, install Dell Feature Enhancement Pack to get some additional advanced power settings (they live in the same spot) that actually work. Thanks, giving it a go now Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6 i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4
Aaron44126 Posted February 3, 2022 Posted February 3, 2022 4 minutes ago, aldarxt said: Thanks, giving it a go now "Thermal mode" is really the only one that's really interesting to me. I have profiles with it set to "Quiet" (actually limits CPU to 2.4 GHz) and "Ultra performance" for gaming. You can configure Process Lasso to automatically switch power profiles when certain apps run. Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi
Ishayin Posted February 4, 2022 Posted February 4, 2022 On 2/1/2022 at 8:06 PM, Aaron44126 said: I don't use any taskbar tweak programs right now, but I do have replacement for other parts of the Windows shell. I use Start11 (Start menu replacement) and Directory Opus (File Explorer replacement). If I could find a good taskbar replacement then I would check it out. I think that the taskbar could certainly be made more power user friendly. I hadn't heard of either of those before thanks. I've always used Total Commander for two panel large copy operations like backups, or sending music to portable music player etc. NexusFile is another option for this I know of (which uses a dark theme by default), mainly because I like the NexusFont font manager app from the same developer. Another useful one is Bulk Rename Utility which gives you a handy context menu entry for bulk renaming multiple files at once. Mainly I use it for adding or removing prefixes/suffixes to file names, but it can also do other things like numbering or replacing according to regular expressions. On 2/1/2022 at 8:06 PM, Aaron44126 said: Windows 11 has lost most taskbar customization functionality. You can't "ungroup" windows anymore, show text next to the taskbar icons, or show it on any side of the screen other than the bottom. I'm a bit miffed that there is no way to show seconds on the clock (either on the taskbar or in the flyout that appears when you click on the clock). You can get functionality back by forcing it to use the Windows 10 taskbar, which is still present, but that's a bit hacky/broken. OMG.. nooooo!! 😞 Well, hopefully someone will add it at some stage, or the Win10 hacky replacement will be improved. I can't see myself ever using it otherwise.
Mr. Fox Posted February 27, 2022 Posted February 27, 2022 The new StartIsBack for Windows 11 fixes everything wrong with the taskbar and start menu, and nothing is broken or malfunctioning as it is with the native hack. It fixes a lot of stuff that is jacked up with Windows 11's tacky UI, including the stupid looking and inefficient new right-click context menu. It made my Windows 11 look exactly as it does using StarIsBack on Windows 10. I refuse to use Windows 10 without StartIsBack. It is an essential as far as I am concerned. I install it as soon as I reach the desktop on a clean install, even before product activation or drivers. It made using Windows 11 a whole lot less disgusting, but it still had too many things about it that remained unacceptable to me, so I reclaimed the drive space it was wasting. WRAITH | X870E Apex | 9950X | RTX 5090 | 32GB DDR5 @ 8200 | O11 XL EVO | HC-500A Chiller BANSHEE | B850MPOWER | 4585PX | RTX 5080 | 48GB DDR5 @ 8000 | XT M3 Mr. Fox YouTube Channel | Mr. Fox @ HWBOT
Mr. Fox Posted May 31, 2024 Posted May 31, 2024 Seems like a fitting place to share this. @Raiderman posted something about this and I missed it, but check this out. It is not a Windows 7 theme. It actually replaced the Windows 11 GUI and numerous elements with Windows 7. This is Windows 11 so I will call it "7-11", no offense to Southland Corporation and their respectable convenience store chain. It even restored the Windows 7 Media Center. System resources are respectable, too. There is also a Vista GUI option. https://r8p.teknixstuff.com/ Besides low system resources, it seems like this GUI correction actually improved performance. This is much closer to Windows 7 wprime 32m performance than Windows 10/11 can do. Windows 10/11 wPrime 32m performance is normally horribly sluggish. 2 WRAITH | X870E Apex | 9950X | RTX 5090 | 32GB DDR5 @ 8200 | O11 XL EVO | HC-500A Chiller BANSHEE | B850MPOWER | 4585PX | RTX 5080 | 48GB DDR5 @ 8000 | XT M3 Mr. Fox YouTube Channel | Mr. Fox @ HWBOT
Papusan Posted June 3, 2024 Posted June 3, 2024 On 5/31/2024 at 6:51 AM, Mr. Fox said: Seems like a fitting place to share this. Is your taskbar suddenly crashing? Blame the latest Windows update Windows update KB5037853 rolled out helpful new features – and broke the taskbar for some people. A fix will now be sent out to affected users. 1 "The Killer" ASUS Z790 Apex Encore | 14900KS | 4090 HOF + 20 other graphics cards | 32GB DDR5 | Be Quiet! Dark Power Pro 12 - 1500 Watt | Second PSU - Cooler Master V750 SFX Gold 750W (For total of 2250W Power) | Corsair Obsidian 1000D | Custom Cooling | Asus ROG Strix XG27AQ 27" Monitors | Papusan @ HWBOT | Team PremaMod @ HWBOT | Papusan @ YouTube Channel
crz Posted June 4, 2024 Posted June 4, 2024 22 hours ago, Papusan said: Windows update KB5037853 rolled out helpful new features – and broke the taskbar for some people. A fix will now be sent out to affected users. It's such an obvious problem or flaw in order to just see it, but Microsoft probably still thinks that the end user continues to be the best tester). 1
kojack Posted February 18, 2025 Posted February 18, 2025 For taskbar and start menu tweaks I use translucentTB and power start menu. Translucent TB for removing all shading of the taskbar and power start menu to remove the silly recommended area and give it much better translucence as well. It all looks clean and modern. 1 Workstation - Dell XPS 8940 - desktop creative powerhouse Mobile Workstation - Dell inspiron 5406 2 in 1 - mobile creative beast Wifey's Notebook - Dell inspiron 3169 - Little gem for our businesses
