Reciever Posted August 22, 2023 Posted August 22, 2023 Good Evening ladies and gents, I have been slowly gathering some benchmarks for my hardware and eventually landed on Crysis 3. First issue, game was locked to 62 FPS, got this resolved by changing the vysnc to off and/or fast in Nvidia Control Panel. The next issue may not be an issue but just wanted to run it by some folks like @Mr. Fox , @electrosoft and maybe @jaybee83 ? Anyways I noticed that when looking out into the sea in the beginning of the game I notice the FPS jumps to around 200ish but doesnt hit full GPU utilization, then I look at a structure and the FPS goes straight to 120 on the dot. Is it the game or am I missing another tweak? Thanks in advance fellas AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX | 32GB DDR4 3200Mhz | 2TB NVME | 3x 1200w | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | P1000 | 9300i-16P | Intel X520 | 48TB HDD's | BeQuiet DP 13 1000w HomeLab | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
jaybee83 Posted August 22, 2023 Posted August 22, 2023 whats your setup again? subtoptimal gpu util points towards a bottleneck somewhere, either hardware based on cpu or RAM or potentially also game engine based. its been a few years since crysis 3 released, after all...u might wanna check online on the engine. as for hardware, whats your setup again? might wanna look into this nifty lil tool Intel just recently released, supposedly its great for identifying gpu/cpu bottlenecks: Mine: Hyperion "Titan God of Heat, Heavenly Light, Power" (2022-26) AMD Ryzen 9 9950X3D (delidded) / Asus ROG Crosshair X670E Extreme (Qualcomm QCNCM865 Wifi 7 Upgrade) / MSI Geforce RTX 5090 Suprim SOC / G.Skill Trident Z5 RGB DDR5-8000 2x24 GB / 4x Western Digital Black SN850P/X 8TB in 2x16TB RAID 0 / Arctic Liquid Freezer III Pro 420 (Push/Pull 6x Noctua NF-A14 IndustrialPPC-3000 exhaust) / Seasonic TX-1600 W Titanium / Phanteks NV9 MKII Black incl. Premium D-RGB Light Strips Kit (6x Arctic P14 Pro A-RGB black intake / 2x Arctic P14 Pro A-RGB black exhaust / 1x Arctic P14 Pro A-RGB black RAM cooling) / Samsung Odyssey Neo G8 32" 4K 240 Hz / Ducky One 3 Daybreak Fullsize Cherry MX Brown / Corsair M65 Ultra RGB / PDP Afterglow Wave Black / Beyerdynamic DT 770 Pro X Limited Edition My Lady's: Clevo NH55JNNQ "Alfred" (2022-26) Sharp LQ156M1JW03 FHD matte 15.6" IGZO 8 bit @248 Hz / Intel Core i5 12600 / Nvidia Geforce RTX 3070 Ti / Mushkin Redline DDR4-3200 2x32 GB / Samsung 970 Pro 1 TB / Samsung 870 QVO 8 TB / Intel AX201 WIFI 6+BT 5.2 / Win 11 Pro Phoenix Lite OS / 230 W PSU powered by Prema Mod!
Reciever Posted August 22, 2023 Author Posted August 22, 2023 Apologies, this is the setup 10850K @ 5.0Ghz 16GB DDR4 @ 4400Mhz RTX 3090 @ +100/+1200 @ 119% Power Limit Installed on SATA SSD 1300w PSU I have that tool installed, would have to spend some time with it to get familiar. Game doesnt seem to want to use more than 70% GPU utilization at the moment. I am not a fan of the Crysis IP so I am not very familiar with if it has any issues out of the box. Crysis 1 Remastered doesnt seem to have an issue using everything that is available to it. 1 AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX | 32GB DDR4 3200Mhz | 2TB NVME | 3x 1200w | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | P1000 | 9300i-16P | Intel X520 | 48TB HDD's | BeQuiet DP 13 1000w HomeLab | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
ryan Posted September 1, 2023 Posted September 1, 2023 I wouldn't go to burger King and ask the manager a question about engineering. But hey you never know. Gpu utilization is low because the cpu is the bottleneck due to the way it was programmed. Everyone that has the game will experience this. Crysis should be doing the same thing as the 2nd and third. They did not account for future 64 core cpus ZEUS-COMING SOON Omen 16 2021 Zenbook 14 oled Vivobook 15x oled
jaybee83 Posted September 1, 2023 Posted September 1, 2023 On 8/22/2023 at 1:41 PM, Reciever said: Apologies, this is the setup 10850K @ 5.0Ghz 16GB DDR4 @ 4400Mhz RTX 3090 @ +100/+1200 @ 119% Power Limit Installed on SATA SSD 1300w PSU I have that tool installed, would have to spend some time with it to get familiar. Game doesnt seem to want to use more than 70% GPU utilization at the moment. I am not a fan of the Crysis IP so I am not very familiar with if it has any issues out of the box. Crysis 1 Remastered doesnt seem to have an issue using everything that is available to it. what res are u testing it at? try and bump it up to the max. also set your gpu back to full stock, see if that does anything for the gpu utilization. if it does, might indeed be a cpu bottleneck potentially caused by the unoptimized engine. its at least capable to scaling up to 6 cores / 12 threads.... https://techreport.com/forums/viewtopic.php?t=86637 Mine: Hyperion "Titan God of Heat, Heavenly Light, Power" (2022-26) AMD Ryzen 9 9950X3D (delidded) / Asus ROG Crosshair X670E Extreme (Qualcomm QCNCM865 Wifi 7 Upgrade) / MSI Geforce RTX 5090 Suprim SOC / G.Skill Trident Z5 RGB DDR5-8000 2x24 GB / 4x Western Digital Black SN850P/X 8TB in 2x16TB RAID 0 / Arctic Liquid Freezer III Pro 420 (Push/Pull 6x Noctua NF-A14 IndustrialPPC-3000 exhaust) / Seasonic TX-1600 W Titanium / Phanteks NV9 MKII Black incl. Premium D-RGB Light Strips Kit (6x Arctic P14 Pro A-RGB black intake / 2x Arctic P14 Pro A-RGB black exhaust / 1x Arctic P14 Pro A-RGB black RAM cooling) / Samsung Odyssey Neo G8 32" 4K 240 Hz / Ducky One 3 Daybreak Fullsize Cherry MX Brown / Corsair M65 Ultra RGB / PDP Afterglow Wave Black / Beyerdynamic DT 770 Pro X Limited Edition My Lady's: Clevo NH55JNNQ "Alfred" (2022-26) Sharp LQ156M1JW03 FHD matte 15.6" IGZO 8 bit @248 Hz / Intel Core i5 12600 / Nvidia Geforce RTX 3070 Ti / Mushkin Redline DDR4-3200 2x32 GB / Samsung 970 Pro 1 TB / Samsung 870 QVO 8 TB / Intel AX201 WIFI 6+BT 5.2 / Win 11 Pro Phoenix Lite OS / 230 W PSU powered by Prema Mod!
Reciever Posted September 1, 2023 Author Posted September 1, 2023 2 hours ago, ryan said: I wouldn't go to burger King and ask the manager a question about engineering. But hey you never know. Gpu utilization is low because the cpu is the bottleneck due to the way it was programmed. Everyone that has the game will experience this. Crysis should be doing the same thing as the 2nd and third. They did not account for future 64 core cpus Im not asking the manager, clearly no one from CryEngine is here to discuss, Im talking to their customers to see if their experience at Burger King is the same as mine. 42 minutes ago, jaybee83 said: what res are u testing it at? try and bump it up to the max. also set your gpu back to full stock, see if that does anything for the gpu utilization. if it does, might indeed be a cpu bottleneck potentially caused by the unoptimized engine. its at least capable to scaling up to 6 cores / 12 threads.... https://techreport.com/forums/viewtopic.php?t=86637 2560x1440 Im guessing this is just what you can expect from Crysis 3, in Crysis 1 Remaster the utilization is maxed out pretty consistently, hadnt tried Crysis 2 yet. Not sure if I have it lol I moved on to get some testing going to get some testing going for the 2700x as I want to install the 5800X3D lol, gathering some data first is hurting my soul XD 1 AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX | 32GB DDR4 3200Mhz | 2TB NVME | 3x 1200w | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | P1000 | 9300i-16P | Intel X520 | 48TB HDD's | BeQuiet DP 13 1000w HomeLab | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
jaybee83 Posted September 3, 2023 Posted September 3, 2023 On 9/2/2023 at 1:08 AM, Reciever said: Im not asking the manager, clearly no one from CryEngine is here to discuss, Im talking to their customers to see if their experience at Burger King is the same as mine. 2560x1440 Im guessing this is just what you can expect from Crysis 3, in Crysis 1 Remaster the utilization is maxed out pretty consistently, hadnt tried Crysis 2 yet. Not sure if I have it lol I moved on to get some testing going to get some testing going for the 2700x as I want to install the 5800X3D lol, gathering some data first is hurting my soul XD kool man, let us know how theey compare on u got the data compiled 🙂 should be interesting! Mine: Hyperion "Titan God of Heat, Heavenly Light, Power" (2022-26) AMD Ryzen 9 9950X3D (delidded) / Asus ROG Crosshair X670E Extreme (Qualcomm QCNCM865 Wifi 7 Upgrade) / MSI Geforce RTX 5090 Suprim SOC / G.Skill Trident Z5 RGB DDR5-8000 2x24 GB / 4x Western Digital Black SN850P/X 8TB in 2x16TB RAID 0 / Arctic Liquid Freezer III Pro 420 (Push/Pull 6x Noctua NF-A14 IndustrialPPC-3000 exhaust) / Seasonic TX-1600 W Titanium / Phanteks NV9 MKII Black incl. Premium D-RGB Light Strips Kit (6x Arctic P14 Pro A-RGB black intake / 2x Arctic P14 Pro A-RGB black exhaust / 1x Arctic P14 Pro A-RGB black RAM cooling) / Samsung Odyssey Neo G8 32" 4K 240 Hz / Ducky One 3 Daybreak Fullsize Cherry MX Brown / Corsair M65 Ultra RGB / PDP Afterglow Wave Black / Beyerdynamic DT 770 Pro X Limited Edition My Lady's: Clevo NH55JNNQ "Alfred" (2022-26) Sharp LQ156M1JW03 FHD matte 15.6" IGZO 8 bit @248 Hz / Intel Core i5 12600 / Nvidia Geforce RTX 3070 Ti / Mushkin Redline DDR4-3200 2x32 GB / Samsung 970 Pro 1 TB / Samsung 870 QVO 8 TB / Intel AX201 WIFI 6+BT 5.2 / Win 11 Pro Phoenix Lite OS / 230 W PSU powered by Prema Mod!
