Csupati Posted September 11, 2023 Posted September 11, 2023 Hi ! There is an AW17 with HD8970m without battery and there is a performance problem , the gpu only runs at 450mhz . Is it possible that the performance is lowered because there is no battery ? Clevo P751TM1-G 8700K/16GB/GTX 1080@120W/1.5TB/FHD 144 G-Sync/ Asus PG279Q
Reciever Posted September 11, 2023 Posted September 11, 2023 1 hour ago, Csupati said: Hi ! There is an AW17 with HD8970m without battery and there is a performance problem , the gpu only runs at 450mhz . Is it possible that the performance is lowered because there is no battery ? I used to run my Ranger with no battery and didnt have those issues. May want to open HWINFO and try to get some limit reasons to try and narrow that down. AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX / Pulse 9070 XT (LSFG) | 32GB DDR4 3200Mhz | 2TB NVME | EVGA 1300w | NVME to 10Gbps | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | P1000 | 9300i-16P | 68TB HDD's | 5TB SSD's | BeQuiet DP 13 1000w ProxMox | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
Csupati Posted September 12, 2023 Author Posted September 12, 2023 11 hours ago, Reciever said: I used to run my Ranger with no battery and didnt have those issues. May want to open HWINFO and try to get some limit reasons to try and narrow that down. Ive sold the laptop and the feedback was that its doing this, i have heard today that the DC-DC circuit is often overloading if there is no battery present, probably dell bypass this problem with a bios update thats holds back the performance. Clevo P751TM1-G 8700K/16GB/GTX 1080@120W/1.5TB/FHD 144 G-Sync/ Asus PG279Q
Reciever Posted September 12, 2023 Posted September 12, 2023 4 hours ago, Csupati said: Ive sold the laptop and the feedback was that its doing this, i have heard today that the DC-DC circuit is often overloading if there is no battery present, probably dell bypass this problem with a bios update thats holds back the performance. I only ran mine up to A14 and later A14+ using 4930mx @ 4.3Ghz and a GTX 1070 @ 120w for about 220w power draw. Was also using 5 drives internally IIRC Sometimes the adapter warning could throw a fit to so I usually had that disabled. Without some limit reasons though it'll be like taking stabs in the dark AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX / Pulse 9070 XT (LSFG) | 32GB DDR4 3200Mhz | 2TB NVME | EVGA 1300w | NVME to 10Gbps | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | P1000 | 9300i-16P | 68TB HDD's | 5TB SSD's | BeQuiet DP 13 1000w ProxMox | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
Maxware79 Posted September 12, 2023 Posted September 12, 2023 There shouldn't be any issue running purely off the adapter. What wattage is the adapter that you supplied? If it's a 180W or lower then it's possible there isn't enough power being supplied. Alienware Aurora R15 - i9-13900KF - RTX 4090 - 32GB DDR5 Alienware X51 - i7-3770 - GTX 1060 - 16GB 1600Mhz DDR3 Alienware M17x R3 - i7-2760QM - GTX 580M - 16GB 1600Mhz DDR3 Alienware Area 51 ALX - i7-975 Extreme - GTX 980 - 16GB 1600Mhz DDR3 Alienware Aurora R2 - i7-3770K - GTX 670FTW - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 1060 - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 670FTW - 16GB 1600Mhz DDR3
Csupati Posted September 13, 2023 Author Posted September 13, 2023 10 hours ago, Maxware79 said: There shouldn't be any issue running purely off the adapter. What wattage is the adapter that you supplied? If it's a 180W or lower then it's possible there isn't enough power being supplied. Ive learnd in the past days , that the Alienware 17 was the first series laptop that had primary mosfet problems , and it lasted to all 6-7 th gen cpu 13-15-17 laptops , dell only managed to solve this problem with the 8.gen cpu series. Thats a litle bit dissapointing . Clevo P751TM1-G 8700K/16GB/GTX 1080@120W/1.5TB/FHD 144 G-Sync/ Asus PG279Q
Reciever Posted September 13, 2023 Posted September 13, 2023 3 hours ago, Csupati said: Ive learnd in the past days , that the Alienware 17 was the first series laptop that had primary mosfet problems , and it lasted to all 6-7 th gen cpu 13-15-17 laptops , dell only managed to solve this problem with the 8.gen cpu series. Thats a litle bit dissapointing . mosfets werent as robust as the M17x R4 and M18x R2 but never read that it had the same problems as the 17 R2 and newer as those issues would cause the CPU to run at 800mhz until at best a reboot flushes the system at worst stayed persistent. AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX / Pulse 9070 XT (LSFG) | 32GB DDR4 3200Mhz | 2TB NVME | EVGA 1300w | NVME to 10Gbps | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | P1000 | 9300i-16P | 68TB HDD's | 5TB SSD's | BeQuiet DP 13 1000w ProxMox | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
Csupati Posted September 13, 2023 Author Posted September 13, 2023 31 minutes ago, Reciever said: mosfets werent as robust as the M17x R4 and M18x R2 but never read that it had the same problems as the 17 R2 and newer as those issues would cause the CPU to run at 800mhz until at best a reboot flushes the system at worst stayed persistent. The gpu running at 450mhz instead of 900mhz,its a litle bit fustrating but its as is. Clevo P751TM1-G 8700K/16GB/GTX 1080@120W/1.5TB/FHD 144 G-Sync/ Asus PG279Q
ssj92 Posted September 14, 2023 Posted September 14, 2023 Try using msi afterburner to "overclock" the gpu by 5mhz or something and see if it helps. Sounds like it's stuck in P1 power state instead of P0 Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) Precision 7520 (T1000) | 7720 (Tesla P6) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
Csupati Posted September 14, 2023 Author Posted September 14, 2023 42 minutes ago, ssj92 said: Try using msi afterburner to "overclock" the gpu by 5mhz or something and see if it helps. Sounds like it's stuck in P1 power state instead of P0 Brand new battery and still 450mhz at load. I thinking about some power settings, or the charger . Its giving good display no fragments or artifacts, no lines on load its just in low power limit, vbios is stock original. The worst os that ive sold the laptop and the buyer have problem with it. Clevo P751TM1-G 8700K/16GB/GTX 1080@120W/1.5TB/FHD 144 G-Sync/ Asus PG279Q
Maxware79 Posted September 14, 2023 Posted September 14, 2023 You can run the system diagnostic in the F12 Boot Menu and see what current the adapter is supplying the system. Just to cross off that possibility. Alienware Aurora R15 - i9-13900KF - RTX 4090 - 32GB DDR5 Alienware X51 - i7-3770 - GTX 1060 - 16GB 1600Mhz DDR3 Alienware M17x R3 - i7-2760QM - GTX 580M - 16GB 1600Mhz DDR3 Alienware Area 51 ALX - i7-975 Extreme - GTX 980 - 16GB 1600Mhz DDR3 Alienware Aurora R2 - i7-3770K - GTX 670FTW - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 1060 - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 670FTW - 16GB 1600Mhz DDR3
Csupati Posted September 14, 2023 Author Posted September 14, 2023 5 hours ago, Maxware79 said: You can run the system diagnostic in the F12 Boot Menu and see what current the adapter is supplying the system. Just to cross off that possibility. It has been tested with diagnostics and no error came back. Clevo P751TM1-G 8700K/16GB/GTX 1080@120W/1.5TB/FHD 144 G-Sync/ Asus PG279Q
Reciever Posted September 14, 2023 Posted September 14, 2023 Still need a adapter info and hwinfo. Like I said I ran my R1 with no battery and had no issues at all, the cause is elsewhere in the system. AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX / Pulse 9070 XT (LSFG) | 32GB DDR4 3200Mhz | 2TB NVME | EVGA 1300w | NVME to 10Gbps | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | P1000 | 9300i-16P | 68TB HDD's | 5TB SSD's | BeQuiet DP 13 1000w ProxMox | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
Csupati Posted September 14, 2023 Author Posted September 14, 2023 7 hours ago, Reciever said: Still need a adapter info and hwinfo. Like I said I ran my R1 with no battery and had no issues at all, the cause is elsewhere in the system. He will test it with an another psu, and will inform me. 13 hours ago, Maxware79 said: You can run the system diagnostic in the F12 Boot Menu and see what current the adapter is supplying the system. Just to cross off that possibility. 1 Clevo P751TM1-G 8700K/16GB/GTX 1080@120W/1.5TB/FHD 144 G-Sync/ Asus PG279Q
Maxware79 Posted September 15, 2023 Posted September 15, 2023 I'm assuming that the 210W adapter will be enough power. Can't say that I've ever seen a 210W for these machines. They usually shipped with a 240W from my experience. Alienware Aurora R15 - i9-13900KF - RTX 4090 - 32GB DDR5 Alienware X51 - i7-3770 - GTX 1060 - 16GB 1600Mhz DDR3 Alienware M17x R3 - i7-2760QM - GTX 580M - 16GB 1600Mhz DDR3 Alienware Area 51 ALX - i7-975 Extreme - GTX 980 - 16GB 1600Mhz DDR3 Alienware Aurora R2 - i7-3770K - GTX 670FTW - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 1060 - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 670FTW - 16GB 1600Mhz DDR3
Csupati Posted September 15, 2023 Author Posted September 15, 2023 12 hours ago, Maxware79 said: I'm assuming that the 210W adapter will be enough power. Can't say that I've ever seen a 210W for these machines. They usually shipped with a 240W from my experience. So, another charger and still the cards is staying at 450mhz core , brand new battery, fresh windows amd drivers, and still no luck, how the hell can it work at half performance but the games graphics are ok, no fragments or stripes on the screen. Clevo P751TM1-G 8700K/16GB/GTX 1080@120W/1.5TB/FHD 144 G-Sync/ Asus PG279Q
Reciever Posted September 15, 2023 Posted September 15, 2023 HWINFO64 should give you limit reasons AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX / Pulse 9070 XT (LSFG) | 32GB DDR4 3200Mhz | 2TB NVME | EVGA 1300w | NVME to 10Gbps | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | P1000 | 9300i-16P | 68TB HDD's | 5TB SSD's | BeQuiet DP 13 1000w ProxMox | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
Csupati Posted September 15, 2023 Author Posted September 15, 2023 I advised him to get a gpu-z and check perf.cap reason. 1 Clevo P751TM1-G 8700K/16GB/GTX 1080@120W/1.5TB/FHD 144 G-Sync/ Asus PG279Q
Maxware79 Posted September 17, 2023 Posted September 17, 2023 On 9/16/2023 at 1:47 AM, Csupati said: So, another charger and still the cards is staying at 450mhz core , brand new battery, fresh windows amd drivers, and still no luck, how the hell can it work at half performance but the games graphics are ok, no fragments or stripes on the screen. Could it just reporting incorrectly while performing properly? Alienware Aurora R15 - i9-13900KF - RTX 4090 - 32GB DDR5 Alienware X51 - i7-3770 - GTX 1060 - 16GB 1600Mhz DDR3 Alienware M17x R3 - i7-2760QM - GTX 580M - 16GB 1600Mhz DDR3 Alienware Area 51 ALX - i7-975 Extreme - GTX 980 - 16GB 1600Mhz DDR3 Alienware Aurora R2 - i7-3770K - GTX 670FTW - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 1060 - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 670FTW - 16GB 1600Mhz DDR3
Csupati Posted September 18, 2023 Author Posted September 18, 2023 18 hours ago, Maxware79 said: Could it just reporting incorrectly while performing properly? Maybe .... Gpu usage 100% d3d usage 100% but its showing 450/300 core /memory freq. Enduro dosnt switch properly? Maybe Enduro is bad:Enduro last supported version is 2019. ill will advise to check this and i will report back. Verdict! : the 210W power supply is not enough, with the 240w psu everything works well, its boosting to 900/1250mhz. He wisited me at my techinician/laptop guru friend , we tested with a 240w psu and its instantly boosted . 2 Clevo P751TM1-G 8700K/16GB/GTX 1080@120W/1.5TB/FHD 144 G-Sync/ Asus PG279Q
Maxware79 Posted September 18, 2023 Posted September 18, 2023 Well that's good news, glad you got it figured out. Like I said before, I hadn't seen these with a 210W adapter so I thought it could be that. I wasn't 100% sure that 30W would make that big of a difference but apparently it does. Alienware Aurora R15 - i9-13900KF - RTX 4090 - 32GB DDR5 Alienware X51 - i7-3770 - GTX 1060 - 16GB 1600Mhz DDR3 Alienware M17x R3 - i7-2760QM - GTX 580M - 16GB 1600Mhz DDR3 Alienware Area 51 ALX - i7-975 Extreme - GTX 980 - 16GB 1600Mhz DDR3 Alienware Aurora R2 - i7-3770K - GTX 670FTW - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 1060 - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 670FTW - 16GB 1600Mhz DDR3
Reciever Posted September 18, 2023 Posted September 18, 2023 38 minutes ago, Maxware79 said: Well that's good news, glad you got it figured out. Like I said before, I hadn't seen these with a 210W adapter so I thought it could be that. I wasn't 100% sure that 30W would make that big of a difference but apparently it does. Its possible that while the system can detect the the 210w adapter it may not be a part of the "approved" adapters for the system. I believe the Ranger shipped with the 180w/240w but that logic kind of breaks down a bit when considering the 330w I personally as well as others have used for the system. Kind of puzzling. AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX / Pulse 9070 XT (LSFG) | 32GB DDR4 3200Mhz | 2TB NVME | EVGA 1300w | NVME to 10Gbps | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | P1000 | 9300i-16P | 68TB HDD's | 5TB SSD's | BeQuiet DP 13 1000w ProxMox | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
ssj92 Posted September 19, 2023 Posted September 19, 2023 180w/240w/330w are the only ones that will work properly on m17x r3/r4/17 r1 210w are for older systems. Glad you got it figured out. I always use 240/330w only with these systems Alienware Area-51M : Intel Core i9-9900K @ 5.3Ghz | nVidia GeForce RTX 2080 | AX210 | Samsung 970 Evo+ Alienware M18x R2 : Intel Core i7 3920XM @ 4.7Ghz | nVidia GeForce RTX 3080 | AX210 | Samsung 980 PRO Alienware 18 : Intel Core i7 4930MX @ 4.5Ghz | nVidia Quadro RTX 5000 | AX210 | Samsung 980 NVMe More Laps: M14x | M14xR2 | M15x (980m) | M17xR2 (RTX 3000) | M17xR3 (WX 7100) | M18xR1 (RTX 5000) Precision 7520 (T1000) | 7720 (Tesla P6) BEAST Server: Intel Xeon W7-3465X 28 P-Cores | 2x nVidia RTX Titan | 128GB RDIMM | Intel Optane P5800X CS Studios YouTube: https://www.youtube.com/c/CSStudiosYT
