On 12/24/2023 at 1:48 PM, razor0601 said:
Which panels will work in P775TM1-G  with 6-43-P7751-010-1N cable?
Thats a regular edp 40 pin, you can fit any sreen you want, unfortunatly theres no oled at 17.3" , but theres mini led.
Fhd qhd 4k screens gonna fit át any refresh rate, only issue can be the brightness, it may only have full brightness.
Do you know what the panel number is for the 17.3" 4k Mini LED panel is?
  • Previous lives: D900F / P150HM / P150EM / P870DM2 / X170KM
  • Testing/Backup Rig - P750DM2 - **in process** - *Build Thread*
  • Wife's Daily - P750DM2- 4k Panel / 6700k / 1060 GTX / 64GB DDR4 3200Mhz Corsair Vengeance / 1TB Samsung 970 Plus / 2TB WD Black SN770 / Killer Wifi
  • Self Daily - P750DM2 (2016) - Dsanke BIOS / 8700k (2017) / 2080 RTX (2019) / 64GB DDR4 3200Mhz CL16 Ballistix / ETC
  • Determined to keep the socketed 15.6" laptops alive as long as possible!!
B173ZAN06.6
On 12/26/2023 at 12:21 AM, 1610ftw said:
Nice panel indeed but with the connector on the other side.
This is a regular panel:
and here the UHD 120Hz panel:
Tbh I do not know if the 775 cable is long enough. On the 870 you could fit one of those with a 775 cable.
Something to consider!
Also I would NOT be pleased if I lost the ability to adjust brightness with a 1000nits LED panel so not sure if that could also be an issue with that panel.
I had that problem with a QHD panel that I put into an MSI and it was already annoying to always have about 400 nits even in the dark - it was basically unusable for me without the ability to adjust brightness.
Oh well, I guess there are always sunglasses when you cannot turn down the brightness for that 1000 nits LED monster 😎
  • 4 months later...
The newest ones 4K MiniLED I know at the moment are:
AUO B173ZAN06.6 (120Hz, 512 zones)
AUO B173ZAN06.A (120Hz, 512 zones)
AUO B173ZAN06.C (144Hz, 1008 zones)
  • 8 months later...
On 11/15/2023 at 4:34 PM, anassa said:
@Developer79 Thanks for that!
From what @razor0601 I had the money I would love to try this one:
  • Samsung ATNA56AC01 = 3k (2880x1620) / 120hz / HDR / AMOLED ~ $300
Those specs for the panel look amazing!
Maybe someday . . .
i happen to have a P750dm3-G and an ATNA56AC01 (one piece flat bottom) sitting new in box.
Am I too old of a laptop?  Do I even have a 40pin connector?
i’ll be back for answers and field questions too.
Guys.  After shopping my model number on websites in mandarin, I’m convinced that P750dm3-g isers have a 30pin eDP cable.
Can anyone confirm?
i want to do my Heatsink, GPU, Screen, Cable, Audio board, and display cable all in one go and leave this thing sealed for a while.
Use this for reference when upgrading displays.
Also take in consideration that newer models of displays have emerged since P870/775/750 era, and that more better displays cand be compatible.
So its almost like you took exactly what we said and ignored all of the key points where we talking about a specific, newer display… Like, I’m just going to order the Clevo/Samsung 30pin to 40 pin adaptor and hope that works since customer service didn’t hear either of our question and yes, the thing was plugged in and in the “on” position.
You do not need an adaptor, you just need the 40pin edp cable.
So turns out despite me constantly seeing 30pin Clevo eDP for 15.6” Clevos, I could have simply looked at my motherboard and found out that there’s a nice “P775DM2MB-0D” stamped underneath my keyboard.
I’m going to upgrade to the Dell/Alienware 1440p and 240hz screen brand new with a 40pin eDP with part number 6-43-PC701-011-1N and when I found out that’s too new of a cable, I’ll have part number 6-43-P7751-020-1L here on Friday! (Which makes more sense)
