cisik88 Posted October 21, 2023 Posted October 21, 2023 Hello, did anyone tried or read somewhere if it's possible to install motherboard from r5 model to r4 case? Motherboards looks very similar, there are few minor differences but maybe someone pulled that off and can advice if it's worth the trouble?
Maxware79 Posted October 24, 2023 Posted October 24, 2023 On 10/21/2023 at 11:11 PM, mtvgt said: Hello, did anyone tried or read somewhere if it's possible to install motherboard from r5 model to r4 case? Motherboards looks very similar, there are few minor differences but maybe someone pulled that off and can advice if it's worth the trouble? They do look remarkably similar but there are a few very small differences with some connectors and the PCB that may make it hard or impossible. Check out along the bottom edge. Alienware Aurora R15 - i9-13900KF - RTX 4090 - 32GB DDR5 Alienware X51 - i7-3770 - GTX 1060 - 16GB 1600Mhz DDR3 Alienware M17x R3 - i7-2760QM - GTX 580M - 16GB 1600Mhz DDR3 Alienware Area 51 ALX - i7-975 Extreme - GTX 980 - 16GB 1600Mhz DDR3 Alienware Aurora R2 - i7-3770K - GTX 670FTW - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 1060 - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 670FTW - 16GB 1600Mhz DDR3
cisik88 Posted November 10, 2023 Author Posted November 10, 2023 Hello, thanks for reply. At the end i decided not to try this. Motherboards are still quite expensive and i didn't want to risk so i went other way with different model.
Batfinks Posted October 12, 2024 Posted October 12, 2024 the Alienware 17 R5 motherboard will go into an Alienware 17 r4 and vice versa, you just need to move the heatsink and fans over with the board, ive done it myself. i have an alienware 17 r5 board + heatsink/fans in a r4 body. i also have a r5 motherboard in a alienware 15 r3 body also !!! and just for fun, the r4 motherboard goes into the r5 body providing you move the heatsink and fans over with it, same with the 15" also :D 1
ShifflyTheSHO Posted March 16, 2025 Posted March 16, 2025 I accidentally ordered an m17 R4 motherboard with a 2080MQ and 8950hk to replace my bad 17R4 motherboad that was a 1070 and 7700hk. The connections at the bottom of the board are moved to the left and some external ports are different, so would drilling the case and moving the ribbons work? everybody wants like $500 dollars for a board that will ultimately fail like the original, my pay double for less!?
ShifflyTheSHO Posted April 23, 2025 Posted April 23, 2025 On 10/21/2023 at 7:41 AM, mtvgt said: Hello, did anyone tried or read somewhere if it's possible to install motherboard from r5 model to r4 case? Motherboards looks very similar, there are few minor differences but maybe someone pulled that off and can advice if it's worth the trouble? Just got done with mine, only one new connector and no Recovery installed at first, and my touchpad backlight doesn’t work, if anyone has any solutions? How do you get your touchpad backlight to function? my 17R4 works with eitber pas or ribbon/plate, but my 17R5 board is having that as the final issue!
kyle2k80 Posted September 19 Posted September 19 On 10/12/2024 at 5:21 PM, Batfinks said: the Alienware 17 R5 motherboard will go into an Alienware 17 r4 and vice versa, you just need to move the heatsink and fans over with the board, ive done it myself. i have an alienware 17 r5 board + heatsink/fans in a r4 body. i also have a r5 motherboard in a alienware 15 r3 body also !!! and just for fun, the r4 motherboard goes into the r5 body providing you move the heatsink and fans over with it, same with the 15" also 😄 Hello, Do you think it's possible to convert the 15 r3 into an 17r4 chassis? Got a 15 r3 that needs a new keyboard and palmrest but If I can find the parts I was tempted to convert it into an R4.. Let me know!
