Aaron44126 Posted February 6, 2024 Author Share Posted February 6, 2024 3 hours ago, DietmarP said: 1. when I start my 3 years old Dell Inspiron 7590 the fans are running after a few minutes, but when I start Dell Fan Management in Automatic operation mode, they stop for a while. What does Dell Fan Management change? 2. Using Dell Power Manager (or Dell Fan Management), the thermal settings won't match. Quiet and Performance thermal setting seems to be same, and the fans are spinning at max. 1. At startup, Dell Fan Management sets the configuration to whatever it was last time that you had it open, and it issues commands to the EC accordingly, even if those match what the EC is already set to. When doing this, the EC fan behavior is "reset" and that will sometimes cause it to turn off the fans for a while. You can also sometimes replicate this by changing the thermal mode in Dell's own tools (balanced to quiet and then immediately back to balanced, or something like that). 2. This isn't a surprise. Dell's fan tables don't necessarily make sense in all systems. I don't think that they put as much time into tuning these as they should. In my Precision 7560 I have observed that "Quiet" often runs the fans higher than "Balanced" for an idle workload, but I use it anyway because "Balanced" is more sensitive to changes in CPU load, and "Quiet" also runs the fans at a lower speed under an "intense" workload. 1 Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi Link to comment Share on other sites More sharing options...
DietmarP Posted February 6, 2024 Share Posted February 6, 2024 (edited) That explains it. Many thanks for the quick reply. Yes, switching between Optimized and Cool sometimes, when the temperature is below 60°C, turns the fans off. FYI: I have asked the question in the Dell community in January, no answer up to now. https://www.dell.com/community/en/conversations/inspiron/inspiron-7590-thermal-settings-mismatch/65b3c607a51f722bfe80a4b0 PS: I was playing around with "consistency" mode, but that setting allows 0, 3200, and 4900 rpm, not the "silent" 2200 rpm that the manual mode allows. Edited February 6, 2024 by DietmarP PS added Link to comment Share on other sites More sharing options...
Aaron44126 Posted February 6, 2024 Author Share Posted February 6, 2024 6 hours ago, DietmarP said: PS: I was playing around with "consistency" mode, but that setting allows 0, 3200, and 4900 rpm, not the "silent" 2200 rpm that the manual mode allows. Consistency mode is there to allow you to select an RPM that the EC normally picks and "lock it in", if the EC sometimes picks something other than the manual choices that you would prefer. For instance, on my M6700, the manual "medium" set it to around 2200 RPM, but the EC in "automatic" would sometimes set the fans to around 1900 RPM which I would prefer. So I would put the RPM threshold at 2000 RPM. When the EC selected 1900 RPM, EC fan control would be disabled without actually changing the speed, so it would be locked at 1900 RPM. 1 Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi Link to comment Share on other sites More sharing options...
DietmarP Posted February 7, 2024 Share Posted February 7, 2024 Interesting. As stated above, on my 7590 EC normally selects 3200 RPM and that will be locked in by the consistency mode. Stupid idea: Now, Dell Fan Management sets (resets) the current settings at startup. What if the "reset" will be done every minute? That would keep the fans off if not needed. Link to comment Share on other sites More sharing options...
Aaron44126 Posted February 7, 2024 Author Share Posted February 7, 2024 4 hours ago, DietmarP said: Stupid idea: Now, Dell Fan Management sets (resets) the current settings at startup. What if the "reset" will be done every minute? That would keep the fans off if not needed. You could achieve this with Task Scheduler and see what happens. DellFanManagement.exe supports command line parameters so you can tell it to enable EC fan control, disable EC fan control, set a specific speed, and so on. (Run it from the terminal with a junk parameter like -? to see what the options are.) Running DellFanManagement.exe from Task Scheduler requires you to use the checkbox for "run with highest privileges" so that it can load the BZH driver. You should not run DellFanManagement from the command line while the GUI app is running. Running it from the command line will cause it to do its job and then unload the BZH driver while closing, which would then make the GUI app unable to issue any EC commands. You can also try using SpeedFan which allows you to set more complex fan behaviors based on temperatures. You could have it keep the fans off until the CPU reaches a certain temperature, for example. The requirements for using SpeedFan are: You have to check a box in SpeedFan config to enable Dell fan support. You have to have automatic EC fan control turned off, or SpeedFan's fan changes will keep getting overridden by the EC. (DellFanManagement can do this, from the GUI or from the command line.) Note also that while SpeedFan supports granular fan curves, when used on a Dell laptop you will still be limited to just three fan speeds ("off" / "medium" / "high"), so really you can just set the fan curves to 0% / 50% / 100%. 1 Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi Link to comment Share on other sites More sharing options...
DietmarP Posted February 7, 2024 Share Posted February 7, 2024 Thanks a lot for your answer. I see 4 fan speeds on my Dell, 0, 2200, 3200, and 4900. EC supports the RPMs in bold. I will check what I can do with the Task Scheduler. To be honest, I am looking for a "set and forget" solution but I see a risk in switching EC off. I always must keep an eye on the temperature. Link to comment Share on other sites More sharing options...
Aaron44126 Posted February 7, 2024 Author Share Posted February 7, 2024 9 hours ago, DietmarP said: Interesting. As stated above, on my 7590 EC normally selects 3200 RPM and that will be locked in by the consistency mode. 29 minutes ago, DietmarP said: Thanks a lot for your answer. I see 4 fan speeds on my Dell, 0, 2200, 3200, and 4900. Yeah, there is where consistency mode could come into play. It might not be the behavior that you are looking for, but you could set the RPM threshold to 2500, and it should lock you in at the 2200 speed (when the EC selects it). It will "unlock" the speed and allow the fans to rev up if one of the temperatures exceeds the upper temperature threshold. I would normally set the upper temperature threshold pretty high, like 95 °C, so the fans only spun up when it was really necessary. I mostly implemented this because I hated the on again / off again behavior of the fans in the M6700. It makes a very obvious sound when the fans power on after being off. This way, the fans can be locked at a low speed but never turn off. 1 Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi Link to comment Share on other sites More sharing options...
DietmarP Posted February 7, 2024 Share Posted February 7, 2024 I am sorry, there is a misunderstanding. EC will not set 2200 RPM, only manual mode medium is able to set that fan speed. Consistency mode will lock in 3200 RPM (see screenshot above from today). Link to comment Share on other sites More sharing options...
Aaron44126 Posted February 7, 2024 Author Share Posted February 7, 2024 14 minutes ago, DietmarP said: I am sorry, there is a misunderstanding. EC will not set 2200 RPM, only manual mode medium is able to set that fan speed. Consistency mode will lock in 3200 RPM (see screenshot above from today). OK, I guess I interpreted your post above wrong. The M6700 (what I built this for) had probably five or six different speed levels that the EC would select in automatic mode, and one of them was above "0" but below what "manual medium" would produce. It also had one higher than what "manual high" would produce so I ended up switching EC back to automatic mode when I was running intense workloads. 1 Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi Link to comment Share on other sites More sharing options...
DietmarP Posted February 9, 2024 Share Posted February 9, 2024 Finally, I am using HWiNFO64. The app supports 0, 2200, and 4900 RPM. I have set the spin-down to 45 sec and a sound alarm for >= 85°C and I show an icon with the actual temperature in the tray which is typically around 60°C on AC and 50°C on battery. Peaks around 80°C only when I start several apps like Chrome and Photos or Outlook. At no time above 85°C. Turbo mode switched off, of course. Link to comment Share on other sites More sharing options...
spiderhans Posted March 14, 2024 Share Posted March 14, 2024 Hi @Aaron44126, Could you please reupload release 3.0? Thanks beforehand. Link to comment Share on other sites More sharing options...
raptorddd Posted March 27, 2024 Share Posted March 27, 2024 On 3/14/2024 at 3:00 AM, spiderhans said: Hi @Aaron44126, Could you please reupload release 3.0? Thanks beforehand. i tried to download but asks for one drive account does that mean its not available.? dell precision m4600 i7 2760QM 8GB ram MX500 crucial SSD 500GB. win 10 21H2 Link to comment Share on other sites More sharing options...
krustybbr Posted August 6, 2024 Share Posted August 6, 2024 I have laptoop dell 7567, but not work, can u send me correct version now? 2 year old i was using normal Link to comment Share on other sites More sharing options...
Aaron44126 Posted August 10, 2024 Author Share Posted August 10, 2024 I posted a new link that will not expire. This is the final public build; I'm not working on this project anymore, and I do not plan to address any of the remaining issues, since I don't even have ready access to any systems that I can test with anymore. (Dell blocked all known fan control mechanisms as of their 2021 systems.) Anyone is welcome to take the code that I have published on GitHub and work with it. https://1drv.ms/u/s!AsIwJHFk4EFdqNc2I45BxBqHhwaKIA?e=YjUSPn 2 Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi Link to comment Share on other sites More sharing options...
Almighty1 Posted August 14, 2024 Share Posted August 14, 2024 On 3/14/2024 at 3:00 AM, spiderhans said: Hi @Aaron44126, Could you please reupload release 3.0? Thanks beforehand. Where did you even get the version for the release from as it just says dev version but no version number is shown anywhere. Link to comment Share on other sites More sharing options...
Aaron44126 Posted August 14, 2024 Author Share Posted August 14, 2024 56 minutes ago, Almighty1 said: Where did you even get the version for the release from as it just says dev version but no version number is shown anywhere. Err, I am the software author so I generated that build. It is an internal work-in-progress build. The 3.0 version never had a final release. 1 Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi Link to comment Share on other sites More sharing options...
Almighty1 Posted September 1, 2024 Share Posted September 1, 2024 On 8/14/2024 at 1:30 PM, Aaron44126 said: Err, I am the software author so I generated that build. It is an internal work-in-progress build. The 3.0 version never had a final release. I think you misunderstood my comment as obviously, I know you are the software author and released the build. My question to the person I quoted originally where was the v3.0 even mentioned because the person I am quoting asked specifically for release v3.0 and in all the internal work-in-progress builds, it never shows the build number as it will says "Dell Fan Management, version DEV" as seen below, I always label the folder based on the date you posted it so I will always have whatever you release as the latest even though it might be more helpful if it did list something after version like the date or something to distinguish the different published builds provided. Link to comment Share on other sites More sharing options...
Aaron44126 Posted September 1, 2024 Author Share Posted September 1, 2024 Yes, previous builds did have version numbers. The build that I have posted is a development snapshot and has all of the latest changes; it is just what I had available to post. As there will be no further development (by me), I won't be releasing any more versioned builds. I don't even have ready access to the build chain right now, my new personal system is a Mac and the Precision system that I was using to build this software is now running Linux. 2 Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi Link to comment Share on other sites More sharing options...
Almighty1 Posted September 1, 2024 Share Posted September 1, 2024 First of all Aaron, thanks for releasing the software since it does help greatly with the Dell XPS 15 9570. I don't remember when I discovered Dell Fan Management but I recall even the first build I downloaded was from December 11, 2022 didn't have a build number either so everytime you posted a link, I just name the folder based on the date of the post itself. I realize there is no further development as I know you mentioned atleast a few months ago and more recently, you already moved to a different system and not even running Windows anymore either and you also mentioned that Dell locked down things. Link to comment Share on other sites More sharing options...
WhenLarryHadABaby Posted January 26, 2025 Share Posted January 26, 2025 Thanks for the app. But GTA V runs extremely laggy when the app is started. Any tips? It's when it's on manual with EC off. When I turn "automatic" on and EC on it works. Dell Fan Utility works with GTA V, but it reset after a shutdown. So Dell Fan Management would be perfect. Just add it to task scheduler and I'm good to go. Link to comment Share on other sites More sharing options...
John Posted February 23, 2025 Share Posted February 23, 2025 Hello, I have a problem with Inspirion 5577. After starting Windows, the laptop starts the fans first at ~50% and then at 100%. The same thing happens in Windows 10 and 11, all BIOS versions from 1.0.1 to 1.13 did not help. I tested different versions of Dell Fan Management, nothing helps. "Consistency mode" does not work, "thermal settings" too. The only thing is the reaction to turning off EC and the "manual control" option and that would be enough, but after setting it to 50% RPM or OFF, the laptop returns to the original settings from EC after 3-4 seconds. The fans at a temperature of 30 GPU and 40-45 CPU from ~2000 RPM jump to ~3000 RPM despite working in IDLE. Running the fan1-level1 command in DFM v2 every 3 seconds helps, which eliminates the return to EC settings. Please help what could be the cause. Maybe the previous owner reballed the GPU and blocked the EC speed so that the chip wouldn't overheat? To summarize, the fans in IDLE mode operate at 3000 RPM!. A script that runs the fan1-level1 and fan2-level1 commands would help, but I don't know how to do it. Please help. Link to comment Share on other sites More sharing options...
Almighty1 Posted April 28, 2025 Share Posted April 28, 2025 Have a question, where are the settings actually stored as recently, it seems like my EC Fan control off button is no longer showing the full circle, I have tried replacing all the files and it is reading the settings from somewhere. Thanks! Link to comment Share on other sites More sharing options...
Aaron44126 Posted April 28, 2025 Author Share Posted April 28, 2025 12 hours ago, Almighty1 said: Have a question, where are the settings actually stored as recently, it seems like my EC Fan control off button is no longer showing the full circle, I have tried replacing all the files and it is reading the settings from somewhere. Thanks! Settings are in the registry. HKEY_CURRENT_USER\SOFTWARE\Dell Fan Management 1 Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi Link to comment Share on other sites More sharing options...
Almighty1 Posted April 30, 2025 Share Posted April 30, 2025 On 4/28/2025 at 5:10 AM, Aaron44126 said: Settings are in the registry. HKEY_CURRENT_USER\SOFTWARE\Dell Fan Management Many thanks Aaron, even though it didn't fix the problem but good to know where it's located when needed. Link to comment Share on other sites More sharing options...
