IL19 Posted February 13, 2022 Posted February 13, 2022 Hello there! Apologies if asking this in a wrong section or on a wrong forum (if thats the case, feel free to recommend us where we should ask for advice instead 😃 ). So we are a bit stuck with upgrading Alienware 18 2013 version (R3 Viking, if I am not mistaken) with a GTX 1070. Great source of guideness has been NotebookReview Forums, but unfortunately it was shot down. Our main issue right now is that GPU fan will not start no matter how hot Graphic Card gets. We are using unlocked A12 Bios and didn't find any fan related settings in there. Graphic Card that we are upgrading to is Nvidia GTX1070 MXM 3.0b from Zotac manufacturer I think (uploaded a photo). Regarding vBios we tried an original Zotac version and a version thats for Dell laptops with the same results. Furthermore when using Dell vBios GPU won't go above 139 MHz for some reason. Any kind of help or advice would be much appreciated. If I should have provided some extra info, please let me know :) Alienware 18 A12 Unlocked.zip
Maxware79 Posted February 13, 2022 Posted February 13, 2022 I would keep trying vBIOS versions until you find one that works but, as always, flash at your own risk. This is usually the issue when there is no automatic fan control.  I'm assuming that you have the system in SG mode to run the 1070 so the card shouldn't heat up when you're just in the Windows desktop. 1 Alienware Aurora R15 - i9-13900KF - RTX 4090 - 32GB DDR5  Alienware X51 - i7-3770 - GTX 1060 - 16GB 1600Mhz DDR3  Alienware M17x R3 - i7-2760QM - GTX 580M - 16GB 1600Mhz DDR3 Alienware Area 51 ALX - i7-975 Extreme - GTX 980 - 16GB 1600Mhz DDR3  Alienware Aurora R2 - i7-3770K - GTX 670FTW - 16GB 1600Mhz DDR3 Alienware Aurora R4 ALX - i7-3930K - GTX 1060 - 16GB 1600Mhz DDR3    Alienware Aurora R4 ALX - i7-3930K - GTX 670FTW - 16GB 1600Mhz DDR3 Â
Reciever Posted February 14, 2022 Posted February 14, 2022 Zotac 1070 needed the MSi vBIOS in order to work on the internal panel for the Ranger (17 R1) I assume that may be the case for the AW18 as well  What also tends to help is installing an RDP protocol so you can remote to the system, grants a little more flexibility when hashing out this process. 1 AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX | 32GB DDR4 3200Mhz | 2TB NVME | 3x 1200w | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | P1000 | 9300i-16P | Intel X520 | 48TB HDD's | BeQuiet DP 13 1000w HomeLab | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo! Â
Tenoroon Posted February 14, 2022 Posted February 14, 2022 Reciever is correct, if you cannot find an MSI vBIOS, I can dump mine if needed. 2 Clevo P870TM-G: Core i7 8700k @ 4.8ghz | Clevo RTX 2070 Super | 32gb HyperX DDR4 @ 3200mhz | 17" 1440p 120hz B173QTN01.0 Screen | 256gb Samsung 850 EVO | 500gb WD Blue SSD | Prema BIOS  Alienware 17 R1: Core i7 4710mq @ 3.619ghz 741 CBR15 (834 CBR15 @ 4.213ghz) | Dell GTX 860m | 16gb HyperX DDR3L @ 2133mhz | 17" 3D 120hz LTN173HT02-T01 Screen | 256gb mSATA SSD Asus Zephyrus G14: Ryzen 7 4800hs @ 4.2ghz | GTX 1650 | 16gb DDR4 @ 3200mhz | 14" 120hz LM140LF1F01 Screen | 512gb NVME SSD  Â
IL19 Posted February 14, 2022 Author Posted February 14, 2022 Thanks everyone for your advices! Yeah, SG mode is activated in Bios, so card doesn't heat up that much while just in Windows Desktop indeed. Was able to find this MSI vBios for GTX 1070 Mobile at techpowerup:https://www.techpowerup.com/vgabios/206876/206876 Should we try this one or are there other versions?  And can also give this RDP protocol a go :) Â
IL19 Posted February 22, 2022 Author Posted February 22, 2022 A little update 🙂 We have tried several MSI vBIOS versions by now. Installing them did solve an issue with GPU frequencies being stuck at 139 MHz but GPU fan still won't kick in. Once it's temperature hits 91°C it starts throttling. Is there a chance that we are missing something in unlocked A12 BIOS? It has all sorts of tweaks and settings yet we can't see anything fans-related in there. Could it be that we simply can't find them or they are really missing? Since fans are supposed to be controlled by motherboard's multicontroller chip we assumed that we probably messes up with BIOS somehow but reinstalling it didn't help as well. Â
Reciever Posted February 22, 2022 Posted February 22, 2022 If the system is needed in the mean time I would locate the PWM wire and cut it so that the fan just goes max speed and later modding a physical switch in later for EC control  My experiences are primarily with the Ranger, I wouldnt be confident in giving further advice :( 1 AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX | 32GB DDR4 3200Mhz | 2TB NVME | 3x 1200w | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | P1000 | 9300i-16P | Intel X520 | 48TB HDD's | BeQuiet DP 13 1000w HomeLab | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo! Â
IL19 Posted February 22, 2022 Author Posted February 22, 2022 Any sort of advice is still much appreciated so thank you for taking time to answer 🙂 Yeah, cutting the wire is sort of a last resort at this point!
Eban Posted February 23, 2022 Posted February 23, 2022 On 2/23/2022 at 6:21 AM, IL19 said: Any sort of advice is still much appreciated so thank you for taking time to answer 🙂 Yeah, cutting the wire is sort of a last resort at this point!  Sorry I cant help with vbios...but another suggestion. You dont have to actually "cut" the pwm wire...just jimmy it out of the plastic connector, then you can always push it back in later. 1 Thunderchild // Lenovo Legion Y740 17" i7-9750H rtx2080maxQ win10LTSC RainBird // Alienware 17 (Ranger) i7-4910mq gtx860m win8.1 JunkDog // Desktop Asrock 660M i3-12100F ARC A580 win10LTSC Â
IL19 Posted February 23, 2022 Author Posted February 23, 2022 Yeah, that would be a bit less definitive 😅
aldarxt Posted March 14, 2022 Posted March 14, 2022 On 2/22/2022 at 12:58 PM, Reciever said: If the system is needed in the mean time I would locate the PWM wire and cut it so that the fan just goes max speed and later modding a physical switch in later for EC control  My experiences are primarily with the Ranger, I wouldnt be confident in giving further advice :( Hey Reciever I came across this many years ago when my asus g51jx was always running HOT I was able to keep a cup of coffee warm placing it in front of the fan, RwPortableX64V1.6.9 allows you to run the fans full bolt say when gaming but to set it back when done, dont remember if a reboot was necessary to reset it. Google it and there was a pic of what to set and the fans just go full, I would play Morrowind or FO3 and the asus stayed cool. Just thought it might help instead of cutting wires. It's not an install just runs portable Here is the pic I used to use Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6  i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4 Â
aldarxt Posted March 14, 2022 Posted March 14, 2022 On 2/22/2022 at 12:46 PM, IL19 said: A little update 🙂 We have tried several MSI vBIOS versions by now. Installing them did solve an issue with GPU frequencies being stuck at 139 MHz but GPU fan still won't kick in. Once it's temperature hits 91°C it starts throttling. Is there a chance that we are missing something in unlocked A12 BIOS? It has all sorts of tweaks and settings yet we can't see anything fans-related in there. Could it be that we simply can't find them or they are really missing? Since fans are supposed to be controlled by motherboard's multicontroller chip we assumed that we probably messes up with BIOS somehow but reinstalling it didn't help as well.  Have you tried unlocked vBios IDK I guess there aren't any for 10 series Clevo P870DM3-G i9-9900k-32.0GB 2667mhz-RTX3080+GTX1080 Alienware M18x R2 i7-3920xm-32GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM-16GB DDR3-RTX 3000 Alienware M17x R4 i7-3940XM 20GB DDR3-P4000 120hz 3D Precision m6700 i7-3840QM-16GB DDR3-GTX 970M Precision m4700 i7-3840QM-16GB DDR3-T2000M HP ZBook 17 G6  i7 9850H-32GB DDR4-RTX4000maxQ GOBOXX SLM G2721-i7-10875H RTX 3000-32GB ddr4 Â
kenny27 Posted March 14, 2022 Posted March 14, 2022 I recall some people having fan issues with the 980m in the m18x r2 and m18 back in the day, while they were figuring it out Hwinfo was a fairly slick way to control the fans... 1 M18x R2 | 3920XM | 16GB DDR3 @ 2133Mhz | 980M SLI | 256GB Samsung 840 Evo + 1TB HHD | Audioengine D1 | Beyordynamic DT990 | Corsair M65
