Linux Posted February 1, 2024 Posted February 1, 2024 As mobile working has been getting more important for me, I would like to free the setup on my desk from a few cables. I have a Surface Pro 7+ fro work and a Clevo gaming laptop (see signature), which are currently connected to a 32" 4K@60Hz display via HDMI+DP. The Surface has a USB-A and a USB-C port (both 5Gbit, USB-C with PD), the gaming laptop has 2 USB-A and 2 USB-C 10Gbit ports. Connection preferable via USB-C in each case. I would like to be able to connect both laptops at the same time. Input devices run via Bluetooth. A camera, printer (USB-A) and an external USB-C hard drive are mandatory USB devices. 1Gbit ethernet too, of course. The Surface should be chargeable via USB-C PD (60+W), the gaming laptop has its own 200W power supply. Then I don't need the Surface power supply anymore. I've only ever used docking stations for individual devices, which is why I'm asking what the right product is for switching between the laptops? In the medium/long term, it might not be a bad idea if the docking station supports 4K@120Hz in case I ever buy a monitor with a higher frequency. Any advice? 1 2017 Clevo Laptop, TuxedoOS/Win11
Linux Posted February 2, 2024 Author Posted February 2, 2024 I now know that this only works properly with a KVM switch. To simplify the search a little, I have shortened the minimum requirements; all KVM switches should fulfil the rest: 2x USB-C host connection (1x with at least 60W PD) At least 1 additional USB-C port 1x DP (4K/120+Hz ready) 1x RJ45, 1Gbit is sufficient 2017 Clevo Laptop, TuxedoOS/Win11
Linux Posted February 3, 2024 Author Posted February 3, 2024 Holy moly. https://www.store.level1techs.com/products/hardware They have some switches meeting my criteria, but these start at 600$. Whew. 2017 Clevo Laptop, TuxedoOS/Win11
Reciever Posted February 4, 2024 Posted February 4, 2024 The requirements kind of confuse me a bit as it seems (to me) that you want a KVM that also functions as a dock? Wendell's products in that genre are all derived from Rextron which is a Taiwan based manufacturer. I have been testing a couple of their products for work purposes, while it appears they wont work for my scenario they are fairly well made. I dont think I have seen a a KVM with an Ethernet port that functions as internet access. You will find some that have it included but usually for the purpose of serial command (remote control of the KVM) AM4-DD | 5800X3D @ 4.45Ghz | Wet Devil 7900 XTX / Pulse 9070 XT (LSFG) | 32GB DDR4 3200Mhz | 2TB NVME | EVGA 1300w | NVME to 10Gbps | Win11 IoT UNRAID | Xeon Gold 6248 40c/80t | 64GB + 512GB PMEM | P1000 | 9300i-16P | 68TB HDD's | 5TB SSD's | BeQuiet DP 13 1000w ProxMox | E5-2697A 32c/64t | 128GB DDR4 2133Mhz | 2x2x1x1TB NVME Bifurcated | GTX 1060 3GB | X550 10Gbps Telegram / TS3 / Twitter 2700X to 5800X3D upgrade! With a 10850K cameo!
Linux Posted February 8, 2024 Author Posted February 8, 2024 I had a couple of days to brood about the situation and the longer i think about it, it makes less sense. The improvement for my current situation would be minimal. It would make more sense to invest in a display upgrade with an integrated USB-C hub or KVM switch. Most of these already support USB PD up to 65 or 100W. There are even gaming displays on the market with these specs. Time to think some more about it. 😭 2017 Clevo Laptop, TuxedoOS/Win11
Meaker Posted April 17, 2024 Posted April 17, 2024 Yeah I went to an MSI with it all built in, less cables around too and for high bandwidth connections with DP compression it makes life easier and more reliable. Louqe Ghost S1 case (Top hat and bottom extension) Powercolor RX 9070 XT Reaper 16GB 32" MSI 4k 160HZ IPS display AMD Ryzen 7 7700 cooled via Thermalright 240mm AIO 48GB (2x24) DDR5 6000 CL36 Asus B650E-I motherboard 2TB T500 nvme SSD + 2TB SN770 nvme Corsair SF750 platinum SFX PSU
Linux Posted April 18, 2024 Author Posted April 18, 2024 Which one do you have? The 32" Optix or MPG version? 2017 Clevo Laptop, TuxedoOS/Win11
Meaker Posted April 23, 2024 Posted April 23, 2024 MPG version since it was heavily discounted. 1 Louqe Ghost S1 case (Top hat and bottom extension) Powercolor RX 9070 XT Reaper 16GB 32" MSI 4k 160HZ IPS display AMD Ryzen 7 7700 cooled via Thermalright 240mm AIO 48GB (2x24) DDR5 6000 CL36 Asus B650E-I motherboard 2TB T500 nvme SSD + 2TB SN770 nvme Corsair SF750 platinum SFX PSU
