Aaron44126 Posted March 19 Share Posted March 19 32 minutes ago, ceasar2k6 said: Also, I think it would use more power (but I guess who uses these on an actual battery?). LCD power draw is pretty much fixed (just varying based on your backlight setting). OLED power draw changes based on what is being displayed. Dark images use less power than light images. If you spend most of your time in "dark mode" applications then you will probably use less power than an LCD panel, but the opposite is true if you work with bright images/apps. 33 minutes ago, ceasar2k6 said: I just hope the power plug is still in the back and they will allow to order gaming GPU online... but, it's still far away enough, than who knows what will happen at launch! Eh, get ready for USB-C power being the only option... Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi Link to comment Share on other sites More sharing options...
ceasar2k6 Posted March 19 Share Posted March 19 Just now, Aaron44126 said: LCD power draw is pretty much fixed (just varying based on your backlight setting). OLED power draw changes based on what is being displayed. Dark images use less power than light images. If you spend most of your time in "dark mode" applications then you will probably use less power than an LCD panel, but the opposite is true if you work with bright images/apps. Eh, get ready for USB-C power being the only option... I think it says that it draws over 280w. Are there usb-c connectors that support that much power? If so, shoooooooooot, I hope not. Link to comment Share on other sites More sharing options...
Aaron44126 Posted March 19 Share Posted March 19 9 minutes ago, ceasar2k6 said: I think it says that it draws over 280w. Are there usb-c connectors that support that much power? If so, shoooooooooot, I hope not. I'm just going off of the leaked image (see first post in this thread). If there was a barrel connector, it would be in the back-left corner of the laptop (either on the left edge or back edge). You can see that part of the laptop, along with the right edge, and the barrel connector is not present. I mean, they could have moved it to the back-right which can't be seen in that image, but that would go against their designs from the past 10+ years... The leaked image does line up with what we can see in the promo images/renderings released by Dell. They are showing the left edge (no barrel connector) but I haven't seen a shot of the rear. It's also not beyond Dell to push the limits of the USB-C spec. When the Precision 5510 systems were new, USB-C capped out at 100w under the spec, but Dell was pushing 130w through there. Now, I think the spec limit of USB-C is 240w. Dell could push a little higher than that, or, they could just have the system draw from battery power when it is "overloaded". Finally... We have EU rules coming down soon which require USB-C power delivery to be supported as a full option for most laptops. No surprise if most manufacturers just make it the only option. Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi Link to comment Share on other sites More sharing options...
SvenC Posted March 19 Share Posted March 19 21 hours ago, David55 said: Dell Pro Max 18 Plus restricts its 18-inch screen to 1440p It says QHD+ here. I'd expect that to be 2560x1600 not 2560x1440. But I found the other post with 1440p as well. Is there an official announcement page from dell? Dell Pro Max Plus 18 * Ultra 7 265HX * 64GB CSoDIMM * 4TB, 2TB, 2560x1600, iGPU previous; Dell Precision 7680 * i7 13850hx * 64GB SO-DIMM * 4TB, 2TB, 1920x1200 previous: Dell Precision 7740 * i7 9750h * 48GB * 512GB, 2TB, 4TB * RTX 3000 * 1920x1080 Link to comment Share on other sites More sharing options...
KMikhail Posted March 20 Share Posted March 20 So, Plus is scalable, but below Premium: https://www.dell.com/en-us/blog/reimagining-technology-with-simplicity-at-its-core/ Link to comment Share on other sites More sharing options...
Aaron44126 Posted March 20 Share Posted March 20 Pro Max Plus will be the “top” machine (by specs), replacing the Precision 7000 series. Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi Link to comment Share on other sites More sharing options...
nforce4max Posted March 20 Share Posted March 20 I have to wonder what features are going to be lost from this new generation forward, don't like clunk pads and non serviceable keyboards. Link to comment Share on other sites More sharing options...
Mambucho Posted March 20 Share Posted March 20 7 hours ago, Aaron44126 said: Pro Max Plus will be the “top” machine (by specs), replacing the Precision 7000 series. it will have a very high price considering the specifications "top" My eyes will pop out when I see the price and I will lose them and I will no longer need a laptop 1 Dell Precision 7680, RTX 3500 ADA, CAMM 32 ГБ, FHD+, WIN 11 Pro for Workstations (25H2.Dev) Link to comment Share on other sites More sharing options...
rahasyavadi Posted March 23 Share Posted March 23 On 3/20/2025 at 12:01 PM, Mambucho said: it will have a very high price considering the specifications "top" My eyes will pop out when I see the price and I will lose them and I will no longer need a laptop I notice that “Dell Pro Max 18 Premium” is not mentioned, and I presume it may eventually appear, with a UHD+ (3840x2400) tandem-OLED and/or DreamColor-like screen, for enough money to cause catastrophic shock to the entire nervous system. Link to comment Share on other sites More sharing options...
Aaron44126 Posted March 23 Share Posted March 23 9 hours ago, rahasyavadi said: I notice that “Dell Pro Max 18 Premium” is not mentioned, and I presume it may eventually appear, with a UHD+ (3840x2400) tandem-OLED and/or DreamColor-like screen, for enough money to cause catastrophic shock to the entire nervous system. My understanding is that (for now) the only 18" system will be the Pro Max Plus. ...If they released an 18" 'Premium' system with an OLED panel at UHD+ resolution, but they couldn't get that resolution in the 18" Pro Max Plus, that would be really disappointing... Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi Link to comment Share on other sites More sharing options...
ov_Darkness Posted March 29 Share Posted March 29 On CAMM2 module pricing: https://www.tomshardware.com/pc-components/ram/crucial-is-selling-64gb-lpcamm2-micron-memory-modules-for-dollar330 https://liliputing.com/camm2-standard-approved-for-up-to-128gb-of-speedy-removable-memory-modules/ So we have a price range. I'm certainly planning on getting the smallest possible RAM from Dell and then buying modules on my own to max it out. I did it with 7750, and it saved me over 1k EUR. Link to comment Share on other sites More sharing options...
ceasar2k6 Posted March 29 Share Posted March 29 7 hours ago, ov_Darkness said: On CAMM2 module pricing: https://www.tomshardware.com/pc-components/ram/crucial-is-selling-64gb-lpcamm2-micron-memory-modules-for-dollar330 https://liliputing.com/camm2-standard-approved-for-up-to-128gb-of-speedy-removable-memory-modules/ So we have a price range. I'm certainly planning on getting the smallest possible RAM from Dell and then buying modules on my own to max it out. I did it with 7750, and it saved me over 1k EUR. let's hope dell will allow that. over the years, their desktops were very persnickety to what ram they allowed. Link to comment Share on other sites More sharing options...
ov_Darkness Posted April 1 Share Posted April 1 On 3/29/2025 at 6:32 PM, ceasar2k6 said: let's hope dell will allow that. over the years, their desktops were very persnickety to what ram they allowed. I can't see why not? My Precision 7750 came with 8GB RAM. I've first bought 4x32GB of Corsair but it didn't like them. I've returned it and went for Crucials. It runs like that without a hitch for 4 years now and I've saved over 1k EUR. From now on, all of my RAM will by Crucial. I'm building a desktop (my first for almost 10years, not counting thexones I've built for my customers) and it will have 4x64GB of Crucial Pro. Link to comment Share on other sites More sharing options...
