igcfck Posted February 26 Share Posted February 26 I've been thinking about upgrading the display panel of my ASUS FX503VM. The laptop has an N156HGA-EAB (which I'll call CURRENT) panel, that I'm planning to swap out for an N156HCA-EN1 (which I'll call UPGRADE). I was thinking of discussing my idea and reasoning with the people here to see if I missed something before pulling the trigger. Both displays use a 30-pin, 2-lane eDP1.2 connector located at the bottom right, the pinouts also match. The UPGRADE has a ~10% higher max power consumption (4.27W), but it offers significantly better viewing angles, color accuracy, and a bit higher brightness. The UPGRADE has no mounting points but is a physically smaller package and I'm thinking about creating a laser-cut or 3d printed mounting solution. From my limited experience with the topic, I'd assume that the UPGRADE panel should work just fine, apart from any whitelisting issues, which I wouldn't know how to solve or check for beforehand. In any case, I wanted to make a post and gather some feedback before spending ~80$ on a display panel. Link to comment Share on other sites More sharing options...
sliderfra Posted May 8 Share Posted May 8 On 2/26/2025 at 10:36 AM, igcfck said: I've been thinking about upgrading the display panel of my ASUS FX503VM. The laptop has an N156HGA-EAB (which I'll call CURRENT) panel, that I'm planning to swap out for an N156HCA-EN1 (which I'll call UPGRADE). I was thinking of discussing my idea and reasoning with the people here to see if I missed something before pulling the trigger. Both displays use a 30-pin, 2-lane eDP1.2 connector located at the bottom right, the pinouts also match. The UPGRADE has a ~10% higher max power consumption (4.27W), but it offers significantly better viewing angles, color accuracy, and a bit higher brightness. The UPGRADE has no mounting points but is a physically smaller package and I'm thinking about creating a laser-cut or 3d printed mounting solution. From my limited experience with the topic, I'd assume that the UPGRADE panel should work just fine, apart from any whitelisting issues, which I wouldn't know how to solve or check for beforehand. In any case, I wanted to make a post and gather some feedback before spending ~80$ on a display panel. Hi, it should work flawlessly. As long as it's same type (EDP and same number of lanes & pinout), no worries. Go for it Link to comment Share on other sites More sharing options...
