On 2/15/2026 at 6:48 PM, PHVM_BR said:
Memory: 5600MT/s CL46 => 6400MT/s CL36 (2x32gb DUAL RANK)
NGU: 2,6GHz => 3,0GHz
D2D: 2,1GHz => 3,1GHz
Ring: 3,8GHz => 4,0GHz
P-cores: 5,2GHz@-60mV or 5,1GHz@-65mV
E-cores: 4,6GHz@-75mV or 4,7@-60mV or 4,8GHz@-50mV
ICCMax: Unlimited
10-minute test:
https://www.3dmark.com/spy/61810196
https://www.3dmark.com/fs/34303826
Hi,
Those are just outstanding scores, as i had 5090, i can tell your results are more close to 5090 than 5080 nice job. GPU OC?
So as i read you have the storm 580, and you did flash the xmg neo 16 e25 bios.
Do you have the FN key mapping mismatch?
As i have no brand x6ar558y, same as yours im willing get your scores.
Do i need to flash xmg bios? And what are your setting for CPU/GPU and ram timing?
(If possible a guide)
2 hours ago, ZoOLf said:
Hi,
Overclocked GPU!
How much depends on the application... for example, in Time Spy I get +450MHz, while in Fire Strike the limit is +430MHz...
For games I keep it at +400MHz to have a safe margin and not have to worry.
VRAM always supports +3000MHz.
I want to update to the XMG BIOS but I haven't done it yet. To get good results, just unlock the advanced BIOS menu through the Control Center and unlock the CPU undervolt and adjust the memory, in addition to the GPU overclock.
I use XTU for CPU undervolt because with it you can adjust the P-cores and E-cores separately.
On my CPU, -60mV on the P-cores is stable, limiting it to 5.2GHz, while on the E-cores at 4.6GHz I use -75mV, also completely stable.
I have 2x32GB of SODIMM memory, therefore the modules are dual rank, more limited for adjustment.
I achieved a stable 6400MT/s CL36-39-39-54 at 1.3V.
I tried 6800MT/s at 1.35V but it didn't POST. I stopped there...
With single-rank memory, 7200 or 7600MT/s at 1.35V should be easily achievable.
2 hours ago, PHVM_BR said:
Overclocked GPU!
Ahh i see, good then, i dont want to flash the xmg bios and finish with missmatch FN key.
I will try XTU, for cpu OC.
For GPU you use Msi afterburner i guess?
For the ram i have kingston fury impact 2x16 5600mhz single rank.
I never messed with ram timing, so i just have to change only those timing and voltage in bios?
If it dont post i need to clear cmos isnt?
Got my Neo 16 (E25) today.
It's stuck in a:
You're 100% there.
Please keep your computer on.
It's been like that for 35 minutes.
Any suggestions?
It's stuck in a:
Any suggestions?
What is this? First time boot? Should not take all that time, did you connected to internet for windows uppdates?
Not first time.
Left it on while I went out for food and returned to this.
About to attempt a win 11 reinstall.
Yes, I use Afterburner.
In the advanced BIOS tab, which is unlocked by checking the option in the manual settings of the Control Center, you adjust the memory and unlock undervolt protection.
If you've never adjusted memory before, I recommend doing some research first.
Generally, if the adjustment doesn't POST, the system itself reverts the changes and restarts Windows after a few minutes of trying to train the memory.
If the system doesn't restart automatically, simply restore the factory settings:
With the charger disconnected, press and hold Ctrl + F11 and click the power button for a few seconds.
When the keyboard starts flashing, you can release Ctrl and F11.
Wait a few minutes and the system will restart with the default settings.
Thx for all this clear clarifications.
Another questions please,
In XTU for the P core, do you use adaptive voltage mod or static?.
I got around 41k in cinebench 23 using a mix between bios high perf mod and some undervolt with TS.
But now i revert to full xtu the max i can get is 40k.
Also do you use watercooling or cooling pad?
Can you test nomad steel bench?
Im getting around 5400 5500.
I'm trying to install XTU but it's saying unsupported platform on install.
I have secure boot disabled and unvolting enabled in the bios, have I missed something?
Thanks.
Thanks.
Have you disabled Windows Core Isolation and virtualization features in the BIOS?
Which version of XTU are you trying to use?
Thanks.
You need to select Cpu advanced per mod in CC
I have Intel VMX Virtualization disabled, can't find Core Isolation in the BIOS.
Trying to install XTU 7.14.2.69
Yup, got CPU ADV Perf Menu active.
I use adaptive voltage.
XTU is a heavier software than Throttlestop, so I recommend applying all settings and then closing the program.
Your settings will remain until the system is turned off or restarted.
If Throttlestop works better for you, use it!
I've always used and preferred Throttlestop, but I switched to XTU with this system because of the extra adjustment possibilities.
I don't have a liquid cooling system and I use an IETS GT600.
I've tested Steel Nomad a little and haven't yet fine-tuned the system for this benchmark:
https://www.3dmark.com/sn/12124446
Core isolation is in windows not bios , memory integrity
You must disable virtualization in the BIOS.
Core isolation is disabled in Windows.
The XTU version compatible with Core Ultra (Arrow Lake) is version 10xxx.
The version you are trying to use, 7xxx, is compatible with older generation CPUs.
Nice score,
I know i asked a lot,
But im a little lost with xtu.
Can you share screenshots of xtu advanced tuning tab of what you changed,
I have BS2 Pro cooling pad and my cpu throttle before finishing the bench @95c.
8 minutes ago, ZoOLf said:
Nice score,
I don't have my laptop with me right now.
I can post tomorrow or the day after, but there's no secret.
Undervolt the P-core, undervolt the E-core, undervolt and/or overclock the cache, ICCMax = Unlimited on both the iGPU and the CPU.
Out of curiousity what are you running for tREFI at 6400MT to get 84ns in Aida64?
I currently have my 2x16GB A-die kit at 6400 38-40-40-80, tREFI 24k, NGU & D2D 30x, Ring 38x which results in around 88ns in Aida64.
I also have a 2x24GB M-die kit which can do 7200 at similar timings but I have not long term stability tested it in combined loads, especially given that I do not use the watercooling addon so memory temps have been observed up to 87C. It can do a bit better in Aida64, around 85ns.
I did get the final Premamod bios recently so its tuning capabilities are better than the stock bios along with updated microcode and other throttling fixes.
Yeah, it was as simple as trying to run the wrong version.
Edit: You have to undervolt core by core now?
Edited by MiSJAH
I have tREFI = 24576
To achieve 84ns I have:
NGU = 3.0GHz
D2D = 3.1GHz
Cache = 4.0GHz
For me, overclock the ring to 4.0GHz decreased the latency by ~2ns.
Is it possible to get the Premamod BIOS without an Eluktronics laptop?
I messaged Prema about this, but haven't received a response...
I really want the higher power limit (250W vs 210W), as well as the extra adjustment options.
Not yet, I just select all P-cores (or all E-cores) and set the undervolt.
