ZoOLf Posted March 7 Posted March 7 1 hour ago, PHVM_BR said: I don't have my laptop with me right now. I can post tomorrow or the day after, but there's no secret. Undervolt the P-core, undervolt the E-core, undervolt and/or overclock the cache, ICCMax = Unlimited on both the iGPU and the CPU. Now as im willing to OC ram i find the xmp profile cant be selected in bios, Checking my ram its PnP not XMP. Do inneed xmp to oc the ram? Also how did you changed the speed in bios, When i select 6400 it does stick in bios but in windows it says 5600mhz...
PHVM_BR Posted March 7 Posted March 7 7 minutes ago, ZoOLf said: Now as im willing to OC ram i find the xmp profile cant be selected in bios, Checking my ram its PnP not XMP. Do inneed xmp to oc the ram? Also how did you changed the speed in bios, When i select 6400 it does stick in bios but in windows it says 5600mhz... To enable the XMP profile in the BIOS, you need memory modules with XMP profiles. To manually adjust the memory, XMP memory modules are not necessary. Change the profile to manual and adjust the settings. Simply changing the target memory frequency is not effective.
ZoOLf Posted March 7 Posted March 7 3 hours ago, PHVM_BR said: To enable the XMP profile in the BIOS, you need memory modules with XMP profiles. To manually adjust the memory, XMP memory modules are not necessary. Change the profile to manual and adjust the settings. Simply changing the target memory frequency is not effective. I can select custom profile, but there is no option to select what frequency i need. Edit: i got it, memory ration " 33.333 gives the frequency. I will play with the timing now, 1
PHVM_BR Posted March 7 Posted March 7 8 hours ago, ZoOLf said: I can select custom profile, but there is no option to select what frequency i need. Edit: i got it, memory ration " 33.333 gives the frequency. I will play with the timing now, 168 = 5600 192 = 6400 204 = 6800 ...
ZoOLf Posted March 7 Posted March 7 55 minutes ago, PHVM_BR said: 168 = 5600 192 = 6400 204 = 6800 ... Thx for the reply, I booted on 6800mhz but my xmg control center is broken, its not working anymore, Reinstalled it did nothing. Tested eluktronic one, same think. I think my bios is interfering. What CC do you use? Any other one that i can test? Found the dream machine (std) works, but options are missing and mux switch is not working... Any idea how to fix this? Edit: tested in another windows installation same problem
PHVM_BR Posted March 7 Posted March 7 27 minutes ago, ZoOLf said: Thx for the reply, I booted on 6800mhz but my xmg control center is broken, its not working anymore, Reinstalled it did nothing. Tested eluktronic one, same think. I think my bios is interfering. What CC do you use? Any other one that i can test? Found the dream machine (std) works, but options are missing and mux switch is not working... Any idea how to fix this? Edit: tested in another windows installation same problem I'm currently using the XMG CC, but it's identical to the Avell one. I haven't noticed any differences...
ZoOLf Posted March 7 Posted March 7 13 minutes ago, PHVM_BR said: I'm currently using the XMG CC, but it's identical to the Avell one. I haven't noticed any differences... I think i need to reflash my bios, Im using mechrevo CC but same as dream machine, Screen calibration is not working mux switch too, the switch need to be done in bios. If not for fn key mismatch i would flash XMG bios. Hydroc g2 has same fn key layout
win32asmguy Posted March 7 Author Posted March 7 12 hours ago, PHVM_BR said: I have tREFI = 24576 To achieve 84ns I have: NGU = 3.0GHz D2D = 3.1GHz Cache = 4.0GHz For me, overclock the ring to 4.0GHz decreased the latency by ~2ns. Is it possible to get the Premamod BIOS without an Eluktronics laptop? I messaged Prema about this, but haven't received a response... I really want the higher power limit (250W vs 210W), as well as the extra adjustment options. So far I have found that increasing Cache to 4.0Ghz actually increased latency. There is a VF Curve applied by default, but Cache overclocking only works with VF offset and needs higher voltage to be stable. I think its only offered for Eluktronics laptops. From what I was told Bootguard is enabled by default with most OEMs so flashing an unsigned bios would not boot regardless. I was even told to not load the XMG bios (while I was waiting for Premamod to become available) as that would fuse Bootguard and lock out any modded bios on that motherboard going forward. I cannot even take advantage of the 250W limit without the liquid cooling addon, but do appreciate all of the other adjustment options. As it stands I think yours still has better latency number than mine, and I have yet to even approach the sub-80ns range I have seen from Legion 7i Pro G10 users. Desktop - Intel 285K, Asus Z890 Apex, 48GB DDR5-8400 C36, 800GB Optane P5800X, Corsair HX1500i, Fractal Define 7 XL, Windows 10 Pro 22H2 Lenovo Legion 9i G10 - 275HX, 2x32GB Kingston Fury DDR5-5200 CL38, 4TB WD 8100, RTX 5090 mobile, 18.0 inch FHD+ 440hz IPS, Windows 10 Pro 22H2 Hydroc G2 / Uniwill IDY X6AR559Y - 275HX, 2x16GB DDR5-6400 CL38, 4TB WD SN850X, RTX 5090 mobile, 16.0 inch QHD+ 300hz MiniLED, Windows 11 Pro 24H2
PHVM_BR Posted March 7 Posted March 7 29 minutes ago, win32asmguy said: So far I have found that increasing Cache to 4.0Ghz actually increased latency. There is a VF Curve applied by default, but Cache overclocking only works with VF offset and needs higher voltage to be stable. I think its only offered for Eluktronics laptops. From what I was told Bootguard is enabled by default with most OEMs so flashing an unsigned bios would not boot regardless. I was even told to not load the XMG bios (while I was waiting for Premamod to become available) as that would fuse Bootguard and lock out any modded bios on that motherboard going forward. I cannot even take advantage of the 250W limit without the liquid cooling addon, but do appreciate all of the other adjustment options. As it stands I think yours still has better latency number than mine, and I have yet to even approach the sub-80ns range I have seen from Legion 7i Pro G10 users. My settings were all tested in several tests over a few hours. Everything is 100% stable until then... Regarding the cache, initially I kept it at 3.8GHz with an undervolt of -80mV, but I realized during testing that the undervolt on the cache delivered practically no benefits (maybe 1 to 2W less at full load). Then I tried overclocking in XTU and discovered that for 4.0GHz it was enough to maintain the original voltage, without undervolting. With the ring at 3.8 GHz and everything else the same, I get about ~86 ns. I believe that with Hynix A-die single rank it's possible to achieve 7600MT/s CL36 and latency below 80ns. We'll see... I'm waiting for a reasonable price to buy 2x16gb Fury Impact 6400MT/s CL38 and test it. As for the BIOS update, I haven't updated to the XMG BIOS yet for fear of something going wrong, but I've seen several reports that it works.
ZoOLf Posted March 7 Posted March 7 26 minutes ago, PHVM_BR said: My settings were all tested in several tests over a few hours. Everything is 100% stable until then... Regarding the cache, initially I kept it at 3.8GHz with an undervolt of -80mV, but I realized during testing that the undervolt on the cache delivered practically no benefits (maybe 1 to 2W less at full load). Then I tried overclocking in XTU and discovered that for 4.0GHz it was enough to maintain the original voltage, without undervolting. With the ring at 3.8 GHz and everything else the same, I get about ~86 ns. I believe that with Hynix A-die single rank it's possible to achieve 7600MT/s CL36 and latency below 80ns. We'll see... I'm waiting for a reasonable price to buy 2x16gb Fury Impact 6400MT/s CL38 and test it. As for the BIOS update, I haven't updated to the XMG BIOS yet for fear of something going wrong, but I've seen several reports that it works. The problem with xmg bios is the FN key layout which are not the same as ours. 1
ZoOLf Posted March 7 Posted March 7 On 10/22/2025 at 9:10 AM, MaxxD said: Full (XMG) Control Center "Gallery" (<---LINK) My experience so far has been good and I am satisfied. I would recommend this machine to anyone. It is properly optimized in both software and hardware. The machine is a Medion Erazer, but it matches the XMG NEO machine perfectly, so I installed the XMG BIOS on it and used the XMG Control Center, and I don't regret it. How did you for the FN key layout? Xmg dont have same layout as yours 1
MiSJAH Posted March 8 Posted March 8 On 3/7/2026 at 2:02 PM, win32asmguy said: I cannot even take advantage of the 250W limit without the liquid cooling addon, but do appreciate all of the other adjustment options. Is the 250W limit achievable with the Premamod BIOS and without the hardware shunt mod?
win32asmguy Posted March 8 Author Posted March 8 1 hour ago, MiSJAH said: Is the 250W limit achievable with the Premamod BIOS and without the hardware shunt mod? The 250W limit is on the CPU. So far as I know there is no GPU shunt mod on the Eluktronics Hydroc G2 other than the one that was made for Gizmosliptech's youtube video review. Desktop - Intel 285K, Asus Z890 Apex, 48GB DDR5-8400 C36, 800GB Optane P5800X, Corsair HX1500i, Fractal Define 7 XL, Windows 10 Pro 22H2 Lenovo Legion 9i G10 - 275HX, 2x32GB Kingston Fury DDR5-5200 CL38, 4TB WD 8100, RTX 5090 mobile, 18.0 inch FHD+ 440hz IPS, Windows 10 Pro 22H2 Hydroc G2 / Uniwill IDY X6AR559Y - 275HX, 2x16GB DDR5-6400 CL38, 4TB WD SN850X, RTX 5090 mobile, 16.0 inch QHD+ 300hz MiniLED, Windows 11 Pro 24H2
MiSJAH Posted March 8 Posted March 8 Interesting. I didn't know that the cpu power could be edited in the bios.
ZoOLf Posted March 9 Posted March 9 9 hours ago, win32asmguy said: The 250W limit is on the CPU. So far as I know there is no GPU shunt mod on the Eluktronics Hydroc G2 other than the one that was made for Gizmosliptech's youtube video review. shunt mod do excite for our model here one 1
PHVM_BR Posted March 9 Posted March 9 21 hours ago, win32asmguy said: The 250W limit is on the CPU. So far as I know there is no GPU shunt mod on the Eluktronics Hydroc G2 other than the one that was made for Gizmosliptech's youtube video review. To take advantage of that 250W CPU limit, I'm afraid even liquid cooling won't be enough. Perhaps LM + liquid cooling would be possible for short/medium duration loads, but the heatsink has aluminum parts, and caution is needed in choosing the solution for its application... 1
ZoOLf Posted March 14 Posted March 14 On 3/7/2026 at 2:23 AM, PHVM_BR said: I have tREFI = 24576 To achieve 84ns I have: NGU = 3.0GHz D2D = 3.1GHz Cache = 4.0GHz For me, overclock the ring to 4.0GHz decreased the latency by ~2ns. Is it possible to get the Premamod BIOS without an Eluktronics laptop? I messaged Prema about this, but haven't received a response... I really want the higher power limit (250W vs 210W), as well as the extra adjustment options. hi, please can you tell me where to OC the D2D NGU and cache? i cant find where
PHVM_BR Posted March 14 Posted March 14 4 hours ago, ZoOLf said: hi, please can you tell me where to OC the D2D NGU and cache? i cant find where BIOS Advanced (D2D / NGU) and XTU (NGU / Ring).
MaxxD Posted Wednesday at 12:17 PM Posted Wednesday at 12:17 PM On 3/7/2026 at 3:58 PM, ZoOLf said: How did you for the FN key layout? Xmg dont have same layout as yours I don't really use it because it doesn't bring in what it should. I don't know why it does something different when I use it than what it should. Any ideas? 🙂 ◄►Medion Erazer Beast 16 X1 Ultimate►+Water System►i9-275HX/96GB/4TB/nV RTX 5090 24GB/RTL 2.5GBLan <---Slayer Of Desktops & Desktop Killer---> ◄►Clevo® X170SM-G / KM-G►+AIO Water System►i7-11700K/128GB/8TB/nV RTX 3080 16GB MXM►Killer 2.5GBLan►Win10/11 x64 Pro►LG®OLED55C4 4K/144Hz G-Sync◄►**
