Aaron44126 Posted May 19 Share Posted May 19 Starting a new thread with the "proper name", since Dell has made an announcement. Spec sheets. 18: https://www.delltechnologies.com/asset/en-us/products/workstations/technical-support/dell-pro-max-18-plus-laptop-spec-sheet.pdf 16: https://www.delltechnologies.com/asset/en-us/products/workstations/technical-support/dell-pro-max-16-plus-laptop-spec-sheet.pdf More soon, as I drudge it up. [Edit] Disappointed that the specs are presented in "paragraph form" rather than as an actual list! 55W Intel Core Ultra CPU (no specific model given) NVIDIA RTX PRO 5000 Blackwell GPU (24GB VRAM) Memory support up to 256GB (CAMM) or 96GB (SODIMM) It says 16TB storage which would be 4×4TB, assuming it really still has 4 NVMe slots, you could probably install 4×8TB yourself. (16" model only has 12TB of storage listed on the spec sheet.) The 18" display only supports up to QHD resolution and says nothing about refresh rate, so assuming 60 Hz. 500 nits. It doesn't say what type of panel it is, either, so I think it would be fair to assume that it is not OLED. 16" supports up to UHD and 120 Hz (tandem OLED). 2.5 gigabit Ethernet (finally) Wi-Fi 7 Bluetooth 5.4 280W USB-C power adapter (...first time Dell has bumped up the power adapter in like 15 years? It's been 240W for a looong time.) 96Whr battery 6.9 lbs (18") [Edit 2] Caught wind of this from Neowin. https://www.neowin.net/news/dell-pro-max-plus-is-its-most-powerful-laptop-to-help-you-get-cloud-ai-performance-at-home/ They are noting that the systems will include (an option for) a "Qualcomm AI 100 Inference Card", allowing large LLMs to be run locally (without relying solely on the CPU/GPU). This thing looks to take up some notable physical space. Maybe it fits in place of the GPU? Can't have both a discrete GPU and NPU? There are renders of both sides of the system, confirming the port layout. Basically what we already knew from the leaks before. Left side, front-to-back: SmartCard, SD card, USB-C ×2, HDMI, Ethernet Right side, front-to-back: 3.5mm audio, USB-C, USB-A ×2, lock port (No barrel connector in sight. USB-C power only.) The spec sheet says that Thunderbolt 5 is supported, but it is not clear if that is on every one of the USB-C ports. Availability: "Later in the year". No price yet. [Edit 3] Other articles. https://www.notebookcheck.net/Dell-s-new-Pro-Max-Plus-workstations-get-serious-AI-muscle-with-Qualcomm-NPU.1019429.0.html https://www.pcmag.com/news/dell-ditches-the-gpu-for-an-ai-chip-in-this-bold-new-workstation-laptop 2 1 Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi Link to comment Share on other sites More sharing options...
ceasar2k6 Posted May 19 Share Posted May 19 Sucks that it only has 2 USB-A since I have wireless headset/mouse occupying both and 3rd would be nice for usb flash drive swappage, for example. Also sucks that no back power connector as they had for a long time, which I always preferred as well. Link to comment Share on other sites More sharing options...
iieeann Posted May 20 Share Posted May 20 Hmm... Looks interesting, but i don't think is a worthy upgrade from 7780 yet. 280W power is a good upgrade, i will need to replace my 14 units of 240W bricks if i buy this 😔... New TB5 dock station should be coming along. Dell Precision 7780. 13950HX, 96GB, RTX 5000 Precison 7720, M6800, XPS 9310, Latitude 5310, etc. Link to comment Share on other sites More sharing options...
addabis Posted May 20 Share Posted May 20 Good to know. This frees me to explore other manufacturers, because my WD19DC docks and power bricks are now likely throw-aways. Is there any 3rd party manufacturer selling CAMM modules (that Pro Max Plus will have)? I know that Crucial "offers" LPCAMM2 64 GB, but does it have a chance to be compatible? I'd expect yes. Link to comment Share on other sites More sharing options...
Aaron44126 Posted May 20 Author Share Posted May 20 I think CAMM and LPCAMM are not going to be cross-compatible. Similar to DDR5 vs. LPDDR5 — though LPDDR5 was never "swappable", offered in soldered-on-the-board form only, and the CAMM version "fixes" that. With a quick search, I can't find CAMM2 modules for sale individually, but I think we'll start seeing them pretty soon. I just saw an article about them showing up on desktop motherboards. https://www.pcgamer.com/hardware/memory/will-2025-be-the-year-that-camm2-memory-finally-makes-a-proper-entrance-rambus-and-team-group-believe-it-is/ 1 Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi Link to comment Share on other sites More sharing options...
addabis Posted May 20 Share Posted May 20 6 hours ago, Aaron44126 said: I think CAMM and LPCAMM are not going to be cross-compatible. Similar to DDR5 vs. LPDDR5 — though LPDDR5 was never "swappable", offered in soldered-on-the-board form only, and the CAMM version "fixes" that. With a quick search, I can't find CAMM2 modules for sale individually, but I think we'll start seeing them pretty soon. I just saw an article about them showing up on desktop motherboards. https://www.pcgamer.com/hardware/memory/will-2025-be-the-year-that-camm2-memory-finally-makes-a-proper-entrance-rambus-and-team-group-believe-it-is/ Ah, that completely eluded me - I thought CAMM2 is a single form-factor. Hopefully it does come. I'm not really willing to pay $1500 or so for a 128 GB module (even though it's probably going down with the new gen) while the new HP Fury G1i will support 4x48 GB SODIMMs, which I can user-upgrade to for less than $400 total. Link to comment Share on other sites More sharing options...
TunaDog Posted May 21 Share Posted May 21 On 5/19/2025 at 10:18 AM, Aaron44126 said: [Edit 2] Caught wind of this from Neowin. https://www.neowin.net/news/dell-pro-max-plus-is-its-most-powerful-laptop-to-help-you-get-cloud-ai-performance-at-home/ They are noting that the systems will include (an option for) a "Qualcomm AI 100 Inference Card", allowing large LLMs to be run locally (without relying solely on the CPU/GPU). This thing looks to take up some notable physical space. Maybe it fits in place of the GPU? Can't have both a discrete GPU and NPU? [snip] [Edit 3] Other articles. https://www.notebookcheck.net/Dell-s-new-Pro-Max-Plus-workstations-get-serious-AI-muscle-with-Qualcomm-NPU.1019429.0.html https://www.pcmag.com/news/dell-ditches-the-gpu-for-an-ai-chip-in-this-bold-new-workstation-laptop The article you linked to at notebookcheck says Quote The Qualcomm-based Pro Max Plus will ditch discrete graphics in favor of a dual AI-100 NPU configuration, featuring 32 AI cores and 64GB LPDDR4x memory for running large language models locally. Dell is clearly targeting this toward engineers and researchers working on high-security AI models and chatbot development, where data sensitivity rules out cloud processing. Link to comment Share on other sites More sharing options...
David55 Posted May 23 Share Posted May 23 Any speculation on or indication of pricing? For the specs (such as 18", Ultra 9 275HX, Nvidia 5080 or 5090) I may get the Alienware 18 Area 51 even though I do not game. No ISV certifications and although power and cooling is prioritized over reliability and durability, the 18 Area 51 is the cheapest laptop with similar specs along with what I have found to be Dell build quality. If a similarly equipped Pro Max 18 Plus (such as an RTX Pro 4000) could have similar pricing, I would wait for it. Any comment on the possible pricing or the comparison with the 18 Area 51? On a different note, I wonder whether the easy-access bottom door will provide access just to one of the SSDs or will be an easily removable bottom cover with latches instead of so many screws and clips. In case you are interested, here are the only real reviews of any kind so far on the Alienware 18 Area 51: Unboxing and first impressions: https://www.youtube.com/watch?v=x2ZFnXQ02bw And the review with a bit more: https://www.youtube.com/watch?v=xuFQ4LN--II 1 Link to comment Share on other sites More sharing options...
ceasar2k6 Posted May 25 Share Posted May 25 On 5/23/2025 at 5:09 PM, David55 said: Any speculation on or indication of pricing? For the specs (such as 18", Ultra 9 275HX, Nvidia 5080 or 5090) I may get the Alienware 18 Area 51 even though I do not game. No ISV certifications and although power and cooling is prioritized over reliability and durability, the 18 Area 51 is the cheapest laptop with similar specs along with what I have found to be Dell build quality. If a similarly equipped Pro Max 18 Plus (such as an RTX Pro 4000) could have similar pricing, I would wait for it. Any comment on the possible pricing or the comparison with the 18 Area 51? On a different note, I wonder whether the easy-access bottom door will provide access just to one of the SSDs or will be an easily removable bottom cover with latches instead of so many screws and clips. In case you are interested, here are the only real reviews of any kind so far on the Alienware 18 Area 51: Unboxing and first impressions: https://www.youtube.com/watch?v=x2ZFnXQ02bw And the review with a bit more: https://www.youtube.com/watch?v=xuFQ4LN--II area-51 does have things I need. 3 usb-a ports. power plug in the back. but I wonder if it has fingerprint reader alongside with windows hello Link to comment Share on other sites More sharing options...
David55 Posted May 25 Share Posted May 25 1 hour ago, ceasar2k6 said: I wonder if it has fingerprint reader alongside with windows hello No fingerprint reader, unfortunately. Could some people share their thoughts? Could the heavy cooling design, for instance, contribute to longevity of the system if not used much for gaming? Or could this design compromise durability even if it is great for powerered gaming while it lasts? Link to comment Share on other sites More sharing options...
samatsu Posted May 26 Share Posted May 26 On 2025/5/22 at AM12點09分, TunaDog said: 您在 Notebookcheck 上連結的文章說 Dell uses the Qualcomm AI 100 dual AI 100 inference card configuration in its Pro Max Plus laptops. Is it better than the NVIDIA RTX PRO 5000 Blackwell GPU? Dell Latitude D600(工作)、Dell Precision M2400(工作)、Dell Precision M7540(工作) Dell Precision M7670(工作) Link to comment Share on other sites More sharing options...
David55 Posted May 29 Share Posted May 29 This pcmag piece has what I think are some new pics. Dell's Pro Max 18 Plus Demolishes AI Tasks With Qualcomm's New Coprocessor https://www.pcmag.com/news/dells-pro-max-18-plus-demolishes-ai-tasks-with-qualcomms-new-coprocessor 2 Link to comment Share on other sites More sharing options...
yslalan Posted June 3 Share Posted June 3 On 5/20/2025 at 11:00 AM, iieeann said: New TB5 dock station should be coming along. With a ridiculous 300W output. Dell Pro Thunderbolt 5 Smart Dock - SD25TB5 1 Precision 7680 i9-13950HX - NVIDIA RTX 5000 Ada 16G - 96G DDR5 - UHD+ Display - 3840*2400 OLED - 6T NVMe Link to comment Share on other sites More sharing options...
yslalan Posted June 14 Share Posted June 14 They updated the spec sheet for the Pro Max Plus series Precision 7680 i9-13950HX - NVIDIA RTX 5000 Ada 16G - 96G DDR5 - UHD+ Display - 3840*2400 OLED - 6T NVMe Link to comment Share on other sites More sharing options...
Aaron44126 Posted June 14 Author Share Posted June 14 OK, that's better, several more pages and an actual specs list now. [Edit] Interesting bits I noticed: Windows 10 no longer offered as an option, you have to downgrade it yourself. (Makes sense as Windows 10 is leaving support in a few months ... though you can still use the LTSC version for longer.) 256 GB RAM seems to be accomplished by using two 128 GB CAMM cards. So it has two CAMM slots now? I wonder if you can do other combinations not listed on the spec sheet. (Buy a second 64 GB CAMM card to go along with your first later on, or mix and match something like 64 GB + 128 GB...) "NVIDIA RTX PRO 5000 Blackwell" GPU gets 24 GB of VRAM, first VRAM bump for the high-end GPU in quite a while. (Quadro P5000 was first with 16GB, way back in like 2017?) 18" system only has one display option listed, the QHD+ panel. 1 Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi Link to comment Share on other sites More sharing options...
SvenC Posted June 14 Share Posted June 14 Is CSoDimm different to SO-DIMM? Dell Pro Max Plus 18 * Ultra 7 265HX * 64GB CSoDIMM * 4TB, 2TB, 2560x1600, iGPU previous; Dell Precision 7680 * i7 13850hx * 64GB SO-DIMM * 4TB, 2TB, 1920x1200 previous: Dell Precision 7740 * i7 9750h * 48GB * 512GB, 2TB, 4TB * RTX 3000 * 1920x1080 Link to comment Share on other sites More sharing options...
Mambucho Posted June 14 Share Posted June 14 3 hours ago, SvenC said: Отличается ли CSoDimm от SO-DIMM? The letter 'C' in the abbreviation CSODIMM stands for synchronous memory, which is equipped with a new hardware component. The front side of the CSODIMM module is shown up close. In the center, under the label, is the clock generator chip from Montage. Dell Precision 7680, RTX 3500 ADA, CAMM 32 ГБ, FHD+, WIN 11 Pro for Workstations (25H2.Dev) Link to comment Share on other sites More sharing options...
SvenC Posted June 16 Share Posted June 16 So, currently available SO-DIMM DDR5 modules won't work? I could not find CSoDimms online. Dell Pro Max Plus 18 * Ultra 7 265HX * 64GB CSoDIMM * 4TB, 2TB, 2560x1600, iGPU previous; Dell Precision 7680 * i7 13850hx * 64GB SO-DIMM * 4TB, 2TB, 1920x1200 previous: Dell Precision 7740 * i7 9750h * 48GB * 512GB, 2TB, 4TB * RTX 3000 * 1920x1080 Link to comment Share on other sites More sharing options...
addabis Posted June 17 Share Posted June 17 On 6/14/2025 at 12:59 PM, Aaron44126 said: 256 GB RAM seems to be accomplished by using two 128 GB CAMM cards. So it has two CAMM slots now? I wonder if you can do other combinations not listed on the spec sheet. I think the last gen had two "slots" too. And they specifically use CAMM and not CAMM2, which leads me to believe this is Dell's CAMM and not the JEDEC-standardized one (at least I think these are not compatible). Link to comment Share on other sites More sharing options...
Mambucho Posted June 17 Share Posted June 17 14 hours ago, SvenC said: So, currently available SO-DIMM DDR5 modules won't work? I could not find CSoDimms online. I think that the 6400 MT won't handle the 13850HX, most likely it's for the 285HX and higher, it's written on the label. Crucial CSODIMM 16GB | Preisvergleich Geizhals EU Dell Precision 7680, RTX 3500 ADA, CAMM 32 ГБ, FHD+, WIN 11 Pro for Workstations (25H2.Dev) Link to comment Share on other sites More sharing options...
yslalan Posted June 20 Share Posted June 20 On 6/17/2025 at 12:34 AM, addabis said: And they specifically use CAMM and not CAMM2 The leaked poster revealed the CAMM2 specifications for memory. On 6/17/2025 at 12:34 AM, addabis said: I think the last gen had two "slots" too. You are referring to 2DPC DRAM, correct? Yea, the 128G CAMM1 is 2DPC, with a memory frequency of 3600MT/s. Precision 7680 i9-13950HX - NVIDIA RTX 5000 Ada 16G - 96G DDR5 - UHD+ Display - 3840*2400 OLED - 6T NVMe Link to comment Share on other sites More sharing options...
SvenC Posted June 23 Share Posted June 23 Here is a french Dell link, which indicates 17th of July as start for the Dell Pro Max Plus. 1 Dell Pro Max Plus 18 * Ultra 7 265HX * 64GB CSoDIMM * 4TB, 2TB, 2560x1600, iGPU previous; Dell Precision 7680 * i7 13850hx * 64GB SO-DIMM * 4TB, 2TB, 1920x1200 previous: Dell Precision 7740 * i7 9750h * 48GB * 512GB, 2TB, 4TB * RTX 3000 * 1920x1080 Link to comment Share on other sites More sharing options...
MyPC8MyBrain Posted July 2 Share Posted July 2 just received a quote for Dell Pro Max 18 Plus from our sales rep, they are now officially available but i haven't seen any info on Dell site yet, the impossible is not impossible, its just haven't been done yet. Link to comment Share on other sites More sharing options...
MyPC8MyBrain Posted July 2 Share Posted July 2 found it https://www.delltechnologies.com/asset/en-us/products/workstations/technical-support/dell-pro-max-18-plus-laptop-spec-sheet.pdf.external the impossible is not impossible, its just haven't been done yet. Link to comment Share on other sites More sharing options...
yslalan Posted July 7 Share Posted July 7 On 6/23/2025 at 2:40 PM, SvenC said: Here is a french Dell link, which indicates 17th of July as start for the Dell Pro Max Plus. I asked my sales rep, and that date is confirmed. Only the 1200P@120Hz display option is compatible with the WWAN antenna, similar to the 7680 model. The 5090 option hasn't been available yet; Let's see if it will finally be on the list. As for now, the CAMM2 is available starting with the 128GB option only 😢. Precision 7680 i9-13950HX - NVIDIA RTX 5000 Ada 16G - 96G DDR5 - UHD+ Display - 3840*2400 OLED - 6T NVMe Link to comment Share on other sites More sharing options...
