Jerryzago Posted September 21, 2025 Posted September 21, 2025 Hello. This is my built. It is an Alienware 17 R1 with the 60Hz screen. Initially it had a 4710mq and GTX 880m with 16 Gigs of 1600MHz Ram. Cpu has been upgraded to a 4930mx @ 4,0GHz on all Cores, running throttle free GPU has been upgraded to PNY Quadro RTX 3000, pulling 80watts constanty Ram will be upgraded to 32GB with Ripjaws 1866MHz speed. Bios is A14+ unlocked Fan control is working natively. I have HWinfo and RTSS running an OSD while gaming just to look at temps. No control is needed. Here is a Firestrike result https://www.3dmark.com/3dm/142194166? Here is a photo album with BIOS settings. Strange enough, system runs in iGFX mode and both Intell HD and RTX 3000 are present in the system. https://photos.app.goo.gl/qgvUHAMnNTbnqgqJ6 Alienware M18x R2 / i7 3720qm -> i7 3940XM / Dual 7970m -> 980m SLI -> HP Quadro RTX 3000 Alienware 17 R1 / 4710MQ -> 4930mx / 880M GTX -> PNY Quadro RTX 3000 HP 8570w / i7 3820qm / Quadro K2000M HP DV6500 / i7 T7200 -> i7 T9500 / 2GB RAM -> 4GB RAM / Atlas OS
Eban Posted September 25, 2025 Posted September 25, 2025 On 9/21/2025 at 8:35 PM, Jerryzago said: Hello. This is my built. It is an Alienware 17 R1 with the 60Hz screen. Initially it had a 4710mq and GTX 880m with 16 Gigs of 1600MHz Ram. Cpu has been upgraded to a 4930mx @ 4,0GHz on all Cores, running throttle free GPU has been upgraded to PNY Quadro RTX 3000, pulling 80watts constanty Ram will be upgraded to 32GB with Ripjaws 1866MHz speed. Bios is A14+ unlocked Fan control is working natively. I have HWinfo and RTSS running an OSD while gaming just to look at temps. No control is needed. Here is a Firestrike result https://www.3dmark.com/3dm/142194166? Here is a photo album with BIOS settings. Strange enough, system runs in iGFX mode and both Intell HD and RTX 3000 are present in the system. https://photos.app.goo.gl/qgvUHAMnNTbnqgqJ6 Just out of curiosity what OS is your Ranger running? Nice upgrade BTW Thunderchild // Lenovo Legion Y740 17" i7-9750H rtx2080maxQ win10LTSC RainBird // Alienware 17 (Ranger) i7-4910mq gtx860m win8.1 JunkDog // Desktop Asrock 660M i3-12100F ARC A580 win10LTSC
Jerryzago Posted September 26, 2025 Author Posted September 26, 2025 15 hours ago, Eban said: Just out of curiosity what OS is your Ranger running? Nice upgrade BTW Thanks. I am running Windows 11 1 Alienware M18x R2 / i7 3720qm -> i7 3940XM / Dual 7970m -> 980m SLI -> HP Quadro RTX 3000 Alienware 17 R1 / 4710MQ -> 4930mx / 880M GTX -> PNY Quadro RTX 3000 HP 8570w / i7 3820qm / Quadro K2000M HP DV6500 / i7 T7200 -> i7 T9500 / 2GB RAM -> 4GB RAM / Atlas OS
