MXM cards that only worked with OPTIMUS finally DO work with edp only laptops
We all thought that RTX cards only worked with optimus enabled laptops.
With a bit of digging (thanks @SuperMG) and testing, we can definity assume cards such as RTX (Turing, ada...) do work with edp only laptops provided they have DP_D or EDP lanes on the MXM port.
Baseline:
concept (thank you SuperMG):
https://notebooktalk.net/topic/2195-rtx-3080-in-m18xr2-should-i-do-it-lol/page/9/
How to:
On clevo P870, solder MXM lanes 23 25 27 (PNL PW et BL) to 3.3V_RUN (via mxm lanes or directly on motherboard)
https://ibb.co/QjD3p5pQ
We tested on 3.3VS and it did not work perfect (sometimes random black screen)
https://ibb.co/sJQ8D5Hs
Proof of work:
Test with SuperMG RTX4070 MXM
https://ibb.co/zT1FTxQZ
Test with my Quadro RTX 3000 PNY (Adlink):
https://ibb.co/zVjrWmgp
https://ibb.co/mVBfdVnc
Drawbacks:
- brightness control don’t work (stays in full brightness)
- requires soldering skills.
But SuperMG is working on a flat ribbon that would do the wire trick without any solder skills.
- drivers still need modding (nvidia at least) thus secure boot might fail.
Will most probably work on:
- Alienware M17x r4 and 17 R1 with edp screens
- dell m4/6700, m4/6800, precision 7710 / 20
- all Clevo lineup ranging from p771zm to P775tm (X170 may work too)
- msi gt72, gt73 series
- Hp zbook g1 to g6, elitebooks 8770, 8570
- other whitebooks or derived laptops with mxm
Once @SuperMG has some flex cables I’ll might try.
I got the cables.
They work with my P570WM. I tested the 4080. Cable 100% works for backlight.
278, 280 are always 3.3V_RUN.
Sleep mode and brightness control works!  but...
It displays on windows without a driver but at the end... I can't install Nvidia drivers.
DDU + install thru disk .inf file
DDU + NVCleanInstall
None work! Even restarting, I can see the bios splash, the windows loading screen and BLACK SCREEN!
Although, I can access to the windows "safe mode" to uninstall the drivers, but it's not worth it because it'll again blackscreen once the drivers installation has been completed.
I tried to use Anydesk, once the driver installed, it says the drivers have been installed successfully and on the device manager... I got an error 43 and the screen resolution was at 640x480 instead of 1920x1080 initially...
EDIT: SAME HAPPENS WITH THE RTX 4090 HELP!
This card was working fine as a slave card too... I don't understand guys, help please...
Probably these cards have DP++ or something that's blocking display for the standard DP display I have.
I'll test these cards on Dell Precision 7720 and P870 later on...
EDIT: I TESTED THE RTX 3080 MXM... It works on the P570WM!!!
1080p 120Hz! Drivers installed successfully! Full TDP, no bugs! Sleep mode and saving mode work!
I suppose the 3080 has basic DP and not DP++...
Edited by SuperMG
News about the RTX 3080!
