Will Posted February 5 Posted February 5 As the title says, based on your experience, what’s the best way to remove the sticky rubber coating/soft touch finish from surfaces like the palmrest or the laptop lid, especially on Alienware and Dell Precision models?
6730b Posted February 6 Posted February 6 lol, my very old Dell E7440 had coating that disintegrated. Looked and felt horrible > time to throw the laptop in the bin :O) But scratched it away with a piece of plastic (softer than the main plastic frame under the coating). Long ago, maybe ? also used some elctronic contact cleaner, which did not attack anything other than the coating. Then polished with fine 800 (or was it 400) sandpaper. Was a job over time, nice finish in the end. Dell Precision 5540 w10 ltsc - Thinkpad P14s G5 w10 ltsc - Thinkpad E14 G5 w11 - HP i5 desktop w10 ltsc - (O&O shutup\Open Shell on all w10\11) - Dell E7440 w8.1 - Tosh Satellite w8.1 - Pixel 8 Pro - Xiaomi 14 Ultra - 2x Samsung A52s - (Netguard on all phones) Stand with
Hyper Posted February 14 Posted February 14 Isopropyl alcohol will usually remove it. But it may be hard on the plastic leaving white stains. And often the entire plastic part is disintegrating and cleaning the sticky residue will not stop the process. HP Elitebook 8540w - i5-560M - FirePro M5800 - 8GB DDR3-1066 - Win7x64 Dell Precision M4800 - Core i7-4810MQ - FirePro M5100 - 24GB DDR3 1600 Windows 11 x64 Dell Precision 7520 - Xeon E3-1545M v5 - Quadro M2200 - 32GB DDR4 2666 Windows 11 x64 Lenovo ThinkPad P16 Gen 3 - Core Ultra 9 275HX - RTX PRO 4000 Blackwell - 64GB DDR5 5600 - Windows 11 x64
Redneck_Randy Posted February 14 Posted February 14 You should see my old laptop (ASUS G75VW). It feels like fly paper cause it's so sticky.
loopster Posted February 14 Posted February 14 Denatured alcohol to clean off the sticky goo on top, then use a few drops of baby oil (yes, baby oil 🙂, it works best) to give the surface a fresh finish and seal it off.
