synclear Posted February 6 Posted February 6 The M4800 + M2000M was installed and the driver was installed normally. However, GPU FAN is not working. Running diagnostics causes a 20000-0511 error. After removing the FAN, it was confirmed that the FAN operates normally when power is supplied from the outside. Is there any way to solve this issue or anything else I need to check? I look forward to your kind reply.
Aaron44126 Posted February 6 Posted February 6 4 hours ago, synclear said: The M4800 + M2000M was installed and the driver was installed normally. However, GPU FAN is not working. Running diagnostics causes a 20000-0511 error. After removing the FAN, it was confirmed that the FAN operates normally when power is supplied from the outside. Is there any way to solve this issue or anything else I need to check? I look forward to your kind reply. Tools like SpeedFan or HWiNFO64 can manually control the fan in this system. If you use one of those, can you get the fan to turn on? Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi
synclear Posted February 9 Author Posted February 9 Thank you for your reply. I ran hwi and checked it by manually adjusting the fan speed. The CPU fan rotates normally, but the GPU fan is fixed at 10,000 PRM and has not actually rotated.
JadeRover Posted February 10 Posted February 10 Hello, sounds like maybe the fan connector got damaged as your fan still works when powering it externally. How did you test it, you plugged 5v on the + and - pins ? Did you remove the fans when upgrading ? Precision M6700 : i7-3740QM | P3000 6gb engineering vbios | 20gb DDR3 1600Mhz | FHD ips dreamcolor | delta fans Zbook 17 g3 : i7-6820HQ -75mv | M3000m 4gb | 16gb DDR4 2400Mhz | FHD ips Precision 7720 : i7-6820HQ -80mv | Zotac GTX1060 6gb, 100w OC vbios | 16gb DDR4 2666Mhz | (crappy) FHD ips -> 4K120hz upgrade Zbook 17 g5 : i7-8850H, -140mv | P5200 16gb | 32gb DDR4 | FHD IPS
Aaron44126 Posted February 10 Posted February 10 I'm also worried about physical damage. The "normal" behavior for when a GPU upgrade causes fan misbehavior is just that the fans will not turn on, report 0 RPM, and will behave when manually adjusted with a tool like this. (I seem to remember usually hearing about this when it comes to AMD GPU upgrades, though.) Apple MacBook Pro 16-inch, 2023 (personal) • Dell Precision 7560 (work) • Full specs in spoiler block below Info posts (Windows) — Turbo boost toggle • The problem with Windows 11 • About Windows 10/11 LTSC Spoiler Apple MacBook Pro 16-inch, 2023 (personal) M2 Max 4 efficiency cores 8 performance cores 38-core Apple GPU 96GB LPDDR5-6400 8TB SSD macOS 15 "Sequoia" 16.2" 3456×2234 120 Hz mini-LED ProMotion display Wi-Fi 6E + Bluetooth 5.3 99.6Wh battery 1080p webcam Fingerprint reader Also — iPhone 12 Pro 512GB, Apple Watch Series 8 Dell Precision 7560 (work) Intel Xeon W-11955M ("Tiger Lake") 8×2.6 GHz base, 5.0 GHz turbo, hyperthreading ("Willow Cove") 64GB DDR4-3200 ECC NVIDIA RTX A2000 4GB Storage: 512GB system drive (Micron 2300) 4TB additional storage (Sabrent Rocket Q4) Windows 11 Enterprise LTSC 2024 15.6" 3940×2160 IPS display Intel Wi-Fi AX210 (Wi-Fi 6E + Bluetooth 5.3) 95Wh battery 720p IR webcam Fingerprint reader Previous Dell Precision 7770, 7530, 7510, M4800, M6700 Dell Latitude E6520 Dell Inspiron 1720, 5150 Dell Latitude CPi
